홈/ 질문/Q 157043
등록일: 2009-02-082009-02-08T20:46:41+09:00 2009-02-08T20:46:41+09:00카테고리: Inventor & Solidworks
vault server 설치 질문 (vista x64)
log file입니다.
Autodesk Diagnostic Tool Log File
Checks
Name Information Result
Checking Operating System
	 Caption=Microsoft® Windows Vista™ Home Premium K
CSDVersion=Service Pack 1
OSLanguage=1042
OSProductSuite=768
OSType=18
ProductType=1
ServicePackMajorVersion=1
ServicePackMinorVersion=0
SuiteMask=784
Version=6.0.6001
Warning
Checking ASP Status
Accessing a static file through the http protocol has passed.  ASPX file failed to run at URL:http://localhost/TestASP/TestASPNet.aspx.원격 서버에서 (500) 내부 서버 오류 오류를 반환했습니다.
Failure
Validating that IIS Anonymous User Account is set up correctly
Does not apply.
Checking for a Proxy Server
Successful
Checking for correct version of Internet Explorer
Internet Explorer version found on this machine = 7.0.6001.18000
Successful
Validating that IIS Anonymous Authentication on IIS is set up correctly
Successful
Checking that IIS is running on port 80
The response from the Web Server running at Port 80:
ContentType=text/html
ResponseUri=http://adminstrator-pc/
Server=Microsoft-IIS/7.0
StatusCode=OK
Successful
Validating IIS .Net settings
Does not apply.
Checking for additional IIS ISAPI filters
Successful
Checking IIS directory paths
IIS default website root directory = C:inetpubwwwroot
Successful
Determining IIS default website Internet address(es).
IIS default website server bindings = :80:
Successful
“AutodeskDM” virtual directory existence check
Successful
Check IIS connection time out.
The IIS connection time out is :900.
Successful
Checking SQL version of Vault database instance.
Does not apply.
Checking SQL Server ‘ADMINSTRATOR-PCAUTODESKVAULT’
The database instance “AUTODESKVAULT” was not found.
Successful
Checking site compatibility with the database
Does not apply.
Checking for existing Vaults with a remote FileStore
Does not apply.
Validating Performance Counters
Successful
Checking port 80 for availability
Does not apply.
Validating that this host name can be resolved on the local network
Server hostname as known by DNS = adminstrator-PC.
Server is resolved to following IP Addresses by the DNS:
192.168.0.2
Successful
Verifying that a reboot is not pending.
Successful
Checking for known firewall
Does not apply.
Check administrative account creation.
Successful
Check permissions of ASPNET account.
Successful
에러 메세지는 대략 file failed to run at URL:http://localhost/TestASP/TestASPNet.aspx.인데
IIS 설치 다하고 매뉴얼대로 세팅 다 하고 asp2.0도 깔았습니다.
그런데 계속 오류……
어케 해야 하나요?
  • 22 조회
    • 상부에 반달 회전은 어찌 해야 할까요?
    • 인벤터 템플릿 설정 문의 합니다
    • 원통형 탱크에 노즐 부착 방법
