홈/ 질문/Q 101464
등록일: 2014-06-172014-06-17T16:59:25+09:00 2014-06-17T16:59:25+09:00카테고리: AutoCAD & CADian
VBA로 DB에서 불러온 TEXT 데이터를 Move할때 Move한 좌표값이 DB에도 자동으로 변경되도록 하고 싶은데 방법이 없을까요?
선배님들 염치 불구하고 도움을 부탁드립니다.
코드는 아래와 같습니다.
Private Sub UserForm_Activate()
    Unload Me
End Sub
Private Sub UserForm_Initialize()
Dim handle_info As String
Dim ado_conn As New ADODB.Connection
Dim ado_rs As New ADODB.Recordset
Dim filterset As AcadSelectionSet
Dim FilterEnt As Object
Dim FilterObj As Variant
Dim objectname As String
    On Error Resume Next
        If thisdrawing.SelectionSets(“sset”) Then _
            thisdrawing.SelectionSets(“sset”).Delete
    On Error GoTo 0
    connectionstring = “Provider=*******.1;Password=**********,User ID=*****;Data Source=*****;Persist Security Info=True”
   Set db = New ADODB.Connection
   db.Open connectionstring
    Set filterset = thisdrawing.SelectionSets.Add(“sset”)
    filterset.SelectOnScreen
    For Each FilterEnt In filterset
    handle = FilterEnt.handle
    Next
        ado_conn_bl.Open connectionstring
        ado_rs_bl.Open “select * from test_info where handle_bl='” + handle + “‘ or handle_fl='” + handle + “‘ or handle_su='” + handle + “‘ or handle_area='” + handle + “‘”, ado_conn_bl
        handle = ado_rs_bl.Fields!handle_line
        ado_conn_bl.Close
     db.Execute query
‘객체 필터링 및 handle_line 값으로 객채 선택
    Dim mode As Integer
    mode = acSelectionSetCrossing
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    gpCode(0) = 0
    dataValue(0) = “text”
    Dim Groupcode As Variant, dataCode As Variant
    Groupcode = gpCode
    dataCode = dataValue
    Dim bl_del_cox As Double
    Dim bl_del_coy As Double
    Dim bl_del_point1(0 To 2) As Double
    Dim bl_del_point2(0 To 2) As Double
    ado_rs_bl.Open “select * from test_info where handle_line='” + handle + “‘”, ado_conn_bl
    If Not IsNull(ado_rs_bl.Fields!bl_txt_cox) Then
    bl_del_cox = ado_rs_bl.Fields!bl_txt_cox
    End If
    ado_conn_bl.Close
    If Not IsNull(ado_rs_bl.Fields!bl_txt_coy) Then
    bl_del_coy = ado_rs_bl.Fields!bl_txt_coy
    End If
    ado_conn_bl.Close
    bl_del_point1(0) = bl_del_cox – 200: bl_del_point1(1) = bl_del_coy + 400: bl_del_point1(2) = 0
    bl_del_point2(0) = bl_del_cox + 200: bl_del_point2(1) = bl_del_coy – 1900: bl_del_point2(2) = 0
    filterset.Select mode, bl_del_point1, bl_del_point2, Groupcode, dataCode
‘DB_Update
    Dim bl_point(0 To 2) As Double
    Dim fl_point(0 To 2) As Double
    Dim su_point(0 To 2) As Double
    Dim area_point(0 To 2) As Double
    Dim x_p As Variant
    Dim y_p As Variant
    Dim bl_del As Integer
        ado_rs_bl.Open “select * from test_su where handle_id='” + handle + “‘”, ado_conn_bl
        x_p = ado_rs_bl.Fields!cox
        ado_conn_bl.Close
        y_p = ado_rs_bl.Fields!coy
        ado_conn_bl.Close
     db.Execute query
    Dim bl_cox As String
    Dim bl_coy As String
    Dim fl_cox As String
    Dim fl_coy As String
    Dim su_cox As String
    Dim su_coy As String
    Dim area_cox As String
    Dim area_coy As String
    bl_point(0) = x_p: bl_point(1) = y_p + (font_height * 1.7): bl_point(2) = 0
    fl_point(0) = x_p: fl_point(1) = y_p + (font_height * 0.4): fl_point(2) = 0
    su_point(0) = x_p: su_point(1) = y_p – (font_height * 0.8): su_point(2) = 0
    area_point(0) = x_p: area_point(1) = y_p – (font_height * 2.1): area_point(2) = 0
    bl_cox = CDbl(Val(bl_point(0)))
    bl_coy = CDbl(Val(bl_point(1)))
    fl_cox = CDbl(Val(fl_point(0)))
    fl_coy = CDbl(Val(fl_point(1)))
    su_cox = CDbl(Val(su_point(0)))
    su_coy = CDbl(Val(su_point(1)))
    area_cox = CDbl(Val(area_point(0)))
    area_coy = CDbl(Val(area_point(1)))
    ‘편집 시작
    Dim Point As Variant
    Point = thisdrawing.Utility.GetPoint(, “원하는 좌표위치를 클릭하세요”)
    For Each FilterObj In filterset
    FilterObj.Move bl_del_point1, Point
‘    FilterObj.Copy
‘    FilterObj.Erase
    thisdrawing.Application.Update
‘    thisdrawing.SelectionSets(“sset”).Delete
    Next
    MsgBox bl_cox
    query = “edit test_info set bl_txt_cox= ‘” + bl_cox + “‘, bl_txt_coy = ‘” + bl_coy + “‘, fl_txt_cox ='” + fl_cox + “‘” & _
    “, fl_txt_coy='” + fl_coy + “‘, su_txt_cox='” + su_cox + “‘, su_txt_coy='” + su_coy + “‘, area_txt_cox='” + area_cox + “‘, area_txt_coy='” + area_coy + “‘”
    db.Execute query
End Sub
CAD상에서 객체는 이동하지만 DB 상의 좌표데이터는 바뀌지가 않네요.
  • 27 조회
