홈/ 질문/Q 96684
등록일: 2012-11-202012-11-20T09:06:49+09:00 2012-11-20T09:06:49+09:00카테고리: AutoCAD & CADian
xcsh님 두 번째 작품입니다. 봐주세요^^
두 직선에 접하는 호 그리는 리습입니다.
; Draws a arc with a specified radius and tangent to two lines.
  ; approach: outside point of a circle / direction from the point / finding center point
    ;           tangent points from the pythagorean theorem  c^2 = a^2 + b^2
(defun c:ttr()
(setq radi (getdist “Enter radius”))                                     ;Specifying radius
 (setvar “osmode” 0)                                                        ;Osnap None
  (setq ftl (entsel))                                                           ;First tangent line
 (setq stl (entsel))                                                            ;Second tangent line
 (setq fsp (cdr (assoc 10 (entget (car ftl)))))                     ;Start point of the ftl
 (setq fep (cdr (assoc 11 (entget (car ftl)))))                    ;Endpoint of the ftl
 (setq ssp (cdr (assoc 10 (entget (car stl)))))               ;Start point of the stl
 (setq sep (cdr (assoc 11 (entget (car stl)))))                ;Endpoint of the stl
 (setq pt1 (inters fsp fep ssp sep nil))                             ;Intersection point
  (setq mpt1 (mapcar ‘(lambda (x) (/ x 2.0) ) (mapcar ‘+ fsp fep)))   ;Midpoint of the ftl
 (setq mpt2 (mapcar ‘(lambda (x) (/ x 2.0) ) (mapcar ‘+ ssp sep)))    ;Midpoint of the stl
    (setq centroid (mapcar ‘(lambda (x) (/ x 3.0) ) (mapcar ‘+ pt1 mpt1 mpt2)))
    ;Centroid of the three points, determining offset direction.
  (command “offset” radi ftl centroid “”)                         ;Offset line from the ftl
 (setq line1 (entlast))
 (command “offset” radi stl centroid “”)                         ;Offset line from the stl
 (setq line2 (entlast))
 (setq dxf1 (entget  line1))
 (setq sp1 (cdr (assoc 10 dxf1)))                                        ;Start point of the line1                       (setq ep1 (cdr (assoc 11 dxf1)))                                          ;Endpoint of the line1
 (setq dxf2 (entget  line2))
 (setq sp2 (cdr (assoc 10 dxf2)))                                           ;Start point of the line2
 (setq ep2 (cdr (assoc 11 dxf2)))                                             ;Endpoint of the line2
 (setq center (inters sp1 ep1 sp2 ep2 nil))                                ;Center of the arc
 (setq dist (distance pt1 center))              ;Distance betweeon pt1 and center (hypotenuse)
 (setq tl(sqrt (- (expt dist 2) (expt radi 2))))                      ;Tangent legnth from pt1
 (setq tpt1 (polar pt1 (angle pt1 mpt1) tl))                                     ;Tangent point1
  (setq tpt2 (polar pt1 (angle pt1 mpt2) tl))                                   ;Tangent point2
  (command “erase” line1 line2 “”)
    (command “arc” tpt1 “E” tpt2 “d” pt1 )
    ;Draws the arc using starpoint, endpoint, tangent direction
  (setvar “osmode” (+ 1 32 128 2048))
  • 15 조회
