홈/ 질문/Q 111966
등록일: 2019-11-202019-11-20T14:01:44+09:00 2019-11-20T14:01:44+09:00카테고리: AutoCAD & CADian
길이(LM) 리습에 “L =” 값 “m” / 면적(AQ) 리습에 “A =” 값 “m2” 로 값 앞 뒤로 붙이고 싶어요. 도와주세요!
 ——————- 길이산출 (LM) 리습이구  L = 99.99 m  로 표기하고 싶어요 —————————
 (princ “n Eltity Length Sum”)
  (setvar “cmdecho” 0)
  (setq ss (ssget (list (cons 0 “LINE,CIRCLE,ARC,POLYLINE,LWPOLYLINE,ELLIPSE,SPLINE”))))
  (if ss
    (progn
      (setq index 0)
      (setq linelist nil)
      (setq linenumlist nil)
      (repeat (sslength ss)
        (setq ent (ssname ss index))
        (command-s “lengthen” ent “” “” “”)
        (setq dist (GETVAR “PERIMETER”))
        (if (apply ‘or (mapcar ‘(lambda (x) (equal dist x 1)) linelist))
          (progn
            (setq temp 0)
            (setq lnum nil)
            (foreach x linelist
              (if (equal dist x 1)
                (setq lnum temp)
              (setq temp (1+ temp))
            (setq count 0)
            (setq temp nil)
            (foreach x linenumlist
              (if (= count lnum)
                (setq temp (append temp (list (+ x 1))))
                (setq temp (append temp (list x)))
              (setq count (1+ count))
            (setq linenumlist temp)
          (progn
            (setq linelist (append linelist (list dist)))
            (setq linenumlist (append linenumlist (list 1)))
        (setq index (1+ index))
      (setq txt “”)
      (setq count 0)
      (setq total 0)
      (setq subtotal 0)
      (repeat (length linelist)
        (if (= count 0)
          (if (> (nth count linenumlist) 1)
            ;;;;(setq txt (strcat “L = ” (rtos (/ (nth count linelist) 1.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            ;;;;(setq txt  (strcat “L = ” (rtos (/ (nth count linelist) 1.0) 2 2)))
            (setq txt (strcat “L = ” (rtos (/ (nth count linelist) 1000.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            (setq txt  (strcat “L = ” (rtos (/ (nth count linelist) 1000.0) 2 2)))
            ;;;;(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            ;;;;(setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1.0) 2 2)))
            (setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1000.0) 2 2) “*” (rtos (nth count linenumlist) 2 0) “개”))
            (setq txt (strcat txt ” + ” (rtos (/ (nth count linelist) 1000.0) 2 2)))
        (setq subtotal (* (/ (nth count linelist) 1) (nth count linenumlist)))
        (setq total (+ subtotal total))
        (setq total1 (/ total 1000));————->추가함
      ;;;;(setq txt (strcat txt ” = ” (rtos total 2 2) “m”))
      (princ txt)
(if (not (setq tth (getreal (strcat “n현재 TextSize : <” (rtos(getvar “textsize”) 2 1) “> 입니다. 원하는 Text 크기를 입력하세요 : “))))
    (setq tth (getvar “textsize”))
    (setvar “textsize” tth)
      (setq pt (getpoint “n 텍스트 삽입점 : “))
      (if pt (command “text” pt “” “” txt))
——————- 면적산출 (AQ리습)구,  A = 99.99 m2 로 표기하고 싶어요 —————————
(defun c:aq( / doc space ss index obj mi mx minpt maxpt inspt area txtobj )
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (cond
    ((= (vla-get-activespace doc) 1) (setq space (vla-get-modelspace doc)))
    ((= (vla-get-activespace doc) 0) (setq space (vla-get-paperspace doc)))
  (if (setq ss (ssget (list (cons 0 “CIRCLE,ARC,*POLYLINE,LINE,ELLIPSE,SPLINE”))))
    (if (or (setq ts (getreal (strcat “n텍스트 높이 입력 <” (vl-princ-to-string (getvar “textsize”)) “>:”))) (setq ts (getvar “textsize”)))
      (progn
  (setvar “textsize” ts)
 (setq index 0)
   (setq obj (vlax-ename->vla-object (ssname ss index)))
   (vla-getboundingbox obj ‘mi ‘mx)
   (setq minpt (vlax-safearray->list mi) maxpt (vlax-safearray->list mx))
   (setq inspt (polar minpt (angle minpt maxpt) (/ (distance minpt maxpt) 2)))
   (setq inspt (list (car inspt) (+ (cadr inspt) (* ts 2))))
   (setq area (vla-get-area obj)) ;len (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)))
    (setq a “”  b (rtos (/ area 1000000.) 2 2) )
       (setq p (vlax-3d-point inspt))
       (setq txtobj (vla-addtext space (strcat a b) p ts))
       (vla-put-alignment txtobj 4)
       (vla-put-textalignmentpoint txtobj p)
       (setq inspt (polar inspt (/ (* 270 pi) 180) (* ts 2)))
 ;(command “chprop” (ssget “x” ‘((0 . “TEXT”) (1 . “평*”))) “” “c” “7” “”)
(vl-load-com)
(prompt “n[ AQ ]”)  ;;;;
  • 47 조회
    • 도곽크기를 a2 그리고 출력은 a3로 하려는데
    • 교통영향평가 cad 자료
    • 아이콘을 바꾸고 싶습니다.
