홈/ 질문/Q 23527
등록일: 2006-02-042006-02-04T13:22:13+09:00 2006-02-04T13:22:13+09:00카테고리: AutoCAD & CADian
길이를 더해주고 텍스트로 표현되는 리습인데 수정좀 해주세여
(DEFUN C:ds(/ eg egl n l ne entname entn p1 p2 l2 radi l_ength)
(SETVAR “cmdecho” 0)
(SETQ EG (SSGET))
(SETQ EGL (SSLENGTH EG))
(SETQ N 0)
(setq l 0)
(setq ne 0)
(WHILE (< N EGL)
(SETQ ENTN (SSNAME EG N))
(SETQ ENT (ENTGET ENTN))
(setq entname (assoc 0 ent))
(setq entname (cdr entname))
(if (= entname “LINE”)
(progn
(SETQ p1 (ASSOC 10 ENT))
(SETQ p2 (ASSOC 11 ENT))
(SETQ p1x (car (CDR p1)))
(SETQ p1y (CaDdR p1))
(SETQ p2x (car (CDR p2)))
(SETQ p2y (CaDdR p2))
(setq l2 (sqrt (+ (expt (- p1x p2x) 2) (expt (- p1y p2y) 2))))
(setq l (+ l l2))
(setq ne (+ ne 1))
(if (= entname “CIRCLE”)
(progn
(SETQ p1 (ASSOC 40 ENT))
(SETQ radi (cdr p1))
(setq l2 (* 2 (* pi radi)))
(setq l (+ l l2))
(setq ne (+ ne 1))
(if (= entname “ARC”)
(progn
(SETQ p1 (ASSOC 50 ENT))
(SETQ p2 (ASSOC 51 ENT))
(SETQ p1R (CDR p1))
(SETQ p2R (CDR p2))
(SETQ TH (ABS (- P1R P2R)))
(setq l2 (* RADI TH))
(setq l (+ l l2))
(setq ne (+ ne 1))
(if (or (= entname “LWPOLYLINE”)(= entname “POLYLINE”))
(progn
(command “area” “e” entn)
(setq l2 (getvar “perimeter”))
(setq l (+ l l2))
(setq ne (+ ne 1))
(SETQ N (+ 1 N))
(princ “n >>>>> “)
(if (> egl ne)
(progn
(princ ne)(princ ” of “)(princ egl)
(princ ” objects are measured // “)
(princ ” Total length is “)
(setq l_ength (rtos (/ l 1000) 2 2))
(prin1 l_ength)
(setq pt (getpoint “nText Point: “))
(setq h (getvar “textsize”))
(prompt “nText Height: “)
(princ H)
(princ ” : “)
(setq z (getdist))
(if z
(setq h z)
(command “text”
(setq z pt)
(setq z h)
(setq z 0.0)
(setq z l_ength)
(setvar “cmdecho” 1)
(setvar “blipmode” 1)
이건데요 소수점 첫째자리까지 나타났으면 하는데요 꼭 0.00 이런식으로
나오죠… ㅠㅠ
소수점 자리수를 바꾸려면 어케하나요
  • 23 조회
    • 질문 검색 안되나요?
    • 배치화면에서의 작업은 엌덯게 하나요
    • 오토캐드 명령어창 ui 관련 질문
    • 오토케드2012 숫자로 레이어 변경방법 있나요?
