홈/ 질문/Q 92398
등록일: 2011-07-222011-07-22T13:11:26+09:00 2011-07-22T13:11:26+09:00카테고리: AutoCAD & CADian
도와주세요. ㅠ.ㅠ 넘버링 넣는 리습입니다. 첫글자는 강제로 P가항상 들어가있으면 좋겠습니다.
(defun c:33( / #circle-size #text-size #font #arrow-size #layer-name
                p1 p2 p3 p4 #qq
    (setq #circle-size 4
          #text-size 3
          #font “ROMANS”
          #arrow-size 3
          #layer-name “파트리스트”
;;_________________________________________________________Sub Routine – 01
    (defun PTE:start( variable-list / )
        (setq *variable* (mapcar ‘getvar variable-list)
              *list* variable-list
        (vla-startundomark (vla-get-ActiveDocument (vlax-get-acad-object)))
;;_________________________________________________________Sub Routine – 02
    (defun PTE:end ()
        (mapcar ‘setvar *list* *variable*)
        (vla-endundomark (vla-get-ActiveDocument (vlax-get-acad-object)))
        (setq *list nil *variable* nil)
;;_________________________________________________________Make Style
    (entmake (list (cons 0 “LAYER”)
               (cons 100 “AcDbSymbolTableRecord”)
               (cons 100 “AcDbLayerTableRecord”)
               (cons 2 #layer-name)
               (cons 70 0)
               (cons 62 4)
               (cons 6 “CONTINUOUS”)))
    (vl-cmdf “-STYLE” “ST-text” #font “0” “” “0” “N” “N” “N”)
;;________________________________________________________Error Function
    (defun *error* (s)
        (PTE:end)
        (setq *ERROR* nil)
;;                       M A I N – R O U T I N E
    (setq #sc (getvar ‘dimscale))
    (PTE:start ‘(“clayer” “orthomode” “osmode” “dimclrd” “dimasz” “cmdecho”))
    (mapcar ‘setvar *list* (list #layer-name 0 0 256 #arrow-size 0))
    (if (= nil #qq_t)(setq #qq_t “-“))
    (setq p1 (getpoint “nLeader Start Point: “)
          p2 (getpoint p1 “nLeader To Point: “)
     (if (or (> (* 0.5 pi)(angle p1 p2)) (< (* 1.5 pi)(angle p1 p2)))
        (setq p3 (polar p2 0 (* (+ #circle-size 7) (getvar ‘dimscale))))
        (setq p3 (polar p2 pi (* (+ #circle-size 7) (getvar ‘dimscale))))
    (setq p4 (polar p3 (angle p3 p2) (* #circle-size #sc)))
    (vl-cmdf “leader” P1 P2  “” “” “n”)
    (entmakex (list (cons 0 “CIRCLE”)
                    (cons 10 p3)
                    (cons 40 (* #circle-size #sc))))
    (vl-cmdf “line” P2 P4 “”)
    (setq #qq ((getstring (strcat “nCIRCLE IN GOTO NUMBER <” #qq_t “> :P”)))
    (if (= #qq “”) (setq #qq #qq_t))
    (vl-cmdf “text” “s” “ST-text” “j” “mc” P3 (P* #sc #text-size) “0” #qq)
    (vl-cmdf “change” (ssget “l”) “” “p” “c” “파트리스트” “”)
    (setq #qq_t #qq )
    (PTE:end)
  • 20 조회
