선과 선사이 중심선을 그리기위한 리습으로 잘 쓰고 있습니다
다만 이 리습은 라인으로만 그려진 선만 인식합니다
폴리라인은 인식하지 않아서요
자잘하게는 선을 깨서 써왔지만 혹시 폴리라인 자체도 인식 가능하게 수정하는 방법이 있는지 여쭤봅니다
(defun c:De(/ ct no len c2 cla s1 s2 e1 e2 int msx msy mex mey i e1 e2 s1 s2 sx sy ex ey po1 )
( prompt “n select 2-LINES : … ” ) ; selection entity
(setq os (getvar “osmode”))
(setvar “osmode” 0)
(command “undo” “be”)
( setq ct ( ssget ‘((0 . “LINE”))))
( SETQ no ( GETINT “n DIVIDING NUMBER : … “)
len ( sslength ct ) cl1 ( ssname ct 0 )
cl2 ( ssname ct 1 ) c1 ( entget cl1 )
c2 ( entget cl2 )
cla ( cdr ( assoc 8 c1 ))
s1 ( cdr ( assoc 10 c1 ))
e1 ( cdr ( assoc 11 c1 ))
s2 ( cdr ( assoc 10 c2 ))
e2 ( cdr ( assoc 11 c2 ))
int ( inters s1 e2 e1 s2 ) )
( if (= int nil ) ( setq k s2 s2 e2 e2 k ))
( setq msx (/ (- (car s2) (car s1)) no )
msy (/ (- (cadr s2) (cadr s1)) no )
mex (/ (- (car e2) (car e1)) no )
mey (/ (- (cadr e2) (cadr e1)) no )
i 1 )
( REPEAT (- NO 1)
( setq sx (+ (car s1) (* msx i))
sy (+ (cadr s1) (* msy i))
ex (+ (car e1) (* mex i))
ey (+ (cadr e1) (* mey i)) i (+ i 1)
po1 (list sx sy) po2 (list ex ey) )
( COMMAND “line” (trans po1 0 1) (trans po2 0 1) “” )
(command “undo” “e”)
(setvar “osmode” os)
