홈/ 질문/Q 98186
등록일: 2013-05-092013-05-09T14:30:02+09:00 2013-05-09T14:30:02+09:00카테고리: AutoCAD & CADian
레이어 변환 리습이 2014에서 안되네요.(Text 리습첨부)
(Defun PTE:layer-subst-load ( / layer )
                ;            Change property For User
                ;   cmd       name       color       linetype
  (setq layer ‘((   “ce”       “1_centerline”    1       “1_centerline”     )
                       (   “hi”       “3_hiddenline”    2       “3_hiddenline”     )
                       (   “im”       “4_imaginary”     3       “4_imaginary”      )
                       (   “ha”       “5_hatching”      4       “5_hatching”       )
                       (   “pu”       “6_purchases”     5       “6_purchases”      )
                       (   “0”        “0”               6       “0”                )))
    ;;             Sub Function – 01            ;;
    (defun PTE:layer-subst-load-subfunction( name color ltype / ssets *error* )
        ;; __Sub 01
        (defun *error*(s)
            (if (not(vl-catch-all-error-p (vl-catch-all-apply ‘vla-item (list ssets “SS1”))))
                (vla-delete (vla-item ssets “SS1”))
        ;; __Sub 02
        (defun PTE:layer( la col lty / layer )
            (while (not(tblsearch “layer” la))
                (setq Layer
                    (vla-add
                        (vla-get-Layers
                            (vla-get-activedocument(vlax-get-acad-object))
                        ) la
                (vla-put-Color Layer col)
                (vla-put-Linetype Layer lty)
        ;; __Sub 03
        (defun LM:LoadLinetypes ( lts / acapp acdoc aclts aclin ) (vl-load-com)
            (setq acdoc (vla-get-ActiveDocument (setq acapp (vlax-get-acad-object)))
                  aclts (vla-get-Linetypes acdoc)
            (setq aclin
                (apply ‘append
                    (mapcar ‘(lambda ( directory ) (vl-directory-files directory “*.lin” 1))
                        (LM:str->lst
                            (vla-get-SupportPath (vla-get-Files (vla-get-Preferences acapp))) “;”
            (apply ‘and
                (mapcar
                    (function
                        (lambda ( lt )
                            (or (tblsearch “LTYPE” lt)
                                (vl-some
                                    (function
                                        (lambda ( lin )
                                            (vl-catch-all-apply ‘vla-load (list aclts lt lin))
                                    aclin
                    lts
        ;; __Sub 04
        (defun LM:str->lst ( str del / pos )
            (if (setq pos (vl-string-search del str))
                (vl-remove “”
                    (cons
                        (substr str 1 pos)
                        (LM:str->lst (substr str (+ pos 1 (strlen del))) del)
                (list str)
        ;; __Main
        (or (tblsearch “ltype” ltype)(LM:LoadLinetypes (list ltype)))
        (PTE:layer name color ltype)
        (setq ssets (vla-get-selectionsets (vla-get-activedocument(vlax-get-acad-object))))
        (vla-selectonscreen (setq ss (vla-add ssets “SS1”)))
        (vlax-for ent ss
            (vla-put-layer ent name)
            (vla-put-linetype ent “ByLayer”)
            (vla-put-color ent 256)
    ;;                Main Function             ;;
    (foreach lst layer
        (eval
            (list ‘defun (read(strcat “c:” (car lst))) ‘nil
                (list ‘PTE:layer-subst-load-subfunction (cadr lst) (caddr lst) (cadddr lst) )
    )(princ)
)(vl-load-com)
(PTE:layer-subst-load)
2009에서는 잘 사용하고 있는데.
이번에 2014에 적용을 해보니.. 명령어는 먹히는데.
레이어 변황이 안되네요.
뭐 때문이지 아시는 분은 가르침을 부탁드려 봅니다.
날씨가 많이 더워 졌네요..즐거운 오후 되세요..ㅎ
  • 17 조회
