홈/ 질문/Q 111531
등록일: 2019-07-112019-07-11T20:06:25+09:00 2019-07-11T20:06:25+09:00카테고리: AutoCAD & CADian
리습 선길이합산 단위변화 부탁드립니다
캐드 리습 사용중인데 선길이합산 중 단위를 m변경 및 소수점 2자리 변경하고싶은데 방법있을까요?
(defun c:lle (/ ent n dis ent_l #a #ad #as th)
(setvar “cmdecho” 0)
(setq ent (ssget ‘((0 . “LINE,CIRCLE,ARC,POLYLINE,LWPOLYLINE,ELLIPSE,SPLINE”))))
(setq th (getreal (strcat “n텍스트 높이 입력 <” (rtos (getvar “textsize”)) “>:”)))
(if th (setvar “textsize” th))
(setq n 0 dis 0)
(repeat (sslength ent)
(setq ent_l (ssname ent n))
(command “lengthen” ent_l “”)
(setq dis (+ dis (GETVAR “PERIMETER”)))
(setq n (1+ n))
(setq #a(strcat (rtos dis)))
(prompt (strcat “n” #a))
(vl-load-com)
(setq #ad(vla-get-activedocument(vlax-get-acad-object)))
(setq #as
(if (> (vla-get-activespace #ad) 0)
(vla-get-modelspace #ad)
(vla-get-paperspace #ad)
);;if
);;setq
(vla-addtext #as #a (vlax-3d-point(getpoint “n≫≫≫Pick text point:”)) (getvar “textsize”))
(mapcar ‘vlax-release-object (list #as #ad))
(setvar “cmdecho” 1)
  • 57 조회
