홈/ 질문/Q 191005
등록일: 2024-09-052024-09-05T07:36:20+09:00 2024-09-05T07:36:20+09:00카테고리: AutoCAD & CADian
리습이 자동로드가 안되는데 어찌할지 모르겠어요
autocad 2024사용중인데 appload로 불러들였는데 매번 안불러집니다.
첨부와같이 설정했는데 안되네요
다시 appload로 불러들이면 됩니다.
loadlisp파일내용은 아래와같습니다.
아래
(Load “c:dawooLISP\22.lsp”)
(Load “c:dawooLISP\2PM.lsp”)
(Load “c:dawooLISP\3.lsp”)
(Load “c:dawooLISP\3LE.lsp”)
(Load “c:dawooLISP\4.lsp”)
(Load “c:dawooLISP\5.lsp”)
(Load “c:dawooLISP\6.lsp”)
(Load “c:dawooLISP\7.lsp”)
(Load “c:dawooLISP\A1.lsp”)
(Load “c:dawooLISP\a3.lsp”)
(Load “c:dawooLISP\AA.lsp”)
(Load “c:dawooLISP\AB.lsp”)
(Load “c:dawooLISP\ALE.lsp”)
(Load “c:dawooLISP\AR.lsp”)
(Load “c:dawooLISP\ARY.lsp”)
(Load “c:dawooLISP\B.lsp”)
(Load “c:dawooLISP\BLE.lsp”)
(Load “c:dawooLISP\CCH.lsp”)
(Load “c:dawooLISP\DIMSETUP.lsp”)
(Load “c:dawooLISP\JJ.lsp”)
(Load “c:dawooLISP\LE.lsp”)
(Load “c:dawooLISP\LF.lsp”)
(Load “c:dawooLISP\LFF.lsp”)
(Load “c:dawooLISP\LT.lsp”)
(Load “c:dawooLISP\OFD.lsp”)
(Load “c:dawooLISP\OFW.lsp”)
(Load “c:dawooLISP\PJC.lsp”)
(Load “c:dawooLISP\QQ.lsp”)
(Load “c:dawooLISP\SLAB.lsp”)
(Load “c:dawooLISP\Old-one.lsp”)
(Load “c:dawooLISP\DTL.lsp”)
(Load “c:dawooLISP\MO.lsp”)
(Load “c:dawooLISP\SUM.lsp”)
(Load “c:dawooLISP\OF.lsp”)
(Load “c:dawooLISP\OFF.lsp”)
(Load “c:dawooLISP\2L.lsp”)
(Load “c:dawooLISP\PBOX.lsp”)
;(Load “c:dawooLISP\STS.lsp”)
(Load “c:dawooLISP\Ip.lsp”)
(Load “c:dawooLISP\abox.lsp”)
(Load “c:dawooLISP\PW.LSP”)
(Load “c:dawooLISP\cl.lsp”)
(Load “c:dawooLISP\af.lsp”)
(Load “c:dawooLISP\w2.lsp”)
(Load “c:dawooLISP\pj.lsp”)
(Load “c:dawooLISP\XCX.VLX”)
(Load “c:dawooLISP\atg.lsp”)
(Load “c:dawooLISP\area-ar1.lsp”)
(Load “c:dawooLISP\hatchOutLine.lsp”)
(load “c:dawooonekey.lsp”)
(command “ucsicon” “off”)
(command “-scalelistedit” “r” “y” “e”)
(COMMAND “viewres” “Y” “2000”)
;;(command “LAYERFILTERALERT” “2”)
(defun c:ZA() (command “_zoom””_a”)(princ));zoom all
(defun c:ZC() (command “_zoom””_c”)(princ));zoom center
(defun c:ZD() (command “_zoom””_d”)(princ));zoom dynamic
(defun c:ZE() (command “_zoom””_e”)(princ));zoom expand
(defun c:ZP() (command “_zoom””_p”)(princ));zoom prvious
(defun c:ZW() (command “_zoom””_w”)(princ));zoom Window
(defun c:ZZ() (command “_zoom””_p”)(princ));zoom prvious
appload
  • 367 조회
