홈/ 질문/Q 93340
등록일: 2011-10-272011-10-27T20:58:30+09:00 2011-10-27T20:58:30+09:00카테고리: AutoCAD & CADian
멀티카핀데요.. 인수가적습니다 라고 실행이안되요 도와주세요
(defun C:multcopy ( / ent tdist pnt1 spt1 ang1 dist)
(set)
(setq ent T)
(while ent (setq tdist 0)
 (setq Ent (SSget))
 (if ent
  (progn
   (setq Pnt1 (getpoint “nBase point:”))
   (setq spt1 (getpoint Pnt1 “nAngle point:”))
   (setq ang1 (angle pnt1 spt1))
   (while
    (and (setq dist (mc_udist 1 “” “nDistance:” dist pnt1))(/= dist 0.0))
    (setq tdist (+ tdist dist))
    (setq spt1 (polar pnt1 ang1 tdist))
    (command “Copy” Ent “” Pnt1 spt1)
  (princ “nNext distance:”)
(reset)
(defun mc_udist (bit kwd msg def bpt / inp)
(if def (setq msg (strcat “n>> ” msg ” <” (rtos def) “>: “)bit (* 2 (fix (/ bit 2))))
(setq msg (strcat “n>> ” msg “: “)))
(initget bit kwd)(setq inp (if bpt (getdist msg bpt)
(getdist msg)))
(if inp inp def))
  • 70 조회
