홈/ 질문/Q 98330
등록일: 2013-05-272013-05-27T00:26:23+09:00 2013-05-27T00:26:23+09:00카테고리: AutoCAD & CADian
면적,길이,평을 구하는 리습인데…길이를 mm에서m로 나타나게…
면적,길이,평을 구하는 리습인데…길이를 mm에서m로 나타나게 수정 좀 부탁드리겠습니다.
(defun c:aaa ( / doc space ss index obj mi mx minpt maxpt inspt area txtobj )
 (setvar “cmdecho” 0)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (cond
    ((= (vla-get-activespace doc) 1) (setq space (vla-get-modelspace doc)))
    ((= (vla-get-activespace doc) 0) (setq space (vla-get-paperspace doc)))
  (if (setq ss (ssget (list (cons 0 “CIRCLE,ARC,*POLYLINE,LINE,ELLIPSE,SPLINE”))))
    (if (or (setq ts (getreal (strcat “n텍스트 높이 입력 <” (vl-princ-to-string (getvar “textsize”)) “>:”))) (setq ts (getvar “textsize”)))
      (progn
  (setvar “textsize” ts)
 (setq index 0)
 (repeat (sslength ss)
   (setq obj (vlax-ename->vla-object (ssname ss index)))
   (vla-getboundingbox obj ‘mi ‘mx)
   (setq minpt (vlax-safearray->list mi) maxpt (vlax-safearray->list mx))
   (setq inspt (polar minpt (angle minpt maxpt) (/ (distance minpt maxpt) 2)))
   (setq inspt (list (car inspt) (+ (cadr inspt) (* ts 2))))
   (setq area (vla-get-area obj) len (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)))
   (mapcar ‘(lambda (a b)
       (setq p (vlax-3d-point inspt))
       (setq txtobj (vla-addtext space (strcat a b) p ts))
       (vla-put-alignment txtobj 4)
       (vla-put-textalignmentpoint txtobj p)
       (setq inspt (polar inspt (/ (* 270 pi) 180) (* ts 2)))
              ‘(“평 : ” “면적(㎡)  : ” “길이(mm) : ” ) (list (rtos (/ area 3305796.) 2 2) (rtos (/ area 1000000.) 2 3) (rtos len 2 2))
   (setq index (1+ index))
 (command “chprop” (ssget “x” ‘((0 . “TEXT”) (1 . “평*”))) “” “c” “7” “”)
(vl-load-com)
(prompt “n[ AAA ]”)
  • 23 조회
    • 캐드출력시 pc3모드이 이상현상
    • 객체 전체 간격 조정 할수 있을까요?
