홈/ 질문/Q 99001
등록일: 2013-08-022013-08-02T10:07:07+09:00 2013-08-02T10:07:07+09:00카테고리: AutoCAD & CADian
면적리습 수정 부탁드립니다..
(defun c:aaa ( / doc space ss index obj mi mx minpt maxpt inspt area txtobj )
 (setvar “cmdecho” 0)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (cond
    ((= (vla-get-activespace doc) 1) (setq space (vla-get-modelspace doc)))
    ((= (vla-get-activespace doc) 0) (setq space (vla-get-paperspace doc)))
  (if (setq ss (ssget (list (cons 0 “CIRCLE,ARC,*POLYLINE,LINE,ELLIPSE,SPLINE”))))
    (if (or (setq ts (getreal (strcat “n텍스트 높이 입력 <” (vl-princ-to-string (getvar “textsize”)) “>:”))) (setq ts (getvar “textsize”)))
      (progn
  (setvar “textsize” ts)
 (setq index 0)
 (repeat (sslength ss)
   (setq obj (vlax-ename->vla-object (ssname ss index)))
   (vla-getboundingbox obj ‘mi ‘mx)
   (setq minpt (vlax-safearray->list mi) maxpt (vlax-safearray->list mx))
   (setq inspt (polar minpt (angle minpt maxpt) (/ (distance minpt maxpt) 2)))
   (setq inspt (list (car inspt) (+ (cadr inspt) (* ts 2))))
   (setq area (vla-get-area obj) len (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)))
   (mapcar ‘(lambda (a b)
       (setq p (vlax-3d-point inspt))
       (setq txtobj (vla-addtext space (strcat a b) p ts))
       (vla-put-alignment txtobj 4)
       (vla-put-textalignmentpoint txtobj p)
       (setq inspt (polar inspt (/ (* 270 pi) 180) (* ts 2)))
              ‘(“평 : ” “면적(㎡)  : ” “길이(mm) : ” ) (list (rtos (/ area 3305796.) 2 2) (rtos (/ area 1000000.) 2 3) (rtos len 2 2))
   (setq index (1+ index))
 (command “chprop” (ssget “x” ‘((0 . “TEXT”) (1 . “평*”))) “” “c” “7” “”)
(vl-load-com)
(prompt “n[ AAA ]”)
여기서 길이만 빼주세요. 그리고 이왕이면 평이랑 면적이 색이 다른데요..색 통일해주심 감사해요. 흰색으루….
  • 46 조회
      2013-10-22T17:36:31+09:00답변 등록 답변 등록 일시 2013-10-22 5:36 pm
      상큼메론90님~~
      표기를     면적: 1,000.11m2
                               (300.11평)
      이렇게는 어떻게 하는지요?  제가 만지면 안되더라구요 갈르쳐주세욤  꾸뻑 고수님~~
