홈/ 질문/Q 29251
등록일: 2002-03-052002-03-05T22:48:44+09:00 2002-03-05T22:48:44+09:00카테고리: AutoCAD & CADian
미국대사관에 욕멜 보냇는데 답장인데 해석점…
Confirming:
> SIGNOFF USKOREA-KR
You are not subscribed to the USKOREA-KR list under the address your message
came from (kmj7059@HANMAIL.NET). You are being mailed some additional
information with a few hints on getting your subscription cancelled. Please
read these instructions before trying anything else.
또 하나Your command:
SUBSCRIBE USKOREA-KR kim-min-jung
requires confirmation. To confirm the execution of your command, simply
point your browser to the following URL:
http://lists.state.gov/SCRIPTS/WA-USIAINFO.EXE?OK=195B7733&L=USKOREA-KR
Alternatively, if you have no WWW access, you can reply to the present
message and type “ok” (without the quotes) as the text of your message.
Just the word “ok” – do not retype the command. This procedure will work
with any mail program that fully conforms to the Internet standards for
electronic mail. If you receive an error message, try sending a new
message to LISTSERV@LISTS.STATE.GOV (without using the “reply” function –
this is very important) and type “ok 195B7733” as the text of your
message.
Finally, your command will be cancelled automatically if LISTSERV does
not receive your confirmation within 48h. After that time, you must start
over and resend the command to get a new confirmation code. If you change
your mind and decide that you do NOT want to confirm the command, simply
discard the present message and let the request expire on its own.
또
Your command:
SIGNOFF *
http://lists.state.gov/SCRIPTS/WA-USIAINFO.EXE?OK=6C480346
this is very important) and type “ok 6C480346” as the text of your
message.
또
Your command:
http://lists.state.gov/SCRIPTS/WA-USIAINFO.EXE?OK=0C2D163A&L=USKOREA-KR
this is very important) and type “ok 0C2D163A” as the text of your
message.
한영해독기점
  • 51 조회
