홈/ 질문/Q 189302
조철민
조철민Lv.0
등록일: 2024-02-292024-02-29T21:59:42+09:00 2024-02-29T21:59:42+09:00카테고리: AutoCAD & CADian
블럭카운터 리습 표크기
;;————–=={ Count.lsp – Advanced Block Counter }==————–;;
;; This program enables the user to record the quantities of a ;;
;; selection or all standard or dynamic blocks in the working drawing. ;;
;; The results of the block count may be displayed at the AutoCAD ;;
;; command-line, written to a Text or CSV file, or displayed in an ;;
;; AutoCAD Table, where available. ;;
;; Upon issuing the command syntax ‘count’ at the AutoCAD ;;
;; command-line, the user is prompted to make a selection of standard ;;
;; or dynamic blocks to be counted by the program. At this prompt, ;;
;; the user may right-click or press ‘Enter’ to automatically count ;;
;; all blocks in the drawing. ;;
;; Depending on the output setting, the results may then be printed ;;
;; to the AutoCAD command-line and displayed in the Text Window, or ;;
;; the user will be prompted to specify an insertion point for the ;;
;; table, or a filename & location for the Text or CSV output file. ;;
;; The program settings may be configured using the ‘countsettings’ ;;
;; command; this command will present the user with a dialog interface ;;
;; through which the data output, table & file headings, displayed ;;
;; columns, sorting field & sort order may each be altered. ;;
;; Author: Lee Mac, Copyright ?2014 – http://www.lee-mac.com ;;
;; Version 1.0 – 2010-06-05 ;;
;; – First release. ;;
;; Version 1.1 – 2010-06-06 ;;
;; – Updated code to include Settings dialog. ;;
;; – Added Undo Marks. ;;
;; Version 1.2 – 2010-06-06 ;;
;; – Fixed bug with 64-bit systems. ;;
;; Version 1.3 – 2011-03-02 ;;
;; – Program completely rewritten. ;;
;; – Updated code to work without error on 64-bit systems by fixing ;;
;; bug with ObjectID subfunction – my thanks go to member ‘Jeff M’ ;;
;; at theSwamp.org forums for helping me solve this problem. ;;
;; – Added ability to write block count to Text/CSV Files. ;;
;; Version 1.4 – 2014-06-15 ;;
;; Version 1.5 – 2015-06-07 ;;
;; – Minor update to enable full compatibility with ZWCAD. ;;
;; (regeneratetablesuppressed property not available) ;;
(setq
count:version “1-5”
count:defaults
(out “tab”)
(tg1 “1”)
(tg2 “1”)
(tg3 “1”)
(ed1 “Block Data”)
(ed2 “Preview”)
(ed3 “Block Name”)
(ed4 “Count”)
(srt “blk”)
(ord “asc”)
(defun count:fixdir ( dir )
(vl-string-right-trim “” (vl-string-translate “/” “” dir))
(defun count:getsavepath ( / tmp )
(cond
( (setq tmp (getvar ‘roamablerootprefix))
(strcat (count:fixdir tmp) “\Support”)
( (setq tmp (findfile “acad.pat”))
(count:fixdir (vl-filename-directory tmp))
( (count:fixdir (vl-filename-directory (vl-filename-mktemp))))
(setq count:savepath (count:getsavepath) ;; Save path for DCL & Config files
count:dclfname (strcat count:savepath “\LMAC_count_V” count:version “.dcl”)
count:cfgfname (strcat count:savepath “\LMAC_count_V” count:version “.cfg”)
(defun c:bc
*error*
all
col
des dir
ed1 ed2 ed3 ed4
fil fnm fun
hgt
idx ins
lst
ord out
row
sel srt
tab tg1 tg2 tg3 tmp
xrf
(defun *error* ( msg )
(if (= ‘file (type des))
(close des)
(if (and (= ‘vla-object (type tab))
(null (vlax-erased-p tab))
(= “AcDbTable” (vla-get-objectname tab))
(vlax-write-enabled-p tab)
(vlax-property-available-p tab ‘regeneratetablesuppressed t)
(vla-put-regeneratetablesuppressed tab :vlax-false)
(if (and (= ‘vla-object (type count:wshobject))
(not (vlax-object-released-p count:wshobject))
(progn
(vlax-release-object count:wshobject)
(setq count:wshobject nil)
(count:endundo (count:acdoc))
(if (and msg (not (wcmatch (strcase msg t) “*break,*cancel*,*exit*”)))
(princ (strcat “nError: ” msg))
(if (not (findfile count:cfgfname))
(count:writecfg count:cfgfname (mapcar ‘cadr count:defaults))
(count:readcfg count:cfgfname (mapcar ‘car count:defaults))
(foreach sym count:defaults
(if (not (boundp (car sym))) (apply ‘set sym))
(if (and (= “tab” out) (not (vlax-method-applicable-p (vla-get-modelspace (count:acdoc)) ‘addtable)))
(setq out “txt”)
(count:startundo (count:acdoc))
(while (setq tmp (tblnext “block” (null tmp)))
(if (= 4 (logand 4 (cdr (assoc 70 tmp))))
(setq xrf (vl-list* “,” (cdr (assoc 2 tmp)) xrf))
(if xrf
(setq fil (list ‘(0 . “INSERT”) ‘(-4 . “<NOT”) (cons 2 (apply ‘strcat (cdr xrf))) ‘(-4 . “NOT>”)))
(setq fil ‘((0 . “INSERT”)))
(cond
( (null (setq all (ssget “_X” fil)))
(count:popup
“No Blocks Found” 64
(princ “No blocks were found in the active drawing.”)
( (and (= “tab” out) (= 4 (logand 4 (cdr (assoc 70 (tblsearch “layer” (getvar ‘clayer)))))))
(count:popup
“Current Layer Locked” 64
(princ “Please unlock the current layer before using this program.”)
( (progn
(setvar ‘nomutt 1)
(princ “nSelect blocks to count <all>: “)
(setq sel
(cond
( (null (setq sel (vl-catch-all-apply ‘ssget (list fil))))
all
( (null (vl-catch-all-error-p sel))
sel
(setvar ‘nomutt 0)
(null sel)
( (or (= “com” out)
(and (= “tab” out) (setq ins (getpoint “nSpecify point for table: “)))
(and (/= “tab” out)
(setq fnm
(getfiled “Create Output File”
(cond
( (and (setq dir (getenv “LMac\countdir”))
(vl-file-directory-p (setq dir (count:fixdir dir)))
(strcat dir “”)
( (getvar ‘dwgprefix))
out 1
(repeat (setq idx (sslength sel))
(setq lst (count:assoc++ (count:effectivename (ssname sel (setq idx (1- idx)))) lst))
(if (= “blk” srt)
(setq fun (eval (list ‘lambda ‘( a b ) (list (if (= “asc” ord) ‘< ‘>) ‘(strcase (car a)) ‘(strcase (car b))))))
(setq fun (eval (list ‘lambda ‘( a b ) (list (if (= “asc” ord) ‘< ‘>) ‘(cdr a) ‘(cdr b)))))
(setq lst (vl-sort lst ‘fun))
(cond
( (= “com” out)
(defun prinn ( x ) (princ “n”) (princ x))
(prinn (count:padbetween “” “” “=” 60))
(if (= “1” tg1)
(progn
(prinn ed1)
(prinn (count:padbetween “” “” “-” 60))
(prinn (count:padbetween ed3 ed4 ” ” 55))
(if (= “1” tg3)
(foreach itm lst
(prinn (count:padbetween (car itm) (itoa (cdr itm)) “.” 55))
(foreach itm lst (prinn (car itm)))
(textpage)
( (= “tab” out)
(if (= “1” tg3)
(setq lst (mapcar ‘(lambda ( x ) (list (car x) (itoa (cdr x)))) lst))
(setq lst (mapcar ‘(lambda ( x ) (list (car x))) lst))
(setq hgt
(vla-gettextheight
(vla-item
(vla-item (vla-get-dictionaries (count:acdoc)) “acad_tablestyle”)
(getvar ‘ctablestyle)
acdatarow
(setq tab
(vla-addtable
(vlax-get-property (count:acdoc) (if (= 1 (getvar ‘cvport)) ‘paperspace ‘modelspace))
(vlax-3D-point (trans ins 1 0))
(+ (length lst) 2)
(+ 1 (atoi tg2) (atoi tg3))
(* 2.5 hgt)
(* hgt
(max
(apply ‘max
(mapcar ‘strlen
(append
(if (= “1” tg2) (list ed2))
(if (= “1” tg3) (list ed4))
(cons ed3 (apply ‘append lst))
(if (= “1” tg1) (/ (strlen ed1) (+ 1 (atoi tg2) (atoi tg3))) 0)
(if (vlax-property-available-p tab ‘regeneratetablesuppressed t)
(vla-put-regeneratetablesuppressed tab :vlax-true)
(vla-put-stylename tab (getvar ‘ctablestyle))
(setq col 0)
(mapcar
‘(lambda ( a b ) (if (= “1” a) (progn (vla-settext tab 1 col b) (setq col (1+ col)))))
(list tg2 “1” tg3)
(list ed2 ed3 ed4)
(setq row 2)
(foreach itm lst
(if (= “1” tg2)
(count:setblocktablerecord tab row (setq col 0) (car itm))
(setq col -1)
(foreach txt itm
(vla-settext tab row (setq col (1+ col)) txt)
(setq row (1+ row))
(if (= “1” tg1)
(vla-settext tab 0 0 ed1)
(vla-deleterows tab 0 1)
( (setenv “LMac\countdir” (count:fixdir (vl-filename-directory fnm)))
(if
(if (= “txt” out)
count:writetxt
count:writecsv
(append
(if (= “1” tg1)
(list (list ed1))
(if (= “1” tg3)
(cons (list ed3 ed4) (mapcar ‘(lambda ( x ) (list (car x) (itoa (cdr x)))) lst))
(cons (list ed3) (mapcar ‘(lambda ( x ) (list (car x))) lst))
fnm
(princ (strcat “nBlock data written to ” fnm))
(count:popup “Unable to Create Output File” 48
(princ
(strcat
“The program was unable to create the following file:nn”
fnm
“nnPlease ensure that you have write-permissions for the above directory.”
(*error* nil)
(defun c:countsettings
*error*
dch des
ord out out-fun
srt
tg1 tg1-fun tg2 tg2-fun tg3 tg3-fun
(close des)
(if (and (= ‘int (type dch))
(< 0 dch)
(unload_dialog dch)
(progn
(cond
( (not (count:writedcl count:dclfname))
(count:popup “DCL file could not be written” 48
(princ
(strcat
“The DCL file required by this program could not be written to the following location:nn”
count:dclfname
( (<= (setq dch (load_dialog count:dclfname)) 0)
(count:popup “DCL file could not be loaded” 48
(princ
(strcat
“The following DCL file required by this program could not be loaded:nn”
count:dclfname
“nnPlease verify the integrity of this file.”
( (not (new_dialog “dia” dch))
(count:popup “DCL file contains an error” 48
(princ
(strcat
“The program dialog could not be displayed as the following DCL file file contains an error:nn”
count:dclfname
( t
(set_tile “dcl”
(strcat
“Count.lsp Version ”
(vl-string-translate “-” “.” count:version)
” \U+00A9 Lee Mac ”
(menucmd “m=$(edtime,0,yyyy)”)
(progn
(mode_tile “tab” 1)
(setq out “txt”)
( (setq tg1-fun (lambda ( val ) (mode_tile “ed1” (- 1 (atoi (setq tg1 val)))))) (set_tile “tg1” tg1))
(action_tile “tg1” “(tg1-fun $value)”)
( (setq tg2-fun (lambda ( val ) (mode_tile “ed2” (- 1 (atoi (setq tg2 val)))))) (set_tile “tg2” tg2))
(action_tile “tg2” “(tg2-fun $value)”)
( (setq tg3-fun (lambda ( val ) (mode_tile “ed4” (- 1 (atoi (setq tg3 val)))))) (set_tile “tg3” tg3))
(action_tile “tg3” “(tg3-fun $value)”)
(foreach key ‘(“ed1” “ed2” “ed3” “ed4”)
(set_tile key (eval (read key)))
(action_tile key (strcat “(setq ” key ” $value)”))
(set_tile out “1”)
( (setq out-fun
(lambda ( val )
(if (= “tab” (setq out val))
(progn
(mode_tile “tg2” 0)
(mode_tile “ed2” (- 1 (atoi tg2)))
(progn
(mode_tile “tg2” 1)
(mode_tile “ed2” 1)
out
(foreach key ‘(“tab” “txt” “csv” “com”)
(action_tile key “(out-fun $key)”)
(set_tile srt “1”)
(foreach key ‘(“blk” “qty”)
(action_tile key “(setq srt $key)”)
(set_tile ord “1”)
(foreach key ‘(“asc” “des”)
(action_tile key “(setq ord $key)”)
(if (= 1 (start_dialog))
(count:writecfg count:cfgfname (mapcar ‘eval (mapcar ‘car count:defaults)))
(*error* nil)
(defun count:popup ( ttl flg msg / err )
(setq err (vl-catch-all-apply ‘vlax-invoke-method (list (count:wsh) ‘popup msg 0 ttl flg)))
(if (null (vl-catch-all-error-p err))
err
(defun count:wsh nil
(cond (count:wshobject) ((setq count:wshobject (vlax-create-object “wscript.shell”))))
(defun count:tostring ( arg / dim )
(cond
( (= ‘int (type arg))
(itoa arg)
( (= ‘real (type arg))
(setq dim (getvar ‘dimzin))
(setvar ‘dimzin 8)
(setq arg (rtos arg 2 15))
(setvar ‘dimzin dim)
arg
( (vl-prin1-to-string arg))
(defun count:writecfg ( cfg lst / des )
(if (setq des (open cfg “w”))
(progn
(foreach itm lst (write-line (count:tostring itm) des))
(setq des (close des))
t
(defun count:readcfg ( cfg lst / des itm )
(if
(and
(setq cfg (findfile cfg))
(setq des (open cfg “r”))
(progn
(foreach sym lst
(if (setq itm (read-line des))
(set sym (read itm))
t
(defun count:writedcl ( dcl / des )
(cond
( (findfile dcl))
( (setq des (open dcl “w”))
(foreach itm
“//——————–=={ Count Dialog Definition }==——————-//”
“// Dialog definition file for use in conjunction with Count.lsp //”
“// Author: Lee Mac, Copyright ?2014 – http://www.lee-mac.com //”
“b15 : edit_box”
” edit_width = 16;”
” edit_limit = 1024;”
” fixed_width = true;”
” alignment = centered;”
” horizontal_margin = none;”
” vertical_margin = none;”
“b30 : edit_box”
” edit_width = 52;”
“tog : toggle”
” horizontal_margin = 0.2;”
“rwo : row”
“rrw : radio_row”
“dia : dialog”
” key = “dcl”;”
” spacer_1;”
” : boxed_column”
” label = “Output”;”
” : rrw”
” : radio_button { key = “tab”; label = “Table”; }”
” : radio_button { key = “txt”; label = “Text File”; }”
” : radio_button { key = “csv”; label = “CSV File”; }”
” : radio_button { key = “com”; label = “Command line”; }”
” spacer;”
” : boxed_column”
” label = “Headings”;”
” spacer_1;”
” : rwo”
” : tog { key = “tg1″; }”
” : b30 { key = “ed1″; }”
” : spacer”
” width = 2.5;”
” : rwo”
” spacer;”
” : tog { key = “tg2″; }”
” : b15 { key = “ed2″; }”
” : b15 { key = “ed3″; }”
” : b15 { key = “ed4″; }”
” : tog { key = “tg3″; }”
” spacer;”
” spacer_1;”
” : row”
” : boxed_column”
” label = “Sort By”;”
” : rrw”
” : radio_button { key = “blk”; label = “Block Name”; }”
” : radio_button { key = “qty”; label = “Quantity”; }”
” spacer;”
” : boxed_column”
” label = “Sort Order”;”
” : rrw”
” : radio_button { key = “asc”; label = “Ascending”; }”
” : radio_button { key = “des”; label = “Descending”; }”
” spacer;”
” spacer_1; ok_cancel;”
“// End of File //”
(write-line itm des)
(while (not (findfile dcl))) ;; for slow HDDs
dcl
(defun count:writecsv ( lst csv / des sep )
(if (setq des (open csv “w”))
(progn
(setq sep (cond ((vl-registry-read “HKEY_CURRENT_USER\Control Panel\International” “sList”)) (“,”)))
(foreach row lst (write-line (count:lst->csv row sep) des))
(close des)
t
(defun count:lst->csv ( lst sep )
(if (cdr lst)
(strcat (count:csv-addquotes (car lst) sep) sep (count:lst->csv (cdr lst) sep))
(defun count:csv-addquotes ( str sep / pos )
(cond
( (wcmatch str (strcat “*[`” sep “”]*”))
(setq pos 0)
(while (setq pos (vl-string-position 34 str pos))
(setq str (vl-string-subst “””” “”” str pos)
pos (+ pos 2)
(strcat “”” str “””)
( str )
(defun count:writetxt ( lst txt / des )
(if (setq des (open txt “w”))
(progn
(foreach itm lst (write-line (count:lst->str itm “t”) des))
(close des)
t
(defun count:lst->str ( lst del )
(if (cdr lst)
(strcat (car lst) del (count:lst->str (cdr lst) del))
(car lst)
(defun count:padbetween ( s1 s2 ch ln )
(lambda ( a b c )
(repeat (- ln (length b) (length c)) (setq c (cons a c)))
(vl-list->string (append b c))
(ascii ch)
(vl-string->list s1)
(vl-string->list s2)
(defun count:setblocktablerecord ( obj row col blk )
(eval
(list ‘defun ‘count:setblocktablerecord ‘( obj row col blk )
(cons
(if (vlax-method-applicable-p obj ‘setblocktablerecordid32)
‘vla-setblocktablerecordid32
(list
‘obj ‘row ‘col
(list ‘count:objectid (list ‘vla-item (vla-get-blocks (count:acdoc)) ‘blk))
‘:vlax-true
(count:setblocktablerecord obj row col blk)
(defun count:objectid ( obj )
(eval
(list ‘defun ‘count:objectid ‘( obj )
(cond
( (not (wcmatch (getenv “PROCESSOR_ARCHITECTURE”) “*64*”))
‘(vla-get-objectid obj)
( (= ‘subr (type vla-get-objectid32))
‘(vla-get-objectid32 obj)
( (list ‘vla-getobjectidstring (vla-get-utility (count:acdoc)) ‘obj ‘:vlax-false))
(count:objectid obj)
(defun count:assoc++ ( key lst / itm )
(if (setq itm (assoc key lst))
(subst (cons key (1+ (cdr itm))) itm lst)
(cons (cons key 1) lst)
(defun count:effectivename ( ent / blk rep )
(if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) “`**”)
(if
(and
(setq rep
(cdadr
(assoc -3
(entget
(cdr
(assoc 330
(entget
(tblobjname “block” blk)
‘(“AcDbBlockRepBTag”)
(setq rep (handent (cdr (assoc 1005 rep))))
(setq blk (cdr (assoc 2 (entget rep))))
blk
(defun count:startundo ( doc )
(count:endundo doc)
(vla-startundomark doc)
(defun count:endundo ( doc )
(while (= 8 (logand 8 (getvar ‘undoctl)))
(vla-endundomark doc)
(defun count:acdoc nil
(eval (list ‘defun ‘count:acdoc ‘nil (vla-get-activedocument (vlax-get-acad-object))))
(count:acdoc)
(vl-load-com)
(princ
(strcat
“n:: Count.lsp | Version ”
” | \U+00A9 Lee Mac ”
” http://www.lee-mac.com ::”
“n:: “count” – Main Program | “countsettings” – Settings ::”
;; End of File ;;
안녕하세요 위 리습을 네이버에서 다운 받았는데
정말로 좋더라고요 근데 딱하나 아쉬운게 표가 너무 작게 나와서 무조건 스케일을
키워야 하더라고요 혹시 처음부터 지금보다 표가 한 40배정도 크게 나오게 수정할 수 있을까요???
  • 278 조회
    • cadplus_plot 사용방법 질문드립니다
      2024-03-06T19:58:56+09:00답변 등록 답변 등록 일시 2024-03-06 7:58 pm
      Lee Mac 님의 Block Counter는 테이블을 작성할 때에 [현재 테이블 스타일]을 사용합니다.
      현재로 설정되어 있는 테이블 스타일을 수정한 다음 사용하세요.
      [테이블 스타일(TABLESTYLE, TS)]
      https://www.lee-mac.com/blockcounter.html
      • 조철민 Lv.0
        2024-03-07T09:42:46+09:00에게 댓글을 달았습니다. 답변 등록 일시 2024-03-07 9:42 am
        와 감사합니다!!!!!!!
