홈/ 질문/Q 25039
등록일: 2007-11-022007-11-02T10:36:54+09:00 2007-11-02T10:36:54+09:00카테고리: AutoCAD & CADian
사칙연산리습…수정부탁드려영..
다되는데..뺄셈만오류가나네여..전혀 모르겠어영..ㅠㅠ
그리고혹쉬…레이어 지정해준 문꾸도 없애준다면..더더욱고맙고요..없앴더니..나누기가안돼드라고여…
(defun exe_1()
(setvar “cmdecho” 0)
(setvar “blipmode” 0)
(setq cl (getvar “clayer”))
(setq e1 (entsel “n>>첫번째숫자선택:”))
(setq a (car e1);;———-엔티티의 이름값
b (entget a);;——–엔티티의 리스트값
txt1 (assoc 1 b);;—-엔티티중 해당 문자열 리스트
tt1 (cdr txt1);;——엔티티 문자열의 리스트중 뒤의값=”문자열”
sum1 (atof tt1);;—–엔티티의 문자열을 정수로 변환=100
txth1 (assoc 40 b);;–엔티티 리스트중 텍스트 높이의 리스트값(40,100)
thh (cdr txth1);;—–엔티티의 텍스트높이의 리스트중 뒤의값=100
(setq e2 (entsel “n>>두번째숫자선택:”))
(setq aa (car e2)
bb (entget aa)
txt2 (assoc 1 bb)
tt2 (cdr txt2)
sum2 (atof tt2)
(setq tl (assoc 8 b)
txtst (cdr tl)
;;(defun exe+()
;; (setq sum (+ sum1 sum2))
;; (setq summ (rtos sum 2 3))
;; (setq p1 (getpoint “n>>표시할 포인트찍기:”))
;; (command “layer” “s” “0” “” “”)
;; (command “text” p1 thh 0 summ)
;; (command “layer” “s” cl “”)
;;(defun exe-()
;; (setq sum (- sum1 sum2))
(defun exe*()
(setq sum (* sum1 sum2))
(defun exe/()
(setq sum (/ sum1 sum2))
(defun exe%()
(setq sum (* (/ sum1 sum2) 100))
(defun c:+( / cl e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe+)
(defun c:-( / cl e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe-)
(defun c:*( / cl e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe*)
(defun c:/( / cl e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe/)
(defun c:%( / cl e1 a b txt1 tt1 sum1 txth1 thh e2 aa bb txt2 tt2 sum2 tl txtst sum summ p1)
(exe_1)
(exe%)
(defun c:py( / cl e1 a b txt1 tt1 sum1 txth1 thh sum summ p1 )
(setq e1 (entsel “n>>숫자선택:”))
(setq sum (* sum1 0.3025))
(setq zz (strcat “(” summ “)”))
(command “text” p1 thh 0 zz)
(defun c:+( / cl sum_m ss ok e ent sum_ p1 txth1 thh summ )
(setq sum_m 0)
(setq SS (ssget))
(setq ok 0)
(while
(setq e (ssname ss ok))
(setq ent (entget e))
(setq sum_ (assoc 1 ent))
(setq sum_ (cdr sum_))
(setq sum_ (atof sum_))
(setq sum_m (+ sum_m sum_))
(setq ok (1+ ok))
(setq txth1 (assoc 40 ent))
(setq thh (cdr txth1))
(setq summ (rtos sum_m 2 3))
(defun c:*( / cl sum_m ss ok e ent sum_ p1 txth1 thh summ )
(setq sum_m 1)
(setq SS (ssget))
(setq ok 0)
(while
(setq sum_m (* sum_m sum_))
(setq ok (1+ ok))
(princ “n>>사칙연산 프로그램 로딩완료 command : +,-,*,/,%,py,++,**”)
  • 14 조회
    • cadplus_plot 사용방법 질문드립니다
    • 캐드 좌표값을 위경도값으로 산출 가능할까요?
