홈/ 질문/Q 110769
열나게
열나게Lv.0
등록일: 2018-12-272018-12-27T10:56:51+09:00 2018-12-27T10:56:51+09:00카테고리: AutoCAD & CADian
석축및 옹벽 표시 리습
현재 사용중인 옹벽, 석축  표시 리습입니다. line 일때만 적용이 되구요
폴리선으로 했을떄 리습이 적용 되는지 부탁드립니다.
(defun c:ss ()
  (setq os-mode (getvar “osmode”))
  (setvar “osmode” 0)
  (sub-sug)
  (command “pline” xpol3 xpol2 xpol1 po1 xpor1 xpor2 xpor3 “”)
  (setvar “osmode” os-mode)
  (prin1)
(defun c:oo ()
  (setvar “osmode” 0)
  (sub-sug)
  (command “pline” xpol2 xpol1 po1 xpor1 xpor2 “”)
  (sub-ong)
  (command “pline” ypol2 ypol1 po2 ypor1 ypor2 “”)
  (prin1)
(defun c:hz ()
  (setvar “osmode” 512)
  (hz-sub)
  (prin1)
(defun hz-sub ()
  (setq a_0 (entsel “n Select Object Pick *1*”))
  (setq a_a (car a_0))
  (setq x_po (car (cdr a_0)))
  (setq a_b (entget a_a))
  (setq a_c10 (cdr (assoc 10 a_b)))
  (setq a_c11 (cdr (assoc 11 a_b)))
  (setq 10_x (car a_c10))
  (setq 10_y (car (cdr a_c10)))
  (setq 10_z (car (reverse a_c10)))
  (setq 11_x (car a_c11))
  (setq 11_y (car (cdr a_c11)))
  (setq 11_z (car (reverse a_c11)))
  (setq n-ac10 (list 10_x 10_y 0.0))
  (setq n-ac11 (list 11_x 11_y 0.0))
  (setq a_an (angle n-ac10 n-ac11))
  (setq g-po (polar x_po (+ a_an (* pi 0.5)) 100))
  (setq po1 (inters g-po x_po n-ac10 n-ac11 nil))
  (setq di1 (distance n-ac10 po1))
  (setq di2 (distance n-ac11 po1))
  (setq di (distance n-ac10 n-ac11))
  (if (> 10_z 11_z)
    (progn
      (setq z (- 10_z 11_z))
      (setq new_z (rtos (+ (* (/ di2 di) z) 11_z) 2 2))
    (progn
      (setq z (- 11_z 10_z))
      (setq new_z (rtos (+ (* (/ di1 di) z) 10_z) 2 2))
  (command “text” po1 1.205 0 new_z “”)
(DEFUN sub-sug ()
  (setq a_an (angle a_c10 a_c11))
  (setq po1 (inters g-po x_po a_c10 a_c11 nil))
  (setq b_a (car (entsel “n Select Object Pick *2*”)))
  (setq b_b (entget b_a))
  (setq b_c10 (cdr (assoc 10 b_b)))
  (setq b_c11 (cdr (assoc 11 b_b)))
  (setq po2 (inters x_po g-po b_c10 b_c11 nil))
  (setq an (angle po1 po2))
  (setq di (distance po1 po2))
  (setq xpol (polar po1 (+ an (* pi 0.25)) 10))
  (setq xpor (polar po1 (- an (* pi 0.25)) 10))
  (setq xpol1 (inters po1 xpol b_c10 b_c11 nil))
  (setq xpor1 (inters po1 xpor b_c10 b_c11 nil))
  (setq xpol (polar xpol1 (+ an (* pi 0.75)) 10))
  (setq xpor (polar xpor1 (- an (* pi 0.75)) 10))
  (setq xpol2 (inters xpol1 xpol a_c10 a_c11 nil))
  (setq xpor2 (inters xpor1 xpor a_c10 a_c11 nil))
  (setq xpol (polar xpol2 (+ an (* pi 0.25)) 10))
  (setq xpor (polar xpor2 (- an (* pi 0.25)) 10))
  (setq xpol3 (inters xpol2 xpol b_c10 b_c11 nil))
  (setq xpor3 (inters xpor2 xpor b_c10 b_c11 nil))
(defun sub-ong ()
  (setq xpol (polar xpol3 (+ an pi) 10))
  (setq ypol3 (inters xpol3 xpol a_c10 a_c11 nil))
  (setq xpol (polar xpol2 an 10))
  (setq ypol2 (inters xpol2 xpol b_c10 b_c11 nil))
  (setq xpol (polar xpol1 (+ an pi) 10))
  (setq ypol1 (inters xpol1 xpol a_c10 a_c11 nil))
  (setq xpor (polar xpor1 (+ an pi) 10))
  (setq ypor1 (inters xpor1 xpor a_c10 a_c11 nil))
  (setq xpor (polar xpor2 an 10))
  (setq ypor2 (inters xpor2 xpor b_c10 b_c11 nil))
  (setq xpor (polar xpor3 (+ an pi) 10))
  (setq ypor3 (inters xpor3 xpor a_c10 a_c11 nil))
  • 199 조회
