홈/ 질문/Q 96519
등록일: 2012-10-312012-10-31T19:13:05+09:00 2012-10-31T19:13:05+09:00카테고리: AutoCAD & CADian
선굵기를 어떻게 지정할까요?
이것저것 참조해서 명령어 하나로 자동으로 레이어를 만들어 주는 리습을 만들었습니다.
이 리습에 선굵기도 자동으로 정하게 하고 싶은데 어떻게 해야할지를 모르겠네요..
고수님들 도와주세요….
(defun c:000()
 (setvar   “cmdecho” 0)
 (if (= (tblsearch “layer” “COL”) nil)
     ;layer 1 이 있는지 없는지 확인 없으면 만든다.
     (command “layer” “m” “COL” “c” “2” “” “lt” “continuous” “” “”))
     ;            레이어이름    레이어색상      레이어선종류
 (if (= (tblsearch “layer” “ss-point”) nil)
     (command “layer” “m” “ss-point” “c” “1” “” “lt” “CENTER” “” “”))
 (if (= (tblsearch “layer” “ss-text”) nil)
     (command “layer” “m” “ss-text” “c” “2” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “ss-ed”) nil)
     (command “layer” “m” “ss-ed” “c” “3” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “ss-rlrg”) nil)
     (command “layer” “m” “ss-rlrg” “c” “4” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “ss-dim”) nil)
     (command “layer” “m” “ss-dim” “c” “5” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “ss-eq”) nil)
     (command “layer” “m” “ss-eq” “c” “6” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “ss-분기관”) nil)
     (command “layer” “m” “ss-분기관” “c” “7” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “ss-back”) nil)
     (command “layer” “m” “ss-back” “c” “8” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “HS-행거”) nil)
     (command “layer” “m” “HS-행거” “c” “60” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “HS-동부속”) nil)
     (command “layer” “m” “HS동부속” “c” “61” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “HS-PVC부속”) nil)
     (command “layer” “m” “HS-PVC부속” “c” “62” “” “lt” “continuous” “” “”))
 (if (= (tblsearch “layer” “HS-치수”) nil)
     (command “layer” “m” “HS-치수” “c” “11” “” “lt” “continuous” “” “”))
(defun c:0()
  (ssget)
  (command”LAYER” “S” “0” “”)
  ;현재 레이어를 0 레이어로 바꾼다.
  (command “chprop” “p” “” “la” “0” “”)
(defun c:1()
  (ssget)
  (command”LAYER” “S” “ss-point” “”)
  (command “chprop” “p” “” “la” “ss-point” “”)
(defun c:2()
  (ssget)
  (command”LAYER” “S” “ss-text” “”)
  (command “chprop” “p” “” “la” “ss-text” “”)
(defun c:3()
  (ssget)
  (command”LAYER” “S” “ss-ed” “”)
  (command “chprop” “p” “” “la” “ss-ed” “”)
(defun c:4()
  (ssget)
  (command”LAYER” “S” “ss-rlrg” “”)
  (command “chprop” “p” “” “la” “ss-rlrg” “”)
(defun c:5()
  (ssget)
  (command”LAYER” “S” “ss-dim” “”)
  (command “chprop” “p” “” “la” “ss-dim” “”)
(defun c:6()
  (ssget)
  (command”LAYER” “S” “ss-eq” “”)
  (command “chprop” “p” “” “la” “ss-eq” “”)
(defun c:7()
  (ssget)
  (command”LAYER” “S” “ss-분기관” “”)
  (command “chprop” “p” “” “la” “”ss-분기관””)
(defun c:8()
  (ssget)
  (command”LAYER” “S” “ss-back” “”)
  (command “chprop” “p” “” “la” “ss-back” “”)
(defun c:60()
  (ssget)
  (command”LAYER” “S” “HS-행거” “”)
  (command “chprop” “p” “” “la” “HS-행거” “”)
(defun c:61()
  (ssget)
  (command”LAYER” “S” “HS-동부속” “”)
  (command “chprop” “p” “” “la” “HS-동부속” “”)
(defun c:62()
  (ssget)
  (command”LAYER” “S” “HS-PVC부속” “”)
  (command “chprop” “p” “” “la” “HS-PVC부속” “”)
(defun c:63()
  (ssget)
  (command”LAYER” “S” “HS-치수” “”)
  (command “chprop” “p” “” “la” “HS-치수” “”)
  • 30 조회
