시작점은 스냅 명령이 잡히는데 마지막점 선택시 스냅이 잡히질 않습니다…고수님들 수정부탁드립니다.
(defun c:DPA (/ DrawEndArrowHead DrawStartArrowHead ActDoc CurSpc Dist ArSty Pt PtList StList Ang EndList
PtList+ PtList- oPt nPt tempPt oAng oAng+ oAng- oPt+ oPt- nPt+ nPt- cAng cAng+ cAng-
tempPt+ tempPt- ntemp+ ntemp- Pt+ Pt- PolyPtList *error* AlignX AlignY AlignZ DistX DistY DistZ)
; Draw a polyline arrow, now shown as you move the cursor
(defun *error* (msg)
;(vl-bt)
(redraw)
(prompt (strcat “n Error-> ” msg))
(defun GetCurrentSpace (Doc / BlkCol SpaceList CurSpace ActSpace temp1)
; Returns the “block object” for the active space
; Thanks to Jeff Mishler
(if (= (getvar “cvport”) 1)
(vla-get-PaperSpace Doc)
(vla-get-ModelSpace Doc)
(defun AlignX (pt1 pt2)
(list
(car pt1)
(cadr pt2)
(caddr pt2)
(defun AlignY (pt1 pt2)
(list
(car pt2)
(cadr pt1)
(caddr pt2)
(defun AlignZ (pt1 pt2)
(list
(car pt2)
(cadr pt2)
(caddr pt1)
(defun DrawEndArrowHead (Stpt CurPt ArrHeadDist ReturnPoints / Ang -Ang tempPt Ang+ Ang- Pt+ Pt-)
(setq Ang (angle StPt CurPt))
(setq -Ang (rem (+ Ang pi) (* pi 2.0)))
(setq tempPt (polar CurPt -Ang (* ArrHeadDist 2.0)))
(setq Ang+ (rem (+ Ang (* pi 0.5)) (* pi 2.0)))
(setq Ang- (rem (+ Ang (* pi 1.5)) (* pi 2.0)))
(setq Pt+ (polar tempPt Ang+ (* ArrHeadDist 0.5)))
(setq Pt- (polar tempPt Ang- (* ArrHeadDist 0.5)))
(grvecs
(list
1 Pt+ (polar Pt+ Ang+ (* ArrHeadDist 0.5))
1 (polar Pt+ Ang+ (* ArrHeadDist 0.5)) CurPt
1 CurPt (polar Pt- Ang- (* ArrHeadDist 0.5))
1 (polar Pt- Ang- (* ArrHeadDist 0.5)) Pt-
(if ReturnPoints
(list
CurPt
(list Pt+ Pt-)
(defun DrawStartArrowHead (StPt CurPt ArrHeadDist ReturnPoints / Ang -Ang tempPt Ang+ Ang- Pt+ Pt- Pt+2 Pt-2)
(setq Ang (angle CurPt StPt))
(setq tempPt (polar StPt -Ang (* ArrHeadDist 2.0)))
(grvecs
(list
1 (polar Pt+ Ang+ (* ArrHeadDist 0.5)) StPt
1 StPt (polar Pt- Ang- (* ArrHeadDist 0.5))
(if ReturnPoints
(list
StPt
(list Pt- Pt+)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vla-EndUndoMark ActDoc)
(vla-StartUndoMark ActDoc)
(setq CurSpc (GetCurrentSpace ActDoc))
(initget “Single Double”)
(setq Dist (getdist “n Enter width [<Single>/Double arrow head]: “))
(if (= (type Dist) ‘STR)
(progn
(setq ArSty Dist)
(setq Dist (getdist “n Enter width: “))
(setq ArSty “Single”)
(setq Pt (getpoint “n Select starting point: “))
(setq PtList (list Pt))
(while
(and
PtList
Pt
ArSty
Dist
(not (prompt “r Select next point [right click to exit / Undo]: “))
(not (vl-position (car (setq tempList (grread T 0))) ‘(11 25)))
(cond
((equal (car tempList) 2)
(cond
((equal (cadr tempList) 15)
(setvar “orthomode” (abs (1- (getvar “orthomode”))))
((and (> (length PtList) 1) (vl-position (cadr tempList) ‘(85 117)))
(setq PtList (cdr PtList))
(setq PtList+ (cdr PtList+))
(setq PtList- (cdr PtList-))
(redraw)
(if (= ArSty “Double”)
(DrawStartArrowHead (last PtList) (nth (- (length PtList) 2) PtList) Dist nil)
(grdraw (car StList) (cadr StList) 1)
(setq EndList (DrawEndArrowHead (car PtList) (polar tempPt cAng (* Dist 2.0)) Dist nil))
(setq cnt 0)
(while (< (1+ cnt) (length PtList+))
(grdraw (nth cnt PtList+) (nth (1+ cnt) PtList+) 1)
(grdraw (nth cnt PtList-) (nth (1+ cnt) PtList-) 1)
(setq cnt (1+ cnt))
(t (print tempList))
((and (equal (length PtList) 1) (or (equal (car tempList) 5) (equal (car tempList) 3)))
(setq tempPt (cadr tempList))
(setq DistX (abs (- (car Pt) (car tempPt))))
(setq DistY (abs (- (cadr Pt) (cadr tempPt))))
(setq DistZ (abs (- (caddr Pt) (caddr tempPt))))
(if (equal (getvar “orthomode”) 1)
(setq tempPt
(cond
((and (> DistX DistY) (> DistX DistZ))
(AlignY Pt tempPt)
((and (> DistY DistZ) (> DistY DistX))
(AlignX Pt tempPt)
((and (> DistZ DistX) (> DistZ DistY))
(AlignZ Pt tempPt)
(if (and tempPt (not (equal Pt tempPt 0.0001)))
(progn
(setq StList (DrawStartArrowHead Pt tempPt Dist nil))
(progn
(setq Ang (angle Pt tempPt))
(setq StList
(list
(polar Pt (rem (+ Ang (* pi 0.5)) (* pi 2.0)) (* Dist 0.5))
(polar Pt (rem (+ Ang (* pi 1.5)) (* pi 2.0)) (* Dist 0.5))
(cond
((equal (car tempList) 5)
(redraw)
(setq EndList (DrawEndArrowHead Pt tempPt Dist nil))
(grdraw (car StList) (car EndList) 1)
(grdraw (cadr StList) (cadr EndList) 1)
((equal (car tempList) 3)
(setq PtList+ (cons (car StList) PtList+))
(setq PtList- (cons (cadr StList) PtList-))
(setq PtList (cons tempPt PtList))
((and (> (length PtList) 1) (or (equal (car tempList) 5) (equal (car tempList) 3)))
(setq oPt (cadr PtList))
(setq nPt (car PtList))
(setq DistX (abs (- (car nPt) (car tempPt))))
(setq DistY (abs (- (cadr nPt) (cadr tempPt))))
(setq DistZ (abs (- (caddr nPt) (caddr tempPt))))
(setq tempPt
(cond
(AlignY nPt tempPt)
(AlignX nPt tempPt)
(AlignZ nPt tempPt)
(if (and tempPt (not (equal nPt tempPt 0.0001)))
(progn
(setq StList (DrawStartArrowHead (last PtList) (nth (- (length PtList) 2) PtList) Dist nil))
(progn
(setq Ang (angle (last PtList) (nth (- (length PtList) 2) PtList)))
(setq StList
(list
(polar (last PtList) (rem (+ Ang (* pi 0.5)) (* pi 2.0)) (* Dist 0.5))
(polar (last PtList) (rem (+ Ang (* pi 1.5)) (* pi 2.0)) (* Dist 0.5))
(setq oAng (angle oPt nPt))
(setq oAng+ (rem (+ oAng (* pi 0.5)) (* pi 2.0)))
(setq oAng- (rem (+ oAng (* pi 1.5)) (* pi 2.0)))
(setq oPt+ (polar oPt oAng+ (* Dist 0.5)))
(setq oPt- (polar oPt oAng- (* Dist 0.5)))
(setq nPt+ (polar nPt oAng+ (* Dist 0.5)))
(setq nPt- (polar nPt oAng- (* Dist 0.5)))
(setq cAng (angle nPt tempPt))
(setq cAng+ (rem (+ cAng (* pi 0.5)) (* pi 2.0)))
(setq cAng- (rem (+ cAng (* pi 1.5)) (* pi 2.0)))
(if (equal (car tempList) 5)
(setq tempPt (polar tempPt (rem (+ cAng pi) (* pi 2.0)) (* Dist 2.0)))
(setq tempPt+ (polar tempPt cAng+ (* Dist 0.5)))
(setq tempPt- (polar tempPt cAng- (* Dist 0.5)))
(setq ntempPt+ (polar nPt cAng+ (* Dist 0.5)))
(setq ntempPt- (polar nPt cAng- (* Dist 0.5)))
(setq Pt+ (inters oPt+ nPt+ ntempPt+ tempPt+ nil))
(setq Pt- (inters oPt- nPt- ntempPt- tempPt- nil))
(if (and Pt+ Pt-)
(cond
(redraw)
(setq cnt 0)
(setq cnt (1+ cnt))
(grvecs
(list
1 (car PtList+) Pt+
1 Pt+ tempPt+
1 tempPt- Pt-
1 Pt- (car PtList-)
(setq PtList+ (cons Pt+ PtList+))
(setq PtList- (cons Pt- PtList-))
(if (> (length PtList) 1)
(progn
(setq EndList (DrawEndArrowHead (cadr PtList) (car PtList) Dist nil))
(setq PtList+ (cons (car EndList) PtList+))
(setq PtList- (cons (cadr EndList) PtList-))
(setq EndPtList (DrawEndArrowHead (cadr PtList) (car PtList) Dist T))
(progn
(setq StPtList (DrawStartArrowHead (last PtList) (nth (- (length PtList) 2) PtList) Dist T))
(setq tempPtList (append StPtList (append (reverse PtList+) (append EndPtList PtList-))))
(setq tempPtList (append (reverse PtList+) (append EndPtList PtList-)))
(foreach Pt (mapcar ‘(lambda (x) (trans x 1 0)) tempPtList)
(setq PolyPtList (cons (car Pt) PolyPtList))
(setq PolyPtList (cons (cadr Pt) PolyPtList))
(vla-put-Closed (vlax-invoke CurSpc ‘AddLightWeightPolyline (reverse PolyPtList)) :vlax-true)
(redraw)
