홈/ 질문/Q 105676
등록일: 2015-12-142015-12-14T10:02:08+09:00 2015-12-14T10:02:08+09:00카테고리: AutoCAD & CADian
안녕하세요. 리습좀봐주세요ㅠㅠ 레이어관련
생성하는거 찾아서 글 수정했었는데 꼭 이걸써야하네요ㅠㅠ
치수도 포함되있는 리습인가봐요ㅠㅠ
단축키만 바꾸면되는줄알았는데
ㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠ
첨부파일처럼, 빨간색밑줄부분 레이어로생성,
단축키는 C1 C2 C3 HH PP 이런식으로 바꾸고싶어요
저기 아래 LP, SP 이런거는 없어도 되는데
너무어려워요 도와주세요ㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠㅠ
길어서 죄송합니다 뭘 지워야할지몰라서요ㅠㅠ
(defun c:TE() (if (= nil (tblsearch “layer” “0”))
                (princ “nNot Layer”)
                (progn (command “layer” “s” “0”  “”)(princ “nCurrent Layer Setting—>TE”))
(princ))
(defun c:LP() (if (= nil (tblsearch “layer” “LP”))
                (progn (command “layer” “s” “LP” “”)(princ “nCurrent Layer Setting—>LP”))
(princ))
(defun c:SP() (if (= nil (tblsearch “layer” “SP”))
                (progn (command “layer” “s” “SP” “”)(princ “nCurrent Layer Setting—>SP”))
(princ))
(defun c:FT() (if (= nil (tblsearch “layer” “FT”))
                (progn (command “layer” “s” “FT” “”)(princ “nCurrent Layer Setting—>FT”))
(princ))
(defun c:DM() (if (= nil (tblsearch “layer” “DM”))
                (progn (command “layer” “s” “DM” “”)(princ “nCurrent Layer Setting—>DM”))
(princ))
(defun c:CE() (if (= nil (tblsearch “layer” “CE”))
                (progn (command “layer” “s” “CE” “”)(princ “nCurrent Layer Setting—>CE”))
(princ))
(defun c:PH() (if (= nil (tblsearch “layer” “PH”))
                (progn (command “layer” “s” “PH” “”)(princ “nCurrent Layer Setting—>PH”))
(princ))
(defun c:EQ() (if (= nil (tblsearch “layer” “EQ”))
                (progn (command “layer” “s” “EQ” “”)(princ “nCurrent Layer Setting—>EQ”))
(princ))
(defun c:AS() (if (= nil (tblsearch “layer” “AS”))
                (progn (command “layer” “s” “AS” “”)(princ “nCurrent Layer Setting—>AS”))
(princ))
(defun c:CV() (if (= nil (tblsearch “layer” “CV”))
                (progn (command “layer” “s” “CV” “”)(princ “nCurrent Layer Setting—>CV”))
(princ))
(defun c:DU() (if (= nil (tblsearch “layer” “DU”))
                (progn (command “layer” “s” “DU” “”)(princ “nCurrent Layer Setting—>DU”))
(princ))
(defun c:EL() (if (= nil (tblsearch “layer” “EL”))
                (progn (command “layer” “s” “EL” “”)(princ “nCurrent Layer Setting—>EL”))
(princ))
(defun c:L1() (if (= nil (tblsearch “layer” “L1”))
                (progn (command “layer” “s” “L1” “”)(princ “nCurrent Layer Setting—>L1”))
(princ))
(defun c:L2() (if (= nil (tblsearch “layer” “L2”))
                (progn (command “layer” “s” “L2” “”)(princ “nCurrent Layer Setting—>L2”))
(princ))
(defun c:L3() (if (= nil (tblsearch “layer” “L3”))
                (progn (command “layer” “s” “L3” “”)(princ “nCurrent Layer Setting—>L3”))
(princ))
(defun c:L4() (if (= nil (tblsearch “layer” “L4”))
                (progn (command “layer” “s” “L4” “”)(princ “nCurrent Layer Setting—>L4”))
(princ))
(defun c:L5() (if (= nil (tblsearch “layer” “L5”))
                (progn (command “layer” “s” “L5” “”)(princ “nCurrent Layer Setting—>L5”))
(princ))
(defun c:L6() (if (= nil (tblsearch “layer” “L6”))
                (progn (command “layer” “s” “L6” “”)(princ “nCurrent Layer Setting—>L6”))
(princ))
(defun c:L7() (if (= nil (tblsearch “layer” “L7”))
                (progn (command “layer” “s” “L7” “”)(princ “nCurrent Layer Setting—>L7”))
(princ))
(defun c:L8() (if (= nil (tblsearch “layer” “L8”))
                (progn (command “layer” “s” “L8” “”)(princ “nCurrent Layer Setting—>L8”))
(princ))
(defun c:L9() (if (= nil (tblsearch “layer” “L9”))
                (progn (command “layer” “s” “L9” “”)(princ “nCurrent Layer Setting—>L9”))
(princ))
(defun c:S1() (if (= nil (tblsearch “layer” “S1”))
                (progn (command “layer” “s” “S1” “”)(princ “nCurrent Layer Setting—>S1”))
(princ))
(defun c:S2() (if (= nil (tblsearch “layer” “S2”))
                (progn (command “layer” “s” “S2” “”)(princ “nCurrent Layer Setting—>S2”))
(princ))
(defun c:S3() (if (= nil (tblsearch “layer” “S3”))
                (progn (command “layer” “s” “S3” “”)(princ “nCurrent Layer Setting—>S3”))
(princ))
(defun c:S4() (if (= nil (tblsearch “layer” “S4”))
                (progn (command “layer” “s” “S4” “”)(princ “nCurrent Layer Setting—>S4”))
(princ))
(defun c:S5() (if (= nil (tblsearch “layer” “S5”))
                (progn (command “layer” “s” “S5” “”)(princ “nCurrent Layer Setting—>S5”))
(princ))
(defun c:S6() (if (= nil (tblsearch “layer” “S6”))
                (progn (command “layer” “s” “S6” “”)(princ “nCurrent Layer Setting—>S6”))
(princ))
(defun c:S7() (if (= nil (tblsearch “layer” “S7”))
                (progn (command “layer” “s” “S7” “”)(princ “nCurrent Layer Setting—>S7”))
(princ))
(defun c:S8() (if (= nil (tblsearch “layer” “S8”))
                (progn (command “layer” “s” “S8” “”)(princ “nCurrent Layer Setting—>S8”))
(princ))
(defun c:S9() (if (= nil (tblsearch “layer” “S9”))
                (progn (command “layer” “s” “S9” “”)(princ “nCurrent Layer Setting—>S9”))
(princ))
(defun c:LATT() (if (= nil (tblsearch “layer” “ATT”))
                (progn (command “layer” “s” “ATT” “”)(princ “nCurrent Layer Setting—>ATT”))
(princ))
(defun C-LA()
  (setvar “clayer” cla) (princ))
(defun L-C-C()
  (command “chprop” (entlast) “” “la” “CE” “lt” “CONTINUOUS” “”))
(defun L-C-1()
  (command “chprop” (entlast) “” “la” “CE” “lt” “c-1” “”))
(defun L-C-2()
  (command “chprop” (entlast) “” “la” “CE” “lt” “c-2” “”))
(defun L-C-3()
  (command “chprop” (entlast) “” “la” “CE” “lt” “c-3” “”))
(defun L-C-4()
  (command “chprop” (entlast) “” “la” “CE” “lt” “c-4” “”))
(defun L-C-5()
  (command “chprop” (entlast) “” “la” “CE” “lt” “c-5” “”))
(defun L-H-1()
  (command “chprop” (entlast) “” “lt” “h-1” “”))
(defun L-H-2()
  (command “chprop” (entlast) “” “lt” “h-2” “”))
(defun L-H-3()
  (command “chprop” (entlast) “” “lt” “h-3” “”))
(defun L-H-4()
  (command “chprop” (entlast) “” “lt” “h-4” “”))
(defun L-H-5()
  (command “chprop” (entlast) “” “lt” “h-5” “”))
(defun L-P-1()
  (command “chprop” (entlast) “” “la” “PH” “lt” “p-1” “”))
(defun L-P-2()
  (command “chprop” (entlast) “” “la” “PH” “lt” “p-2” “”))
(defun L-P-3()
  (command “chprop” (entlast) “” “la” “PH” “lt” “p-3” “”))
(defun L-P-4()
  (command “chprop” (entlast) “” “la” “PH” “lt” “p-4” “”))
(defun L-P-5()
  (command “chprop” (entlast) “” “la” “PH” “lt” “p-5” “”))
(defun L-P-6()
  (command “chprop” (entlast) “” “la” “PH” “lt” “p-6” “”))
(defun L-P-7()
  (command “chprop” (entlast) “” “la” “PH” “lt” “p-7” “”))
(defun L-LP()
  (command “chprop” (entlast) “” “la” “LP” “lt” “BYLAYER” “”))
(defun L-SP()
  (command “chprop” (entlast) “” “la” “SP” “lt” “BYLAYER” “”))
(defun L-FT()
  (command “chprop” (entlast) “” “la” “FT” “lt” “BYLAYER” “”))
(defun L-EQ()
  (command “chprop” (entlast) “” “la” “EQ” “lt” “BYLAYER” “”))
(defun LA-1()  (if (= kid_ “SM”) (C:SP) (C:LP)))
(defun LA-2()  (if (= kid_ “SM”) (C:FT) (C:SP)))
(defun C:TT()
   (princ “nChange layer : 0<White, Text>”)(ssget)
   (command “chprop” “p” “” “la” “0” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:LL()
   (princ “nChange layer : LP<Large Pipe>”)(ssget)
   (command “chprop” “p” “” “la” “LP” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:SS()
   (princ “nChange layer : SP<Small Pipe>”)(ssget)
   (command “chprop” “P” “” “la” “SP” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:FF()
   (princ “nChange layer : FT<Fitting(Symbol)>”)(ssget)
   (command “chprop” “p” “” “la” “FT” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:EE()
   (princ “nChange layer : EQ<Equipment>”)(ssget)
   (command “chprop” “p” “” “la” “EQ” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:AA()
   (princ “nChange layer : AS<Architecture>”)(ssget)
   (command “chprop” “p” “” “la” “AS” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:VV()
   (princ “nChange layer : CV<Civil>”)(ssget)
   (command “chprop” “p” “” “la” “CV” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:DDU()
   (princ “nChange layer : DU<Duct>”)(ssget)
   (command “chprop” “p” “” “la” “DU” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:EEL()
   (princ “nChange layer : EL<Electric>”)(ssget)
   (command “chprop” “p” “” “la” “EL” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:DD()
   (princ “nChange layer : DM<White, Dimension>”)(ssget)
   (command “chprop” “p” “” “la” “DM” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun c:CC (/ siz ltype)
   (princ “nChange layer : CE<Red, Center>”)(ssget)
   (setq siz(strcase(getstring “nc-1/c-2/c-3/c-4/c-5/Continuous/<c-2> : “)))
   (cond ((= siz “1”) (setq ltype “c-1”))
         ((= siz “2”) (setq ltype “c-2”))
         ((= siz “3”) (setq ltype “c-3”))
         ((= siz “4”) (setq ltype “c-4”))
         ((= siz “5”) (setq ltype “c-5”))
         ((= siz “C”) (setq ltype “continuous”))
         ((= siz “” ) (setq ltype “c-2”)) (t nil)
   (command “chprop” “P” “” “la” “CE” “lt” ltype “c” “bylayer” “”)
   (princ))
(defun c:PP (/ siz ltype)
   (princ “nChange layer : PH<Red, Phantom>”)(ssget)
   (setq siz(strcase(getstring “np-1/p-2/p-3/p-4/p-5/p-6/p-7/Continuous/<p-4> : “)))
   (cond ((= siz “1”) (setq ltype “p-1”))
         ((= siz “2”) (setq ltype “p-2”))
         ((= siz “3”) (setq ltype “p-3”))
         ((= siz “4”) (setq ltype “p-4”))
         ((= siz “5”) (setq ltype “p-5”))
         ((= siz “6”) (setq ltype “p-6”))
         ((= siz “7”) (setq ltype “p-7”))
         ((= siz “” ) (setq ltype “p-4”)) (t nil)
   (command “chprop” “P” “” “la” “PH” “lt” ltype “c” “bylayer” “”)
   (princ))
(defun c:HH (/ siz ltype)
   (princ “nChange layer : Bylayer<Bylayer, Hidden>”)(ssget)
   (setq siz(strcase(getstring “nh-1/h-2/h-3/h-4/h-5/<h-3> : “)))
   (cond ((= siz “1”) (setq ltype “h-1”))
         ((= siz “2”) (setq ltype “h-2”))
         ((= siz “3”) (setq ltype “h-3”))
         ((= siz “4”) (setq ltype “h-4”))
         ((= siz “5”) (setq ltype “h-5”))
         ((= siz “” ) (setq ltype “h-3”)) (t nil)
   (command “chprop” “P” “” “lt” ltype “”)
   (princ))
(defun c:GCC (/ siz ltype)
   (princ “nChange layer : Bylayer<Bylayer, Center>”)(ssget)
   (command “chprop” “P” “” “c” “1””lt” ltype “”)
   (princ))
(defun c:GPP (/ siz ltype)
   (princ “nChange layer : Bylayer<Bylayer, Phantom>”)(ssget)
   (setq siz(strcase(getstring “np-1/p-2/p-3/p-4/p-5/p-6/p-7/Continuous/<p-5> : “)))
         ((= siz “” ) (setq ltype “p-5”)) (t nil)
   (command “chprop” “P” “” “c” “1” “lt” ltype “”)
;   (command “chprop” “P” “” “lt” ltype “”)
   (princ))
(defun c:ECC (/ siz ltype)
   (princ))
(defun c:EPP (/ siz ltype)
   (princ))
(defun C:L11()
   (princ “nChange layer : L1<Red>”)(ssget)
   (command “chprop” “p” “” “la” “L1” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:L22()
   (princ “nChange layer : L2<Yellow>”)(ssget)
   (command “chprop” “p” “” “la” “L2” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:L33()
   (princ “nChange layer : L3<Green>”)(ssget)
   (command “chprop” “p” “” “la” “L3” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:L44()
   (princ “nChange layer : L4<Cyan>”)(ssget)
   (command “chprop” “p” “” “la” “L4” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:L55()
   (princ “nChange layer : L5<Blue>”)(ssget)
   (command “chprop” “p” “” “la” “L5” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:L66()
   (princ “nChange layer : L6<Magenta>”)(ssget)
   (command “chprop” “p” “” “la” “L6” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:L77()
   (princ “nChange layer : L7<White>”)(ssget)
   (command “chprop” “p” “” “la” “L7” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:L88()
   (princ “nChange layer : L8<Dark Gray>”)(ssget)
   (command “chprop” “p” “” “la” “L8” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:L99()
   (princ “nChange layer : L9<Gray>”)(ssget)
   (command “chprop” “p” “” “la” “L9” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:S11()
   (princ “nChange layer : S1<Red>”)(ssget)
   (command “chprop” “p” “” “la” “S1” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:S22()
   (princ “nChange layer : S2<Yellow>”)(ssget)
   (command “chprop” “p” “” “la” “S2” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:S33()
   (princ “nChange layer : S3<Green>”)(ssget)
   (command “chprop” “p” “” “la” “S3” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:S44()
   (princ “nChange layer : S4<Cyan>”)(ssget)
   (command “chprop” “p” “” “la” “S4” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:S55()
   (princ “nChange layer : S5<Blue>”)(ssget)
   (command “chprop” “p” “” “la” “S5” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:S66()
   (princ “nChange layer : S6<Magenta>”)(ssget)
   (command “chprop” “p” “” “la” “S6” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:S77()
   (princ “nChange layer : S7<White>”)(ssget)
   (command “chprop” “p” “” “la” “S7” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:S88()
   (princ “nChange layer : S8<Dark Gray>”)(ssget)
   (command “chprop” “p” “” “la” “S8” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
(defun C:S99()
   (princ “nChange layer : S9<Gray>”)(ssget)
   (command “chprop” “p” “” “la” “S9” “lt” “bylayer” “c” “bylayer” “”)
   (princ))
  • 27 조회
      2015-12-14T11:03:10+09:00답변 등록 답변 등록 일시 2015-12-14 11:03 am
      다시한번 글이 길어서 죄송해요….
      ;————— Layer ADD———————————————–
      (command “-layer” “m” “CO1” “C” “7” “” “”)
      (command “-layer” “m” “CO2” “C” “4” “” “”)
      (command “-layer” “m” “CO3” “C” “6” “” “”)
      (command “-layer” “m” “FORM” “C” “7” “” “”)
      (command “-layer” “m” “H1” “C” “1” “” “”)
      (command “-layer” “m” “P1” “C” “3” “” “”)
      이렇게 생성하는거는 찾아서 했는데 ㅠㅠㅠ저 리습을 꼭 써야하더라구요 치수부분때매(치수부분은 LISP꺼 살리고싶어요)
      객체선택후, 단축키 C1을 누르면 CO1로 레이어변경 뭐 이런식…이랑
      2015-12-15T07:37:54+09:00답변 등록 답변 등록 일시 2015-12-15 7:37 am
      메론님 말씀처럼 lisp은 구조는 정말 간단합니다.
      단지 길이가 길어지면 길어질수록 에러뜨면 그 에러찾아 고치는게 숨은그림찾기 같은 느낌이지요…
      저도 한때 애 많이 먹었는데 메론님께서 많은 도움주셨습니다.
      힘내시길…
      2015-12-15T09:25:41+09:00답변 등록 답변 등록 일시 2015-12-15 9:25 am
      안녕하세요!
      이부분을 지우고 위에부분을 넣었는데요!
      C1, C2, C3까지는 단축키를 넣으면 생성이되더라구요 감사해요ㅠㅠㅠ
      HH, PP는 다른거랑 중복되는지 안되더라구요ㅠㅠ제가 이건 찾아서 지워볼게요ㅠㅠ
      그런데 도면을 키면 저절로생기는거는 어떻게하는걸까요?ㅠㅠ
      그리고 선을 그렸을때 선을 선택후 제가 원하는 레이어로 변경하구싶어요ㅠㅠㅠㅠㅠ
      2015-12-15T09:36:15+09:00답변 등록 답변 등록 일시 2015-12-15 9:36 am
      도면을 새로 만들면 저절로 CO1 LAYER가 생성되었으면좋겠어요 ㅠㅠㅠㅠㅠㅠ
      (defun c:FF () ; <— c1이 명령어 입니다.
       (setvar   “cmdecho” 0)
       (if (= (tblsearch “layer” “FORM”) nil)   ; <– CO1 레이어가 없으면 만듭니다.
           (command “-layer” “m” “FORM” “c” “7” “” “”)) ; <– 7이 색상번호
        (princ “nt레이어 만듦 : FORM”)
      (defun c:c1 () ;
       (if (= (tblsearch “layer” “CO1”) nil)   ;
           (command “-layer” “m” “CO1” “c” “7” “” “”)) ;
        (princ “nt레이어 만듦 : CO1”)
      (defun c:c2 () ;
       (if (= (tblsearch “layer” “CO2”) nil)   ;
           (command “-layer” “m” “CO2” “c” “4” “” “”)) ;
        (princ “nt레이어 만듦 : CO2”)
      (defun c:c3 () ;
       (if (= (tblsearch “layer” “CO3”) nil)   ;
           (command “-layer” “m” “CO3” “c” “6” “” “”)) ;
        (princ “nt레이어 만듦 : CO3”)
      (defun c:HH () ;
       (if (= (tblsearch “layer” “H1”) nil)   ;
           (command “-layer” “m” “H1” “c” “1” “” “”)) ;
        (princ “nt레이어 만듦 : H1”)
      (defun c:PP () ;
       (if (= (tblsearch “layer” “P1”) nil)   ;
           (command “-layer” “m” “P1” “c” “3” “” “”)) ;
        (princ “nt레이어 만듦 : P1”)
      이 아래꺼를 위에거 토대로 바꿨더니 바뀌는건되요!
      근데 생성이안되요ㅠㅠㅠ
      (defun C:C1()
         (princ “nChange layer : CO1<White, Text>”)(ssget)
         (command “chprop” “p” “” “la” “CO1” “lt” “bylayer” “c” “bylayer” “”)
         (princ))
      (defun C:C2()
         (princ “nChange layer : CO2”)(ssget)
         (command “chprop” “p” “” “la” “CO2” “lt” “bylayer” “c” “bylayer” “”)
         (princ))
      (defun C:C3()
         (princ “nChange layer : CO3”)(ssget)
         (command “chprop” “P” “” “la” “CO3” “lt” “bylayer” “c” “bylayer” “”)
         (princ))
      (defun C:HH()
         (princ “nChange layer : H1>”)(ssget)
         (princ))
      (defun C:PP()
         (princ “nChange layer : P1”)(ssget)
         (command “chprop” “p” “” “la” “P1” “lt” “bylayer” “c” “bylayer” “”)
         (princ))
         (princ))
      (defun c:PPP (/ siz ltype)
         (princ))
      (defun c:HHH (/ siz ltype)
         (princ))
