홈/ 질문/Q 80344
등록일: 2009-02-112009-02-11T11:46:47+09:00 2009-02-11T11:46:47+09:00카테고리: AutoCAD & CADian
에러가 나는데 이유를 모르겠네요
(defun c:aq (/ TEXT-TO-COPY TEXT_TO_CHANGE its-a-dim)
  (setq TEXT-TO-COPY nil)
  (setq TEXT_TO_CHANGE nil)
  (setq its-a-dim nil)
  (setvar “cmdecho” 0)
  (command “_.UNDO” “_Group”)
 ;-selects objects to be COPIED
  (WHILE (= TEXT-TO-COPY NIL)
    (SETQ TEXT-TO-COPY (NENTSEL “nSelect attrib or text:”))
 ;-error chk
    (IF (= TEXT-TO-COPY NIL)
      (ALERT “Please select text or attrib…..”)
    ) ;-End of if statement
  ) ;-End of while statement
  (IF (/= NIL TEXT-TO-COPY)
    (SETQ TEXT-TO-COPY-INFO (ENTGET (CAR TEXT-TO-COPY)))
  (REDRAW (CDR (ASSOC -1 TEXT-TO-COPY-INFO)) 3)
 ;-selects objects to be changed
  (SETQ TEXT_TO_CHANGE
         (NENTSEL “nSelect TARGET attrib or text, or [Enter] for multiple copies”)
  ) ;_ end of SETQ
 ;-If user presses enter the program goes into a while loop
 ; to select muliple objects
  (if (= TEXT_TO_CHANGE nil)
    (progn (SETQ TEXT_TO_CHANGE 1)
           (WHILE TEXT_TO_CHANGE
             (SETQ TEXT_TO_CHANGE (NENTSEL))
             (text_check)
             (if its-a-dim
               (change_dim)
             ) ;_ end of if
             (if (not its-a-dim)
               (progn
                 (setq REGEN_NAME TEXT_TO_CHANGE)
                 (IF (= (length REGEN_NAME) 4)
                   (SETQ REGEN_NAME (CADDDR REGEN_NAME))
                 ) ;_ end of IF
                 (SETQ TEXT_TO_CHANGE (ENTGET (CAR TEXT_TO_CHANGE)))
                        (subst (assoc 1 TEXT-TO-COPY-INFO)
                               (assoc 1 TEXT_TO_CHANGE)
                               TEXT_TO_CHANGE
                        ) ;_ end of subst
                 ) ;_ end of setq
                 (entmod TEXT_TO_CHANGE)
                 (entupd (car REGEN_NAME))
               ) ;_ end of progn
             ) ;_ end of WHILE
           ) ;_ end of progn
    ) ;_ end of if
  ) ;-end of while loop
 ;-changes a single object
  (if (/= TEXT_TO_CHANGE nil)
    (progn (text_check)
           (if its-a-dim
             (change_dim)
           ) ;_ end of if
           (if (not its-a-dim)
             (progn
               ) ;_ end of IF
               (PROGN
               ) ;_ end of PROGN
                             TEXT_TO_CHANGE
                      ) ;_ end of subst
               ) ;_ end of setq
             ) ;_ end of progn
           ) ;_ end of if
    ) ;_ end of progn
  ) ;-end of single change
  (command “_.UNDO” “End”)
  (REDRAW (CDR (ASSOC -1 TEXT-TO-COPY-INFO)) 4)
  (PRINC)
) ;_ end of defun
(princ “nAttribute Copy 2.0 written by Clinton Cogswell at cmcadd.com….”)
(princ “ntAC (Attribute/copy) loaded.  Start command with AC.”)
 ;|첲isual LISP?Format Options?
(96 2 1 2 T “end of ” 80 9 0 0 2 nil T nil T)
;*** DO NOT add text below the comment! ***|;
위의 리습은 일반 text 내용을 속성블럭안에 있는 text에 넣어주는 기능이 되는건데요
편리한 기능이기에 받았는데 뭐가 문제인지 제 컴에서 안되서요…부탁드려요~~
  • 17 조회
