홈/ 질문/Q 80699
등록일: 2009-03-022009-03-02T10:05:14+09:00 2009-03-02T10:05:14+09:00카테고리: AutoCAD & CADian
오스냅 안꺼지게 하는방법좀 알려주세요
(defun C:BAR( /
             sblist bblist
      scl ans ssc nc llist count cent cc rc fn ipnt ans34)
  (bardlg)
;  (alert (rtos #roundup))
;  (exit)
(setvar “luprec” 3)
  (setvar “osmode” 0)
  (setvar “cmdecho” 0)
  (command “dimscale” “50”)
  (setq scl (getvar “DIMSCALE”))            ;scale값 잡아내기
;  (if (= #tr34 “1”)
;    (setq ans34 “Yes”)
;    (setq ans34 “No”)
;  );if
  (setq ans “Table”)
  (setq ssc (ssget ‘((0 . “CIRCLE”))))      ;circle들을 입력
  (setq nc (sslength ssc))                  ;circle의 갯수
  (setq llist nil)                          ;빈 line-list 만듬
  (setq count 0)
  (repeat nc                                            ;circle갯수만큼 반복
    (setq cent (entget (ssname ssc count)))             ;circle정보
    (setq cc (cdr (assoc 10 cent)))                     ;center 좌표
    (setq rc (cdr (assoc 40 cent)))                     ;radius (반지름)
    (setq llist (append llist (list (b_mark cc rc #roundup))))   ;Marking 찾기
    (setq count (1+ count))                             ;다음 circle로
  ) ;of repeat
  (cond
    ((= ans “File”)
      (progn
        (setq fn (getfiled “Open data file” “” “dat” 1))      ;file이름 입력받음
        (write_data llist fn)                                 ;파일로 만들기
      ) ;of progn
    ) ;of sub_cond
    ((= ans “Table”)
      (if (= #addg “1”)
 (progn
          (setq spblist (split_blist llist 22))
          (setq bblist (car spblist))
          (setq sblist (cadr spblist))
          (if bblist
            (progn
              (setq ipnt (getpoint “nInsert point(D22~D32): “))             ;삽입점 입력받음
              (bar_list bblist #addb ipnt scl)                             ;bar list그리기
            );progn
          );if
          (if sblist
            (progn
              (setq ipnt (getpoint “nInsert point(D10~D19): “))             ;삽입점 입력받음
              (bar_list sblist #adds ipnt scl)                             ;bar list그리기
            );progn
          );if
        );progn
        (progn
          (setq ipnt (getpoint “nInsert point: “))             ;삽입점 입력받음
          (bar_list llist #addratio ipnt scl)                             ;bar list그리기
        ) ;of progn
      );if
    ) ;of sub_cond
    ((= ans “All”)
      (progn
        (write_data llist fn)                                 ;file로 만들기
        (bar_list llist ipnt scl)                             ;bar list그리기
      ) ;of progn
    ) ;of sub_cond
  ) ;of cond
  (pop-env)                                             ;환경변수 복귀
  (princ “nNormal terminated”)                         ;정상적으로 끝남 표시
  (setq *error* oer seterr nil)
) ;of defun
(defun B_MARK(IP R A34 /
  A34 ix iy p1 p2 p3 ss ssn count tlst sent etype l1 l2 end_p nt
  txt1 txt2 MARK LD LD1 AVL L txt txtl N maxl
  (setq ix (car IP)                         ;삽입점 x
        iy (cadr IP)                        ;       y
        p1 (list (- ix R) (+ iy R))         ;
        p2 (list (+ ix R) (- iy R))         ;
        p3 (list (+ ix R) (+ iy R))         ;
        ss (ssget “C” p1 p2)                ; MARKING/LINE 잡아내기
        ssn (sslength ss)
        count 0
        tlst nil)
  (cond
    ((= A34 4) (setq roundv 0.0035))
    ((= A34 5) (setq roundv 0.0045))
  );cond
  (repeat ssn                                 ;엔티티 갯수만큼 반복
    (setq sent (entget (ssname ss count)))
    (setq etype (cdr (assoc 0 sent)))
    (cond
      ((= etype “TEXT”)                       ;엔티티가 텍스트인 경우
        (progn
           (setq tlst (append tlst (list (cdr (assoc 1 sent))))) ;텍스트 리스트에 추가
        ) ;of progn
      ) ;of etype=TEXT
      ((= etype “LINE”)                       ;엔티티가 라인인 경우
        (progn
          (setq l1 (cdr (assoc 10 sent))          ;첫점
                l2 (cdr (assoc 11 sent)))         ;끝점
          (if (> (car l1) (car l2))             ;끝점찾기
            (setq end_p l1)
            (setq end_p l2)
          ) ;of if
        ) ;of progn
      ) ;of etype=LINE
    ) ;of cond
  ) ;of repeat                                  ;다음 엔티티로
  (setq nt (length tlst))                       ;text갯수
  (if (= nt 2)                                  ;text갯수가 두개면 (예: A1-1)
    (progn
      (setq txt1 (car (sp-trunc (nth 0 tlst)))
            txt2 (car (sp-trunc (nth 1 tlst))))
      (if (= (substr txt1 1 1) “-“)               ;-가 붙은 쪽을 뒤로해서 더하기
        (setq MARK (strcat txt2 txt1))
        (setq MARK (strcat txt1 txt2))
      ) ;of if
    ) ;of progn
    (setq MARK (nth 0 tlst))                     ;text갯수가 한개면 (예: A2)
  ) ;of if
  ; DIA , 길이, 갯수 잡아내기
  (setq ss (ssget “C” p3 end_p ‘(( 0 . “TEXT”))))
  (setq ssn (sslength ss)
        count          0
        DIA            “”
        LD             0.0
        LD1            0.0
        AVL            0.0
        L              0.0
        N                0)
  (repeat ssn
    (setq txt (car (sp-trunc (cdr (assoc 1 (entget (ssname ss count))))))  ;텍스트 내용
          txtl                                        (strlen txt))        ;텍스트 길이
    (cond
      ((or (= (setq txt3 (substr txt 1 3)) “D13”)
           (= txt3 “D10”) (= txt3 “D16”)  (= txt3 “D19”) (= txt3 “D22”)
           (= txt3 “D25”) (= txt3 “D29”) (= txt3 “D32”)
           (= txt3 “H10”) (= txt3 “H13”)  (= txt3 “H16”) (= txt3 “H19”)
           (= txt3 “H22”) (= txt3 “H25”) (= txt3 “H29”)
           (= txt3 “H32”))                                      ; DIA
        (setq DIA TXT)
      ) ;of sub_cond
      ((= (substr txt 1 2) “L=”)                                ; L=
        (setq L (atof1 (substr txt 3 (- txtl 2))))
      ) ;of sub_cond
      ((= (substr txt 1 3) “L’=”)                               ; L’=
        (setq LD (atof1 (substr txt 4 (- txtl 3))))
      ) ;of sub_cond
      ((= (substr txt 1 3) “L`=”)                               ; L`=
        (setq LD1 (atof1 (substr txt 4 (- txtl 3))))
      ) ;of sub_cond
      ((= (substr txt 1 6) “A.V.L=”)                            ;A.V.L=
        (setq AVL (atof1 (substr txt 7 (- txtl 6))))
      ) ;of sub_cond
      ((= (substr txt 1 2) “N=”)                                ;N=
;        (setq N (atoi (substr txt 3 (- txtl 2))))                     ;정수로바꿈
        (setq N (atof (substr txt 3 (- txtl 2))))                     ;정수로바꿈
      ) ;of sub_cond
    ) ;of cond
  ) ;of repeat
  (setq maxl L)
  (if (> LD maxl) (setq maxl LD))
  (if (> LD1 maxl) (setq maxl LD1))             ; L, L’중 가장 큰 값 사용
  (if (> AVL 0.0) (setq maxl AVL))              ;A.V.L이 있으면 A.V.L 을 길이로
  (if (= maxl 0.0) (alert (strcat “<” MARK “>” ” LENGTH NOT FOUND”)))
  (if (= DIA “”) (alert (strcat “<” MARK “>” ” DIA NOT FOUND”)))
  (if (= N 0) (alert (strcat “<” MARK “>” ” NUMBER NOT FOUND”)))
  (if (> A34 0)                                 ;3사4입의 적용여부
    (progn
      (setq rm (rem maxl 0.01))                     ; 3사 4입
      (if (>= rm roundv)                            ;나머지가 3.5MM이상일 때
        (setq L (+ maxl (- 0.01 rm)))                  ;올림
        (setq L (- maxl rm))                        ;나머지가 3.5MM이하일 때
      ) ;of if                                         ;버림
    );progn
    (setq L maxl)
  );if
  (list MARK DIA L N)
) ;of defun
(defun atof1(STR / n count dot)
  (setq     n (strlen str)
        count            1
        dot              0)
  (repeat n
    (if (= (substr str count 1) “.”) (setq DOT count))
  ) ;of repeat
  (if (= dot 0) (* 0.001 (atof str))
                (atof str))
) ;of defun
(defun ATOI1( STR / n count str chr)
        count            1)
  (while (/= (setq chr (substr str count 1)) “”)
    (if (= chr “,”)
      (setq str (strcat (substr str 1 (1- count))
                        (substr str (1+ count) (- n count)))
              n (1- n))
    ) ;of if
  ) ;of while
  (atoi str)
) ;of defun
(defun DATA-IN(arg1
/             srt    strl    count    num    strt    nchr    subs
              lst    rslt
;(setq oer *error* *error* seterr)   ;Store AutoLISP error routine
   (setq str arg1)                              ;넘어온 문자열
   (setq strl (strlen arg1))                    ;넘어온 문자열의 길이
   (setq count 1)
   (setq num 1)
   (setq strt 1)                                ;추출시작 위치
   (setq nchr 1)                                ;추출문자 갯수
   (repeat (+ strl 1)
      (setq subs (substr str count 1))          ;문자 한개
      (if (or (= subs “,”) (= subs “”))         ;현재 문자가 ,이거나 끝일때
         (progn
            (setq lst (substr str strt (- nchr 1)))    ;시작위치부터
            (if (= rslt nil)
               (setq rslt (list lst))                  ;돌림값이 비었을때
               (setq rslt (append rslt (list lst)))    ;돌림값에다 추가
            ) ;of if
            (setq nchr 0)                       ;추출갯수 다시 0으로
            (setq strt (1+ count))              ;다음 추출시작을 다음문자로
         ) ;of progn
         nil
      ) ;of if
      (setq count (1+ count))                   ;다음 문자로
      (setq num (1+ num))                       ;
      (setq nchr (1+ nchr))                     ;문자 갯수 한개 증가
   ) ;of repeat
   (setq arg1 rslt)                             ;돌림값 돌림
;(setq *error* oer seterr nil)                  ; Restore previous error handler
) ;of defun STRLOC
(defun SP-TRUNC(txt
/               txtl        frntn       backn       txt1
(setq txtl (strlen txt))
(setq frntn 1)
(while (= (substr txt frntn 1) ” “) (setq frntn (+ frntn 1)))
(if (<= frntn txtl)
  (progn
    (setq backn txtl)
    (while (= (substr txt backn 1) ” “)
     (setq backn (- backn 1))
    (setq txt1 (substr txt frntn (- backn frntn -1)))
    (list txt1 frntn backn (is-num txt1))
  ) ;progn
) ;of if
);of defun
(defun IS-NUM(str
/ str strl count ch )
  (setq strl (strlen str))
  (setq count 1)
  (while (or (and (>= (setq ch (ascii (substr str count 1))) 48)
                  (<= ch 57))
             (= ch 44)
             (= ch 46)
             (and (= count 1) (= ch 43))
             (and (= count 1) (= ch 45))
    (setq count (+ count 1))
  ) ;of while
  (if (= count (+ strl 1)) strl NIL)
) ;of defun
(defun SORT_LIST(alist aidx
/       alist       nl       rlist       slist        count      min1
        min_th      count1   c_list      c_val        aidx
  (setq nl (length alist))                  ;list의 갯수
  (setq slist nil)                          ;빈 sort된 list만듬
  (setq rlist alist)                        ;최대값을 축출한 나머지 list
  (setq count nl)                           ;list 갯수부터 한개씩 빼면서 반복
  (repeat nl                                        ;list갯수만큼
    (setq min1 (nth aidx (nth 0 rlist)))             ;첫번째 list를 작은 값으로
    (setq min_th 0)                                 ;최소값의 위치를 처음으로
    (setq count1 1)                                 ;두번째 list부터
    (repeat (1- count)
      (setq c_list (nth count1 rlist))              ;현재 list
      (setq c_val (nth aidx (nth count1 rlist)))    ;현재 값
      (if (lt c_val min1)                             ;현재 값이 min보다 작을때
        (progn
          (setq min_th count1)                      ;최소값위치를 현재 위치로
          (setq min1 c_val)                          ;최소값을 현재 값으로
        ) ;of progn
      ) ;of if
      (setq count1 (1+ count1))                     ;다음 list로
    ) ;of repeat
    (setq slist (append slist (list (nth min_th rlist)))) ;최소값을 sort된 list에 추가
    (setq rlist (del_atom rlist min_th))            ;남은list에서 최소 list 제거
    (setq count (1- count))                         ;한개 줄여서
  ) ;of repeat
  (setq slist slist)
) ;of defun
(defun LT1(arg1 arg2)
  (if (and (is-num arg1) (is-num arg2))
    (< (atof arg1) (atof arg2))
    (< arg1 arg2)
  ) ;of if
) ;of defun
(defun DEL_ATOM(b_list anth
/       b_list      mlist       a_list      count   ;지역변수
  (setq nlist (length b_list))                      ;list의 갯수
  (setq a_list nil)                                 ;빈 list생성
  (setq count 0)                                    ;첫번째 list부터
  (repeat nlist                                     ;list갯수만큼 반복
    (if (/= count anth)                             ;지정된 atom이 아닌경우만
      (setq a_list (append a_list (list (nth count b_list))))   ;list에다 추가
    ) ;of if
  ) ;of repeat
  (setq a_list a_list)
) ;of defun
(defun BAR_LIST(blist add ipnt s
       add     ipnt    s
       bd      bdx     bl      blist    blt     blx     bn      bnx     cdia
       cl      count   dcount  fdia     gtw     gtwa    hy      ix      iy
       lh      ln      ly      nb       nbx     ndia    oldc    sbcount sbn
       slist   stl     th      tl       tlist   tlx     tw      twa     twat
       twax    twt     twx     uwx      vy1     vy1     vy2     y       add_factor
  (setq th 2.5)                                 ;글자 크기
  (setq lh 8)                                   ;한 line의 높이
;;;  (setq add (getreal “n할증률<3%>: “))
;;;  (if (= add nil)                               ;엔터입력시 할증률은 3%
;;;    (setq add_factor 1.03)
    (setq add_factor (+ 1 (/ add 100)))
;;;  );if
  (setq th (* th s))                            ;글자크기 scale대로
  (setq lh (* lh s))                            ;줄높이 scale대로
  (setq ln (length blist))                      ;철근 data 갯수
  (setq blist (reverse (sort_list blist 1)))    ;철근 직경을 기준으로 sort
  (setq fdia (nth 1 (nth 0 blist)))             ;첫 철근 직경
  (setq ix   (car ipnt)
        iy   (cadr ipnt)
        bnx  (+ ix (* 10.0 s))
        bdx  (+ ix (* 30.0 s))
        blx  (+ ix (* 68 s))
        nbx  (+ ix (* 88 s))
        tlx  (+ ix (* 118 s))
        uwx  (+ ix (* 138 s))
        twx  (+ ix (* 168 s))
        twax (+ ix (* 198 s)))
  (setq slist nil                               ;sub list
        tlist nil)                              ;total list
  (setq tl   0.0                                ;같은 철근 길이 합
        tw   0.0)                               ;총 중량
  (setq count 0)                                ;두번째 철근부터
  (repeat ln                                    ;끝까지 반복
    (setq cdia (nth 1 (nth count blist)))       ;현재의 철근직경
    (if (= fdia cdia)                           ;현재직경이 이전직경과 같을 때
      (setq slist (append slist (list (nth count blist))))
      (progn
        (setq tlist (append tlist (list slist)))
        (setq slist (list (nth count blist)))
        (setq fdia cdia)
      ) ;of progn ELSE
    ) ;of if
    (setq count (1+ count))                         ;다음 철근으로
  ) ;of repeat
  (setq tlist (append tlist (list slist)))          ;마지막 철근묶음 추가
  (setq hy (- iy (/ lh 2.0)))                 ;Header의 y위치
  (command “TEXT” “M” (list (+ ix (* 100.0 s)) (+ iy (* th 5)))
                  (* 6.0 s) “0.0” “철 근 재 료 표”)
  (command “TEXT” “M” (list (+ ix (*  10.0 S)) hy) th “0.0” “번 호”)
  (command “TEXT” “M” (list (+ ix (*  30.0 S)) hy) th “0.0” “직 경”)
  (command “TEXT” “M” (list (+ ix (*  55.0 S)) hy) th “0.0” “길    이”)
  (command “TEXT” “M” (list (+ ix (*  80.0 S)) hy) th “0.0” “갯 수”)
  (command “TEXT” “M” (list (+ ix (* 105.0 S)) hy) th “0.0” “총  길  이”)
  (command “TEXT” “M” (list (+ ix (* 130.0 S)) hy) th “0.0” “단위중량”)
  (command “TEXT” “M” (list (+ ix (* 155.0 S)) hy) th “0.0” “총  중  량”)
  (command “TEXT” “M” (list (+ ix (* 185.0 S)) hy) th “0.0” “비 고”)
;  (command “TEXT” “M” (list (+ ix (* 185.0 s)) (- hy lh)) th “0.0” “ADD 3%”)
           (strcat “ADD ” (rtos (* (- add_factor 1.0) 100) 2 0) “%”))
;   (command “INSERT” (strcat (prefix) “blocks/bhead”) ipnt scl scl “0”)
  (setq ly (- hy  (/ lh 2.0)))                      ;line y좌표
  (setq oldc (getvar “CECOLOR”)) (setvar “CECOLOR” “7”)
  (command “LINE” (list ix iy) (list (+ ix (* 200 s)) iy) “”)   ;윗line그리기
  (setvar “CECOLOR” “1”)
  (command “LINE” (list ix ly) (list (+ ix (* 200 s)) ly) “”)   ;아래line그리기
  (command “LINE” (list (+ ix (*   0 s)) iy) (list (+ ix (*   0 s)) (- iy lh)) “”)
  (command “LINE” (list (+ ix (*  20 s)) iy) (list (+ ix (*  20 S)) (- iy lh)) “”)
  (command “LINE” (list (+ ix (*  40 s)) iy) (list (+ ix (*  40 S)) (- iy lh)) “”)
  (command “LINE” (list (+ ix (*  70 s)) iy) (list (+ ix (*  70 S)) (- iy lh)) “”)
  (command “LINE” (list (+ ix (*  90 s)) iy) (list (+ ix (*  90 S)) (- iy lh)) “”)
  (command “LINE” (list (+ ix (* 120 s)) iy) (list (+ ix (* 120 S)) (- iy lh)) “”)
  (command “LINE” (list (+ ix (* 140 s)) iy) (list (+ ix (* 140 S)) (- iy lh)) “”)
  (command “LINE” (list (+ ix (* 170 s)) iy) (list (+ ix (* 170 S)) (- iy lh)) “”)
  (command “LINE” (list (+ ix (* 200 s)) iy) (list (+ ix (* 200 S)) (- iy lh)) “”)
  (setvar “CECOLOR” oldc)
  (setq iy (- iy (* 1.5 lh)))                       ;새로운 insert point
  (setq ndia (length tlist))                        ;직경 갯수
  (setq cl 0                                        ;현재 line번호
        gtw 0.0                                     ;Grand total weight
        gtwa 0.0)
  (setq dcount 0)                                   ;DIA count
  (repeat ndia                                      ;DIA갯수만큼 반복
    (setq dlist (sort_list (nth dcount tlist) 0))   ;DIA별 묶음
    (setq cdia (nth 1 (nth 0 dlist)))               ;현재 직경
    (setq sbn (length dlist))                       ;묶음내 갯수
    (setq stl 0.0)                                  ;Sub total length
    (setq vy1 cl)
    (setq sbcount 0)                                ;Sub bar count
    (repeat sbn                                     ;철근 갯수만큼반복
      (setq bn (nth 0 (nth sbcount dlist))          ;철근번호
            bd (nth 1 (nth sbcount dlist))          ;철근직경
            bl (nth 2 (nth sbcount dlist))          ;철근길이
            nb (nth 3 (nth sbcount dlist)))         ;철근갯수
      (if (/= sbcount 0) (setq bd (chr 34)))        ;처음것이 아니면 같음 표시
      (if (< bl 1.0)
        (setq blt (rtos (* bl 1000.0) 2 0))
        (setq blt (rtos bl 2 3))
      ) ;of if
      (setq tl  (* bl nb)                           ;길이*갯수
            stl (+ stl tl))                         ;소계길이
      (setq y    (- iy (* cl lh)))                  ;현재 line y위치
      (command “TEXT” “M” (list bnx y) th “0.0” bn)              ;번호
      (command “TEXT” “M” (list bdx y) th “0.0” bd)              ;직경
      (command “TEXT” “MR” (list blx y) th “0.0” blt)            ;길이
;      (command “TEXT” “MR” (list nbx y) th “0.0” (itoa nb))        ;정수갯수
;      (command “TEXT” “MR” (list nbx y) th “0.0” (rtos nb 2 3))    ;실수갯수
      (command “TEXT” “MR” (list nbx y) th “0.0”        ;정수갯수,실수갯수판단
        (if (> (- nb (fix nb)) 0)                       ;소수점 이하갯수면
          (rtos nb 2 3)                                 ;실수갯수
          (rtos nb 2 0)
        );if
      );command
      (command “TEXT” “MR” (list tlx y) th “0.0” (rtos tl 2 3))  ;총길이
      (setq ly (- y (/ lh 2.0)))                                    ;line y좌표
      (setq oldc (getvar “CECOLOR”)) (setvar “CECOLOR” “1”)
      (command “LINE” (list ix ly) (list (+ ix (* 200 s)) ly) “”)      ;line그리기
      (setq sbcount (1+ sbcount))                                   ;다음철근
      (setq cl (+ cl 1))                                            ;현재 line
    ) ;of repeat
    (cond
      ((= cdia “D10”) (setq uw 0.560))
      ((= cdia “D13”) (setq uw 0.995))
      ((= cdia “D16”) (setq uw 1.560))
      ((= cdia “D19”) (setq uw 2.250))
      ((= cdia “D22”) (setq uw 3.040))
      ((= cdia “D25”) (setq uw 3.980))
      ((= cdia “D29”) (setq uw 5.040))
      ((= cdia “D32”) (setq uw 6.230))
      ((= cdia “H10”) (setq uw 0.560))
      ((= cdia “H13”) (setq uw 0.995))
      ((= cdia “H16”) (setq uw 1.560))
      ((= cdia “H19”) (setq uw 2.250))
      ((= cdia “H22”) (setq uw 3.040))
      ((= cdia “H25”) (setq uw 3.980))
      ((= cdia “H29”) (setq uw 5.040))
      ((= cdia “H32”) (setq uw 6.230))
    ) ;of cond
    (setq tw (* stl uw 0.001)                                   ;총중량
          twt (rtos tw 2 3)
          tw (atof twt)
;          twa (* tw 1.03)                                       ;총중량(가산)
          twa (* tw add_factor)                                       ;총중량(가산)
          twat (rtos twa 2 3)
          twa (atof twat)
          gtw (+ gtw tw)
          gtwa (+ gtwa twa))                                    ;전체중량
    (setq    y  (- iy (* lh cl)))                               ;현재 line y좌표
    (command “TEXT” “M” (list (/ (+ ix nbx) 2.0) y) th “0.0” “소      계”)
;    (command “INSERT” (strcat (prefix) “BLOCKS/BSUBT”)         ;소계
;                      (list (/ (+ ix nbx) 2.0) y)
;                      scl scl “0”)
    (command “TEXT” “MR” (list tlx y) th “0.0” (rtos stl 2 3))  ;총길이 소계
    (command “TEXT” “MR” (list uwx y) th “0.0” (rtos uw 2 3))   ;단위중량
    (command “TEXT” “MR” (list twx y) th “0.0” twt)   ;총중량소계
    (command “TEXT” “MR” (list twax y) th “0.0” twat) ;총중량소계(가산)
    (setq vy1 (- iy (* vy1 lh) (/ lh -2.0))
          vy2 (- iy (* cl lh) (/ lh -2.0)))
    (command “LINE” (list (+ ix (*  20 s)) vy1) (list (+ ix (*  20 S)) vy2) “”)
    (command “LINE” (list (+ ix (*  40 s)) vy1) (list (+ ix (*  40 S)) vy2) “”)
    (command “LINE” (list (+ ix (*  70 s)) vy1) (list (+ ix (*  70 S)) vy2) “”)
    (setq cl (1+ cl))                                           ;현재 line번호
    (setq dcount (1+ dcount))                                   ;다음 직경으로
  ) ;of repeat
  (setq y (- iy (* lh cl)))                                 ;y좌표
  (command “TEXT” “M” (list (/ (+ ix nbx) 2.0) y) th “0.0” “총      계”)
;  (command “INSERT” (strcat (prefix) “BLOCKS/BGRDT”)            ;총계
;                    scl scl “0”)
  (command “TEXT” “MR” (list twx y) th “0.0” (rtos gtw 2 3))    ;천체중량
  (command “TEXT” “MR” (list twax y) th “0.0” (rtos gtwa 2 3))  ;천체중량(가산)
  (command “TEXT” “M” (list (- twx (* th 3)) (+ y (/ th 2.0))) th “0.0” “T”)
  (command “TEXT” “M” (list (- twax (* th 3)) (+ y (/ th 2.0))) th “0.0” “T”)
  (setq vy1 (+ iy (/ lh 2.0))
        vy2 (- iy (* (1+ cl) lh) (/ lh -2.0)))
  (command “LINE” (list ix vy1) (list ix vy2) “”)
  (command “LINE” (list (+ ix (* 90 s)) vy1) (list (+ ix (* 90 s)) vy2) “”)
  (command “LINE” (list (+ ix (* 120 s)) vy1) (list (+ ix (* 120 s)) vy2) “”)
  (command “LINE” (list (+ ix (* 140 s)) vy1) (list (+ ix (* 140 s)) vy2) “”)
  (command “LINE” (list (+ ix (* 170 s)) vy1) (list (+ ix (* 170 s)) vy2) “”)
  (command “LINE” (list (+ ix (* 200 s)) vy1) (list (+ ix (* 200 s)) vy2) “”)
) ;of defun
(defun WRITE_DATA( LLIST FN / nl count opf nl line nb)
  (setq nl (length LLIST)                               ;list의 갯수
        count           0)                              ;첫 list부터
  (setq opf (open fn “w”))                              ;file열기
  (repeat nl                                            ;list갯수만큼 반복
    (setq nb (nth 3 (nth count llist)))
    (setq line (strcat (nth 0 (nth count llist)) “,”
                       (nth 1 (nth count llist)) “,”
                       (rtos (nth 2 (nth count llist)) 2 3) “,”
;                       (itoa (nth 3 (nth count llist)))
                         (rtos nb 2 3)                  ;실수갯수
                         (rtos nb 2 0)                  ;정수갯수
                       );if
               );strcat
    );setq
    (write-line line opf)                               ;파일에 쓰기
    (setq count (1+ count))                             ;다음 list로
  ) ;of repeat
  (close opf)                                           ;파일 닫기
  (princ “nDATA FILE “)
  (princ FN)
  (princ ” is made”)
) ;of defun
(defun LT(arg1 arg2)
  (setq hpos1 (str_position arg1 “-“)
        hpos2 (str_position arg2 “-“))
  (if (and (= hpos1 nil) (= hpos2 nil))
    (lt1 arg1 arg2)
    (progn
      (if hpos1
        (setq arg1f (substr arg1 1 (1- hpos1)))
        (setq arg1f arg1)
      );if
      (if hpos2
        (setq arg2f (substr arg2 1 (1- hpos2)))
        (setq arg2f arg2)
      );if
      (if (= arg1f arg2f)
        (lt1 arg1 arg2)
        (lt1 arg1f arg2f)
      ) ;of if
    );progn
  );if
;  (if (and (is-num arg1) (is-num arg2))
;    (< (atof arg1) (atof arg2))
;    (< arg1 arg2)
;  ) ;of if
) ;of defun
(defun str_position(str1 str2 / str1 str2 len1 len2 count )
  (setq len1 (strlen str1)
        len2 (strlen str2))
  (setq count 1)
  (while (and (/= (substr str1 count len2) str2) (<= count (- len1 len2 -1)))
  ); repeat
 (if (> count (- len1 len2 -1)) nil count)
);defun str_position
(defun split_blist( blist idia /
;  (setq blist (reverse (sort_list blist 1)))    ;철근 직경을 기준으로 sort
  (setq bbarlist nil
        sbarlist nil)
  (setq nbar (length blist))
  (setq ibar 0)
  (repeat nbar
    (setq diaofbar (atoi (substr (nth 1 (nth ibar blist)) 2 2)))
    (if (>= diaofbar idia)
      (setq bbarlist (append bbarlist (list (nth ibar blist))))
      (setq sbarlist (append sbarlist (list (nth ibar blist))))
    (setq ibar (1+ ibar))
  );repeat
  (list bbarlist sbarlist)
);defun
(defun bardlg(/
                  dcl_id )
  (setq dcl_id (load_dialog “bar”))                 ;ddscl.dcl load
  (if (not (new_dialog “bar” dcl_id)) (exit))         ;ddscl.dcl 안의 scl빨몹
;  (if (= #tr34 “1”) (set_tile “tr34” “1”))
  (cond
    ((= #roundup 4) (set_tile “round4” “1”))
    ((= #roundup 5) (set_tile “round5” “1”))
    ((= #roundup 0) (set_tile “roundno” “1”))
    ((= #roundup nil)
      (setq #roundup 0))
  );cond
  (if (/= #addratio nil) (set_tile “addratio” (rtos #addratio 2 0)) (set_tile “addratio” “3”))
  (if (/= #adds nil) (set_tile “adds” (rtos #adds 2 0)) (set_tile “adds” “3”))
  (if (/= #addb nil) (set_tile “addb” (rtos #addb 2 0)) (set_tile “addb” “6”))
  (if (= #addg “1”) (set_tile “addg” “1”)(set_tile “addg” “0”))
  (set_addg)
  ;  (alert #addg)
;;;  (set_tile “div” (rtos 10 2 0))
;;;  (set_tile “prop” (strcat “Y = aX^2 = ” (rtos #a 1 6) ” X^2″))
;;;  (set_tile “cap” #cap)
;;;  (set_tile “both” #both)
;;;  (set_tile “length”  (strcat “L= ” (rtos h 2 3)))
;;;  (set_tile “height”  (strcat “H= ” (rtos l2 2 3)))
;  (action_tile “tr34” “(set_tr34)”)     ;user 럼력 box
  (action_tile “round4” “(setq #roundup 4)”)
  (action_tile “round5” “(setq #roundup 5)”)
  (action_tile “roundno” “(setq #roundup 0)”)
  (action_tile “addg” “(set_addg)”)               ;user 럼력 box
  (action_tile “addratio” “(set_val $key)”)               ;user 럼력 box
  (action_tile “adds” “(set_val $key)”)               ;user 럼력 box
  (action_tile “addb” “(set_val $key)”)               ;user 럼력 box
  (action_tile “cancel” “(do_cancel)”)                ;CALCEL button
  (action_tile “accept” “(do_accept)”)                ;CALCEL button
  (start_dialog)
  (unload_dialog dcl_id)
) ;of defun para-DIALOG
(defun set_tr34 ()
  (setq #tr34 (get_tile “tr34”))
);defun
(defun set_addg ()
  (setq #addg (get_tile “addg”))
  (if (= #addg “0”)
    (progn
      (mode_tile “adds” 1)
      (mode_tile “addb” 1)
      (mode_tile “addratio” 0)
    );progn
    (progn
      (mode_tile “adds” 0)
      (mode_tile “addb” 0)
      (mode_tile “addratio” 1)
    );progn
  );if
);defun
(defun set_val(key )
  (setq val (atof (get_tile key)))
  (if (<= val 0.0)
    (progn
      (set_tile “error” “Invalid Input”)
      (mode_tile key 2)
      (mode_tile key 3)
    );progn
    (progn
      (cond
        ((= key “addratio”) (setq #addratio val))
        ((= key “adds”) (setq #adds val))
        ((= key “addb”) (setq #addb val))
      );cond
      (set_tile “error” “”)
    );progn
  );if
);defun
(defun do_cancel()
  (done_dialog)
  (exit)
);defun
(defun do_accept()           ;dialog box를 끝내기 전에 모든 입력 데이타 확인
  (if (and (set_val “addratio”)
           (set_val “adds”)
           (set_val “addb”))
    (done_dialog)
  ) ;of IF
) ;of defun
osmode 를 숫자만 바꿨더니 표가 망가져서 나오는데..
어딜 수정해야하나요?
osmode 4351 입니다
  • 45 조회
    • cadplus_plot 사용방법 질문드립니다
