회사에서 작업중 캐드 파일 두개를 한개로 합쳐야 하는데 복사 붙여넣기가 안되네요…ㅜㅜ
dxf 파일로 저장했다가 불러오기 해서 하면 된다고 해서 해보는데…
불러오기가 안되네요.
recorver해도 오류가 없다고 나오면서 안되네요..ㅜㅠ
붙여넣기 하면 이렇게 나와요.
_pasteclip Duplicate definition of block _ARCHTICK ignored.
Duplicate definition of block UPR1 ignored.
Duplicate definition of block CAP ignored.
Duplicate definition of block COUPLING ignored.
Duplicate definition of block DPEND1 ignored.
Duplicate definition of block ELEV ignored.
Duplicate definition of block ELEVINFO ignored.
Duplicate definition of block ETC ignored.
Duplicate definition of block HEIGHTZ ignored.
Duplicate definition of block HITEBOX ignored.
Duplicate definition of block PEND2 ignored.
Duplicate definition of block PIPESPC ignored.
Duplicate definition of block REF ignored.
Duplicate definition of block RISE ignored.
Duplicate definition of block RISER ignored.
Duplicate definition of block SECTION ignored.
Duplicate definition of block SIDE1 ignored.
Duplicate definition of block SIDE4 ignored.
Duplicate definition of block SPRIG1 ignored.
Duplicate definition of block SPRIG2 ignored.
Duplicate definition of block SPRIG3 ignored.
Duplicate definition of block SPRIG4 ignored.
Duplicate definition of block UPR2 ignored.
Duplicate definition of block UPR3 ignored.
Duplicate definition of block vlvbflow ignored.
Duplicate definition of block spk-calc-pump ignored.
Duplicate definition of block HEIGHTH ignored.
Duplicate definition of block vlvbfly ignored.
Duplicate definition of block SPK-CALC-REFPT-BOX ignored.
Duplicate definition of block SPK-CALC-SRC ignored.
Duplicate definition of block SPK-CALC-SRC-FIXED ignored.
Duplicate definition of block SPK-CALC-NODE ignored.
Duplicate definition of block vlvother ignored.
Duplicate definition of block SPK-CALC-JOB ignored.
Duplicate definition of block SPK-CALC-DA ignored.
Duplicate definition of block SPK-CALC-HEAD ignored.
Duplicate definition of block SPK-CALC-RESULTS ignored.
Duplicate definition of block vlvcheck ignored.
Duplicate definition of block SPK-CALC-HOSE ignored.
Duplicate definition of block $HEADS ignored.
Substituting [simplex.shx] for [COMPLEX].
Substituting [simplex.shx] for [AvantGarde Bk BT].
Substituting [simplex.shx] for [highways.shx].
Substituting [simplex.shx] for [Txt].
Resolve Xref “X-P1-EXTR”: X-P1-EXTR.dwg
“X-P1-EXTR.dwg” cannot be found.
Resolve Xref “X-P2-PERIMETER”: M:201313609 – Mayfair Village NorthCDX-P2-PERIMETER.dwg
“X-P2-PERIMETER.dwg” cannot be found.
이렇게 뜨면서 복사가 안되네요..ㅠㅠ
영문버전을 써서 영어로 나왔네요..
이유가 뭘까요??ㅠ_ㅜ 알려주세요
파일 첨부하고 싶은데 사이즈가 넘 크네요..ㅜ_ㅠ
원하시면 메일로 보내드릴게요
꼭 알려주시거나 고쳐주세요..ㅠㅠ
고쳤네요 ㅋㅋㅋ
2010버젼으로 저장후 CADian 가정용으로 열어서 audit-purge 후에 다시 저장후,
복사했더니 되네요 ㅋ
