고수님 옵셋리습인데 지정레이로 되게끔해주실수 없을까여 가령 1번레이어로 되게끔요 고수님들 부탁합니다
(defun C:O9 (/ cmd d lyr obj ename elist)(vl-load-com)
(setq cmd (getvar “cmdecho”))
(setvar “cmdecho” 0)
(if (null #oldist)
(setq #oldist 1)
(setq d (getreal (strcat “nSpectfy of distance <” (vl-princ-to-string #oldist) “>: “)))
(if (null d)
(setq d #oldist)(setq #oldist d)
(if (null #olnlayer)
(setq #olnlayer “0”)
(setq lyr (strcase (getstring (strcat “nEnter Layer name <” #olnlayer “>: “))))
(if (null (read lyr))
(setq lyr #olnlayer)(setq #olnlayer lyr)
(while (null (tblsearch “LAYER” lyr))
(prompt (strcat “n Layer ” lyr ” does not exist.”))
(setq lyr (strcase (getstring “nEnter layer name again: “)))
(setq obj (entsel “nChoose object: “))
(while (null obj)
(setq obj (entsel “nChoose object again: “))
(while (not (null obj))
(command “offset” d obj pause “”)
(setq ename (entlast))
(setq elist (entget ename))
(setq elist (subst (cons 8 lyr) (assoc 8 elist) elist))
(entmod elist)
(if (not (null obj))
(progn (command “offset” “” obj pause “”)
(setq ename (entnext ename))
(prompt “nTo cancel command, press the ESC key. “)
(setvar “cmdecho” cmd)
(defun lineerr(err)
(prompt “n*error*:”)
(prin1 err)
(command “redraw”)
(setq *error* olderr)
);** defun end **
레이어 지정 구문이 있는데요 ???
아 그렇군요 레이어 지정구문없애고 바로 1번으로 바꾸어 주시면 안될까요
