;;*** SUB
(defun C:` (/ b1 b2 b3 b4 tot pot total n t1 ss en ename elist no sum )
(setvar “cmdecho” 0)
(graphscr)
(setq n 0 t1 0
ss (ssget ‘((-4 . “<or”)(0 . “TEXT”)(0 . “MTEXT”)(-4 . “or>”)))
en (sslength ss)
(while (< n en)
(setq ename (ssname ss n)
elist (entget ename)
no (atof (cdr (assoc 1 elist) ) )
(if sum
(setq sum (- t1 no))
(setq sum (+ t1 no))
);end if
(setq
t1 sum
n (+ n 1)
(setq pot (getint “Decimal point <0 to 8> : “)
total (rtos t1 2 pot))
(prompt (strcat “nSub Total = ” total )) (terpri)
(setq tot (entsel “Pick a change on target text”))(terpri)
(setq b1 (entget (car tot)))
(setq b2 (assoc 1 b1))
(setq b3 (cons (car b2) total))
(setq b4 (subst b3 b2 b1))
(entmod b4)
(princ “*** 계산이 완료되었습니다. ***”)
;;*** PLUS & SUM
(defun C:“ (/ b1 b2 b3 b4 tot pot total)
(graphscr)
(setq n 0 t 0
en (sslength ss)
(while (< n en)
sum (+ t no)
t sum
n (+ n 1)
total (rtos t 2 pot))
(prompt (strcat “nTotal = ” total )) (terpri)
(entmod b4)
위 리습을 곱하기 나누기 리습으로 만들어 주시면 안되요??
ㅠ,ㅠ
