작은 수에서 큰수를 빼면 소수점이 2개가 찍힙니다.
한개만 찍히도록 할려면 어떻게 해야 하는지 알고 싶습니다.
; Number minus(98CHO_I)
; ->두 수의 차 구하기
(defun c:-(/ choi d_ts w_os ht ss1 en1 ent1 tv1 ss2 en2 ent2 tv2 grpt pt1 rst1
tot1 rtv1 rtv2 en an)
(setq choi (getvar “orthomode”) d_ts (getvar “textsize”)
w_os (getvar “osmode”) )
(setvar “orthomode” 0) (setvar “osmode” 0)
(setq ht d_ts)
(prompt “nText Height<“) (prin1 ht) (prompt “>: “)
(setq ht (getdist))
(if (= ht nil) (setq ht d_ts))
(prompt “nSelect first number->”)
(setq ss1 (entsel) en1 (car ss1)) (redraw en1 3)
(setq ent1 (assoc 1 (entget (car ss1))))
(setq tv1 (cdr ent1))
(prompt “nSelect second number->”)
(setq ss2 (entsel) en2 (car ss2)) (redraw en2 3)
(setq ent2 (assoc 1 (entget (car ss2))))
(setq tv2 (cdr ent2))
(setq grpt (grread T) pt1 (cadr grpt))
(setq rst1 0)
(setq rtv1 (atof tv1) rtv2 (atof tv2))
(setq rst1 (- rtv1 rtv2))
(setq tot1 (abs rst1))
(setq tot1 (rtos tot1 2 3))
(if (= (wcmatch tot1 “*.*”) nil)
(setq tot1 (strcat tot1 “.000”)))
(setq an (strlen tot1))
(if (= (substr tot1 (- an 1) 1) “.”)
(setq tot1 (strcat tot1 “0”)) )
(if (< rst1 0)
(setq tot1 (strcat (substr tot1 1 (- an 4)) “.” (substr tot1 (- an 3) 3) )))
(prompt “n합 계 : “) (prin1 rst1)
(command “text” “j” “r” pt1 ht “0” tot1)
(redraw en1 4) (redraw en2 4)
(prompt “nEnter text point->”)
(command “move” “l” “” pt1 pause)
(setvar “orthomode” choi) (setvar “osmode” w_os)
(prin1)
