홈/ 질문/Q 106239
등록일: 2016-03-122016-03-12T00:34:12+09:00 2016-03-12T00:34:12+09:00카테고리: AutoCAD & CADian
지시선 정렬 LISP 관련 문의드립니다 ㅠ
안녕하세요.
제가 인터넷에서 지시선 정렬 LISP을 받았는데,
내용은 아래와 같습니다.
;;; aligns the landings of selected 3 point leaders to a picked point or selection of leader
;;; and makes landing horizontal (if not already)
(defun c:dd (/ c# crds doc e ins newpt obj ss txt x y sel)
  (vl-load-com)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (initget 0 “Leader PickPoint”)
  (if (= (cond ((getkword
                  (strcat “n Align by [Leader/PickPoint] <Leader>: “)
               (“Leader”)
         “Leader”
    (and (setq e (car (entsel “nSelect leader for alignment: “)))
         (setq x (cadr (assoc 10 (reverse (entget e)))))
    (setq x (car (getpoint “nSelect point for alignment: “)))
  (if (and x (setq ss (ssget ‘((0 . “leader”)))))
    (progn (vla-endundomark doc)
           (vla-startundomark doc)
           (foreach l (vl-remove e
                                 (vl-remove-if ‘listp (mapcar ‘cadr (ssnamex ss)))
             (setq obj  (vlax-ename->vla-object l)
                   crds (vlax-get obj ‘coordinates)
                   c#   (length crds)
             (if (and (= c# 9) ;if leader has 3 points and /= x coord
                      (not (equal x (nth (- c# 3) crds) 0.0001))
               (progn (setq y     (nth (- c# 5) crds) ;new y coord to ensure flat landing
                            newpt (list x y (nth (1- c#) crds))
                      (vlax-put obj
                                ‘coordinates
                                (append (reverse (cdddr (reverse crds))) newpt)
                      (vla-update obj)
                      (and (setq txt (vl-catch-all-apply ;has text attached to leader
                                       ‘vlax-ename->vla-object
                                       (list (cdr (assoc 340 (entget l))))
                           (not (vl-catch-all-error-p txt)) ;check for invalid ename
                           (setq ins (vlax-get txt ‘insertionpoint))
                           (vlax-put txt
                                     ‘insertionpoint
                                     (polar (list x (cadr ins) (caddr ins))
                                            (if (> x (nth (- c# 3) crds))
                                              0.
                                              pi
                                            (if (zerop (getvar ’tilemode))
                                              (vla-get-textgap obj)
                                              (* (getvar ‘dimscale) (vla-get-textgap obj))
                           (vla-update txt)
이 리습이 3점인 지시선에는 적용이 되는데,
2점인 지시선에서는 적용이 안되더라구요.
어떻게 2점까지 쉽게 추가할 수 있는 방법은 없는 것입니까?!
  • 25 조회
