홈/ 질문/Q 87757
등록일: 2010-06-162010-06-16T19:17:18+09:00 2010-06-16T19:17:18+09:00카테고리: AutoCAD & CADian
캐드 리습.오류좀 찾아줏요.원의 중심선.
(defun cl_fn ( cl_orig / shl sucsf e cen rad d ts xx)
  (while (null e)
    (setq e (entsel “nSelect arc or circle: “))
    (if e
      (progn
        (setq e (car e))
        (if (and (/= (cdr (assoc 0 (entget e))) “ARC”)
                 (/= (cdr (assoc 0 (entget e))) “CIRCLE”))
          (progn
            (prompt “nEntity is a “)
            (princ (cdr (assoc 0 (entget e))))
            (setq e nil)
  (setq cen (trans (cdr (assoc 10 (entget e))) e 1))
  (setq rad (cdr (assoc 40 (entget e))))
  (prompt (strcat “nRadius is ” (rtos rad)))
  (prompt (strcat “nDiameter is ” (rtos (* rad 2.0))))
  (setq cen_dia (rad 2.0))
  (setq cen_dia (+ rad cen_dia))
  (if cl_orig
    (progn
      (prompt (strcat “nLength <” (rtos cen_dia) “> : “))
      (setq d (getdist cen))
      (if (null d)
        (setq d cen_dia)
    (setq d cen_dia)
  (command “_layer” “s” “center” “”)
  (command “color” “8” “”)
  (command “-linetype” “s” “center” “”)
  (command “LINE” (list (car cen) (- (cadr cen) d) (caddr cen))
                  (list (car cen) (+ (cadr cen) d) (caddr cen))
; (chcenl (entlast))
  (command “LINE” (list (- (car cen) d) (cadr cen) (caddr cen))
                  (list (+ (car cen) d) (cadr cen) (caddr cen))
  (command “_layer” “s” “0” “”)
  (command “color” “Bylayer” “”)
  (command “-linetype” “s” “Bylayer” “”)
(defun c:cl() (cl_fn T) (princ))
(defun c:cl2() (cl_fn nil) (princ))
  • 25 조회
