홈/ 질문/Q 99229
등록일: 2013-09-012013-09-01T13:57:30+09:00 2013-09-01T13:57:30+09:00카테고리: AutoCAD & CADian
퀵 솔리드
솔리드 편하게 넣는 리습인데 뭐가 잘못됐을까요???
(defun c:qso(/ cla os ortho pt-list k num b2 p1 b1 ss)
(if (= nil (tblsearch “layer” “S-253”))
   (command “m” “S-253” “c” 253 “” “l” “continuous” “” “”)
(setq cla (getvar “clayer”))
(setq os (getvar “osmode”))
(setq ortho (getvar “orthomode”))
(setq pt-list ‘() k 0 num nil b2 0)
(setvar “orthomode” 0)
(setvar “clayer” “S-253”)
(command “undo” “be”)
(initget 128)
(setq p1 (getpoint “nFirst point & 객체선택(S):”))
(if (listp p1)
  (progn
   (command “pline”)
   (while p1
    (command p1)
    (setq pt-list (append pt-list (list p1)))
    (setq p1 (getpoint p1 “nNext point:”))
   (setq num (length pt-list))
   (if (> num 1) (command “c”) (command “”))
   (setvar “osmode” 0)
   (cond ((=num 1)
          (setq b1 (entlast))
          (command “boundary” (nth 0 pt-list) “”)
          (setq b2 (entnext b1))
         ((= num 2)
         (entdel (ent last))
         (command “rectangle” (nth 0 pt-list) (nth 1 pt-list))
   (if (/= b2 nil)
    (progn
     (setq ss (entlast))
     (command “hatch” “solid” ss “”)
     (entdel ss)
     (command “draworder” (entlast) “” “b”)
     (alert “n선이 떨어져있습니다! 확인요망!”)
   (;progn
   (progn
    (setq ss (ssget (list (cons 0 “lwpolyline”)))
    (if ss
     (progn
(command “undo” “e”)
(setvar “osmode” os)
(setvar “orthomode” ortho)
(setvar “clayer” cla)
  • 48 조회
    • 도구막대 이동시 미리보기가 안됩니다.
