홈/ 질문/Q 102906
등록일: 2014-12-102014-12-10T13:14:14+09:00 2014-12-10T13:14:14+09:00카테고리: AutoCAD & CADian
해치합치기 리습 오류원인?(리습포함)
;; massoc (Jaysen Long)               ;;
;; Minor Modification by Jvillarreal ;;
;; Extracts info from list by key     ;;
(defun massoc (key alist / x nlist)
 (foreach x alist
   (if
     (eq key (car x))
     (setq nlist (cons x nlist))
 (reverse nlist)
);defun
(defun c:H2 ( / hentinfo ss i ent ent# seedpt# entinfo entinfo2 ent# seedpt# seedpts MergedHatchList)
(while (/= (cdr (assoc 0 hentinfo)) “HATCH”)
  (setq hentinfo (car (entsel “nSelect Hatch Pattern to use:”)))
  (If hentinfo (setq hentinfo (entget hentinfo)) (princ “nMissed. Try again.”)))
(while (not ss) (princ “nSelect hatch entities to merge:”)(setq ss (ssget ‘((0 . “HATCH”)))))
(setq MergedHatchList
(list (cons 0 “HATCH”)
      (cons 100 “AcDbEntity”)
      (assoc 8 hentinfo)
      (cons 100 “AcDbHatch”)
      (assoc 10 hentinfo)
      (assoc 210 hentinfo)
      (assoc 2 hentinfo)
      (assoc 70 hentinfo)
      (assoc 71 hentinfo)
      (cons 91 (sslength ss))
) i -1 seedpt# 0 ent# 0)
(repeat (sslength ss)
 (setq n -1
       entinfo (entget (ssname ss (setq i (1+ i))))
       entinfo2 (member (assoc 92 entinfo) entinfo)
       entinfo2 (reverse (cdr (member (assoc 75 entinfo2)(reverse entinfo2))))
       ent# (+ ent# (cdr (assoc 91 entinfo)))
       seedpt# (+ seedpt# (cdr (assoc 98 entinfo)))
       seedpts (append seedpts (cdr (member (assoc 98 entinfo) entinfo)))
       MergedHatchList (append MergedHatchList entinfo2)
(entdel (ssname ss i))
(setq MergedHatchList (subst (cons 91 ent#)(assoc 91 MergedHatchList) MergedHatchList)
      MergedHatchList
   (append
     (reverse (cdr (member (assoc 98 hentinfo)(reverse (member (assoc 75 hentinfo) hentinfo)))))
     (cons (cons 98 seedpt#) seedpts))))
(if (= (cdr (assoc 71 hentinfo)) 1)(setq MergedHatchList (append MergedHatchList ‘((-3 (“ACAD” (1010 0.0 0.0 0.0)))))))
(entmake MergedHatchList)
(setq ent (entlast))
 (mapcar
  ‘(lambda (x / entlist)
   (setq entlist (entget (cdr x)))
   (entmod (subst (cons 330 ent) (assoc 330 entlist) entlist))
  (massoc 330 MergedHatchList)
(defun c:MH () (c:MergeHatch))
  • 82 조회
    • 동적블록 신축에서 길이를 늘릴때 최종 길이를 입력 또는 늘려야 하는 차이만큼의 길이를 입력
    • 캐드 타일 개수 구하기
    • 캐드 선택할 때 마우스 옆에 박스안 초록동그라미, 파란동그라미 표시 어떻게 없애나요?
    • 캐드 용량이 16.8MB 인데 10MB 이하로 줄이고 싶습니다
      2014-12-10T13:15:21+09:00답변 등록 답변 등록 일시 2014-12-10 1:15 pm
      해치합치는 리습입니다.
      처음로드해서 실행하면 되는데 두번째실행 부터 해치가 없어지는 현상은 왜 그런걸가요?
    • 국산 CAD ‘캐디안 2025’ 출시 사전 예약 진행 2024-09-27
