홈/ 질문/Q 98745
등록일: 2013-07-092013-07-09T17:32:01+09:00 2013-07-09T17:32:01+09:00카테고리: AutoCAD & CADian
혹시…리습 수정 가능하시나요..
(defun c:ar2 (/ arRegionCenter arRtos arSta arEnd acDoc acSpc ss m2 py textHeigth iPt iPt1 iPt2 tObj)
 (defun arRegionCenter (obj / closed regObj cenPt)
  (setq closed (if (= (vla-get-closed obj) :vlax-true) 0 1))
  (and (= closed 1)(vla-put-closed obj :vlax-true))
  (setq regObj (car (vlax-invoke acSpc ‘addRegion (list obj))))
  (and (= closed 1)(vla-put-closed obj :vlax-false))
  (setq cenPt (vla-get-Centroid regObj))
  (vla-delete regObj)
  (vlax-safearray->list (vlax-variant-value cenPt))
 (defun arRtos (n d / re ls m L s r)
  (defun re (L n / r)
   (if L (cons (reverse (repeat (if (> (length L) (1- n)) n (length L))
     (setq r (cons (car L) r) L (cdr L)) r))(re L n)))
  (defun ls (L d)(if (cdr L)(strcat (car L) d (ls (cdr L) d))(car L)))
  (and (= (type n) ‘STR)(setq n (atof n)))
  (and (minusp n)(setq m t n (abs n)))
  (setq L (re (reverse (mapcar ‘chr (vl-string->list (itoa (fix n))))) 3))
  (setq s (ls (reverse (mapcar ‘(lambda (x) (apply ‘strcat (reverse x))) L)) “,”))
  (if m (setq s (strcat “-” s)))
  (if (> d 0)
   (progn
    (setq r (apply ‘strcat (cddr (mapcar ‘chr (vl-string->list (rtos (abs (- n (fix n))) 2 d))))))
    (if (> (setq i (- d (strlen r))) 0)(repeat i (setq r (strcat r “0”))))
    (strcat s “.” r)
   ) s
 (defun *error* (msg)(arEnd)
  (if (not (wcmatch (strcase msg) “*BREAK,*CANCEL*,*EXIT*”))
   (princ (strcat “n** Error: ” msg ” **”)))(princ)
 (defun arSta (/ lst o)(arEnd)
  (setq gv (mapcar ‘getvar (setq gvL ‘(“OSMODE” “CMDECHO”))))
  (mapcar ‘setvar gvL ‘(0 0))(vla-startundomark acDoc)
 (defun arEnd ()
  (if (and gvL gv)(mapcar ‘setvar gvL gv))
  (if (= 8 (logand 8 (getvar ‘UNDOCTL)))(vla-endundomark acDoc))
 (vl-load-com)
 (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
 (setq acSpc (vlax-get-property acDoc (if (= 1 (getvar ‘CVPORT)) ‘paperspace ‘modelspace)))
 (arSta)
 (if (setq ss (ssget “:S” ‘((0 . “LWPOLYLINE”))))
  (progn
   (setq obj (vlax-ename->vla-object (ssname ss 0)))
   (setq m2 (arRtos (vla-get-Area obj) 0)) ;면적(M2)
   (setq py (arRtos (* (vla-get-Area obj) 0.3025) 0)) ;면적(PY)
   (prompt “nArea (M2): “)(princ m2)
   (prompt “nArea (Py): “)(princ py)(princ)
   (setq textHeigth (* (getvar “dimscale”) 2)) ;문자크기
   (setq iPt (arRegionCenter obj)) ;선택한 객체의 중심점
   (setq iPt1 (vlax-3d-point (list (car iPt) (+ (cadr iPt) (* textHeigth 1.0)) 0.0)))
   (setq iPt2 (vlax-3d-point (list (car iPt) (- (cadr iPt) (* textHeigth 1.0)) 0.0)))
   (setq tObj (vla-addtext acSpc (strcat “면적(M2) : ” m2) iPt1 textHeigth))
   (vla-put-Alignment tObj acAlignmentMiddleCenter)(vla-put-TextAlignmentPoint tObj iPt1)
   (setq tObj (vla-addtext acSpc (strcat “면적(PY) : ” py) iPt2 textHeigth))
   (vla-put-Alignment tObj acAlignmentMiddleCenter)(vla-put-TextAlignmentPoint tObj iPt2)
 )(arEnd)(princ)
면적 계산하는건데요..
이거 면 선택하면 자동으로 면적이랑 평수 나와서 아주 유용하게 쓰고 있어요.
근데 단위가…..
만약에 27평이면 27,000.000 이런식으로….0이 많이 붙어요.
0을 좀 떼어주실 수 있으신가요?
너무 기초적인 질문이라 성가시다면….어느 쪽을 고치라고 한줄 답변만이라도…ㅜㅜ
제가 기본도 안된 사람이라ㅠㅠ
  • 23 조회
    • cadplus_plot 사용방법 질문드립니다
    • 캐드 좌표값을 위경도값으로 산출 가능할까요?
