홈/ 질문/Q 105292
등록일: 2015-10-212015-10-21T17:31:46+09:00 2015-10-21T17:31:46+09:00카테고리: AutoCAD & CADian
홀 좌표 리습
가공 업체에서 일을하게되었는데 홀 좌표뽑는 리습을 사용하고있는데요
이리습
(defun dtr (a) (* a (/ pi 180)))
(defun c:XYT (/ sca a n index th no noo sp lsp lep 1p 2p 3p 4p 5p 6p
                 org xorg yorg lp ep aa spt cp x y rr ss xsp ysp rsp)
(defun *error* (msg)(princ “error: “)(princ msg)  (setvar “osmode” cur-osmode)  (setvar “orthomode” ortho_mode)(princ))
;  (setq sca 1)
  (setq cur-osmode (getvar “osmode”))
   (setq ortho_mode (getvar “orthomode”))
   (setq dlf (getvar “dimlfac”) dsc (getvar “dimscale”) dtxt (getvar “dimtxt”) txth (* dsc dtxt))
  (setq sca (getreal “n>>Input Scale. < 1 >: “))
  (if (= sca nil)(setq sca 1))
  (princ “n>>원이나 Arc를 선택하시오.:”)
  (setvar “orthomode” 1)
  (setvar “cmdecho” 0)
  (setvar “osmode” 32)
0 ………..없음   none
1 ………..끝점   end
2 ………..준간점 mid
4 ………..중심점 cen
8 ………..노드   node
16 ……….사분점 qua
32 ……….교차점 int
64 ……….삽입점 ins
128 ………수직점 per
256 ………접점   tan
512 ………근처점 nea
1024 ……..신속 -두개이상의 점중가가장 가까운점
2048 ……..가상 교차점
  (setq a     (ssget)
        org   (getpoint “n>> 원점.: “)
        xorg  (polar org 0 100)         ;(getpoint org “n>>Positive X-axis direction.: “)
        yorg  (polar org (/ pi 2) 100)  ;(getpoint org “n>>Positive Y-axis direction.: “)
        n     (sslength a)
        index  0 th (rtos txth) no 1
        noo (getstring “n>>머리첨자. < h >: “)
        non (getint “n>> 시작번호. < 1 >: “)
        p-p (getint “n>> 소수이하 자릿수. < 1 >: “)
        sp  (getpoint “n>>표 그리기 시작점.: “)
        lsp (polar sp (dtr 180) (* dsc 5))
        lsp (polar lsp (dtr 90) (* dsc 4))
        lep (polar lsp 0 (* dsc 75))
        1p  (polar lsp 0 (* dsc 15))
        2p  (polar lsp 0 (* dsc 35))
        3p  (polar lsp 0 (* dsc 55))
        lp lsp ep lep
        xp “Y”  ;(getstring “n>>Want head line ? <Y>:”)
    (setvar “osmode” 0)
;  (if (= xp “”)(setq xp “Y”))
  (if (= noo “”)(setq noo “h”))
  (if (= non nil)(setq non 1))
  (if (= p-p nil)(setq p-p 1))
  (if (or (= xp “”)(= (strcase xp) “Y”))
      (progn
         (command “color” “w”)
         (command “text” sp txth 0 “No       X         Y         Dia.”)
         (command “color” “bylayer”)
  (setq th txth)
  (repeat n
    (setq aa (entget (ssname a index)))
    (if (or (= (cdr (assoc 0 aa)) “arc”) (= (cdr (assoc 0 aa)) “CIRCLE”))
;      (if (= (cdr (assoc 0 aa)) “CIRCLE”)
       (progn
         (command “ucs” “3” org xorg yorg)
         (setq cp (cdr (assoc 10 aa))
               x  (rtos (/ (car  (trans cp 0 1)) sca) 2 p-p)
               y  (rtos (/ (cadr (trans cp 0 1)) sca) 2 p-p)
               rr (cdr  (assoc 40 aa))
               rr (/ (* rr 2) sca)
         (command “ucs” “P”)
         (setq spt (polar (trans cp 0 1) (dtr 45) (+ (/ rr 2) 1.0))
               lsp (polar lsp (dtr 270) (* dsc 5))
               lep (polar lep (dtr 270) (* dsc 5))
               rr (strcat  “%%c” (rtos rr 2 p-p))
         (setq ss (strcat noo (itoa non)))
         (command “line” lsp lep “”)
         (command “text” spt th 0 ss)
         (setq sp (polar sp (dtr 270) (* dsc 5)))
         (command “text” sp th 0 ss)
         (setq xsp (polar sp 0 (* dsc 23))
               ysp (polar sp 0 (* dsc 43))
               rsp (polar sp 0 (* dsc 63))
 ; (point-place x)
         (command “text” “r” xsp th 0 x)
 ; (point-place y)
         (command “text” “r” ysp th 0 y)
         (command “text” “r” rsp th 0 rr)
         (setq non (+ non 1))
    (setq index (+ index 1))
  (setq lsp (polar lsp (dtr 270) (* dsc 5))
        4p  (polar lsp 0 (* dsc 15))
        5p  (polar lsp 0 (* dsc 35))
        6p  (polar lsp 0 (* dsc 55))
  (command “line” lp lsp lep ep lp “”)(command “line” 1p 4p “”)
  (command “line” 2p 5p “”)(command “line” 3p 6p “”)
); end of defun
아크 인식 삭제와 크기별 최단거리로 좌표를 뽑을 수 있게 수정을 하고싶은데 어떻게 해야할까요??
  • 118 조회
    • cadplus_plot 사용방법 질문드립니다
    2. 자유천지 Lv.8
      2015-10-21T17:42:09+09:00답변 등록 답변 등록 일시 2015-10-21 5:42 pm
       ; (if (or (= (cdr (assoc 0 aa)) “arc”) (= (cdr (assoc 0 aa)) “CIRCLE”))
      2015-10-21T17:55:43+09:00답변 등록 답변 등록 일시 2015-10-21 5:55 pm
      무슨말씀인지 잘 모르겠어요.ㅜㅜ
      2015-10-22T08:19:51+09:00답변 등록 답변 등록 일시 2015-10-22 8:19 am
      아하… 감사합니다. 최단거리두 수정이 가능할까요? 홀을 여러개 찍었을때 가까운곳에 있는거 부터 먼저 좌표가 찍히게끔…가능할까요..?
      2015-10-22T08:21:13+09:00답변 등록 답변 등록 일시 2015-10-22 8:21 am
      아하… 감사합니다. 여러개 찍었을때 가까운곳부터 찍고들어가는건데 제가 말을 이상하게 적었나봐요 ㅠㅠ
