홈/ 질문/Q 30790
등록일: 2002-05-122002-05-12T18:03:18+09:00 2002-05-12T18:03:18+09:00카테고리: AutoCAD & CADian
도와주세여… ㅡ.ㅜ
AutoCAD Alert
The NLS files required to convert
the text entities and symbol table
names in your drawing from code page
ANSI_932 to ANSI_949 cannot be found
or are not installed in your system.
AutoCAD can try to cannot text entities
and symbol table names using the default
system code page; however, this might
result in loss of imformation To install
the missing NLS files, double-click
the Regional Settings icon in the Windows
Control Pannel.
무슨내용인지좀 갈켜주시고여…
어떻게 해결해야하는지도여…
제발 님들아…
답변 부탁합니다… ^^*
  • 29 조회
      2002-05-12T23:25:07+09:00답변 등록 답변 등록 일시 2002-05-12 11:25 pm
      -_- 헉시 증상이 다운대져? 나두 저런적있었는디… 더블클릭해서 그런거 아닌가..;;
