홈/ 질문/Q 113388
등록일: 2021-10-122021-10-12T13:08:04+09:00 2021-10-12T13:08:04+09:00카테고리: AutoCAD & CADian
블록 리스트 엑셀이나 텍스트 파일로 가져올 수 있는 리습
안녕하세요 🙂
캐드에서 renname 명령어를 입력하면 블록 이름들이 리스트로 쭉 나오는데 그 리스트를 엑셀이나 텍스트로 가져올 수 있는 리습이 있을까요 ? ㅠ
  • 196 조회
    2. bee누 Lv.0
      2021-11-25T16:45:07+09:00답변 등록 답변 등록 일시 2021-11-25 4:45 pm
      파일첨부 안되어서 리습짜집기로 만들어봤어요
      (defun c:bbb(/)
      (vlax-for Blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
        (entmake (list ‘(0 . “MTEXT”) ‘(100 . “AcDbEntity”) ‘(100 . “AcDbMText”)
                 (cons 10 (list 0.0 0.0 0.0)) (cons 40 20)
                 (cons 1 (strcat (vla-get-name blk)
                 (cons 7 (getvar “TEXTSTYLE”)) ))
      (command “zoom” “w” “-50,-50” “200,200”)
      (aa)
      ;;   Text to Excel
      ;;      Made By……….   TaeEun  -_-)=b
      ;;          Contact Me…….   arin9916@naver.com
      ;;                          …   http://cafe.naver.com/ptelisp
      ;;          Client………..   Gocad
      ;;            Date………….    2012-04-15
      (defun aa( / objs doc tol excel cell str x y PTE:sortobj LM:UnFormat)
          ;    Sub-function – 01
          (defun PTE:sortobj
              (   olst typ tol /
                  typ objs opt npt lst data lst rev sx sy dxf x y
                  PTE:s1 PTE:s2 PTE:s3 PTE:s4
              (defun rev (ls f) (mapcar ‘(lambda (l)(if (setq f (not f)) (reverse l) l)) ls))
              (defun sx  (objs) (vl-sort objs ‘(lambda (a b) (< (x a) (x b)))))
              (defun sy  (objs) (vl-sort objs ‘(lambda (a b) (< (y a) (y b)))))
              (defun dxf (o c)  (cdr  (assoc c (entget (vlax-vla-object->ename o)))))
              (defun x   (o)    (car  (dxf o 10)))
              (defun y   (o)    (cadr (dxf o 10)))
              (setq typ (vl-string->list (strcase typ)))
              (if (member (car typ) ‘(76 82))
                  (setq PTE:s1 sy PTE:s2 y PTE:s3 sx PTE:s4 rev)
                  (setq PTE:s1 sx PTE:s2 x PTE:s3 sy PTE:s4 rev)
              (setq objs (PTE:s1 olst) opt (PTE:s2 (car objs)))
              (foreach o objs
                  (if (< tol (abs (- (setq npt (PTE:s2 o)) opt)))
                      (setq lst  (cons data lst) data (list o) opt npt)
                      (setq data (cons o data))
              (setq lst (mapcar ‘(lambda (l) (PTE:s3 l))(cons data lst))
                    lst (if (member (cadr typ) ‘(85 82)) (reverse lst) lst)
                    lst (if (member (car typ)  ‘(68 76)) (mapcar ‘(lambda (l) (reverse l)) lst) lst)
                    lst (if (/= (car typ) (caddr typ))(PTE:s4 lst t) lst)
          ;    Sub-function – 02
          (defun LM:UnFormat ( str mtx / _Replace regex )
              ;; и╧ Lee Mac 2010
              (defun _Replace ( new old str )
                  (vlax-put-property regex ‘pattern old) (vlax-invoke regex ‘replace str new)
              (setq regex (vlax-get-or-create-object “VBScript.RegExp”))
              (mapcar
                  (function
                      (lambda ( x ) (vlax-put-property regex (car x) (cdr x)))
                  (list (cons ‘global actrue) (cons ‘ignorecase acfalse) (cons ‘multiline actrue))
              (mapcar
                  (function
                      (lambda ( x ) (setq str (_Replace (car x) (cdr x) str)))
                      (“ив”       . “\\\\”)
                      (” ”       . “\\P|\n|\t”)
                      (“$1”      . “\\(\\[ACcFfHLlOopQTW])|\\[ACcFfHLlOopQTW][^\\;]*;|\\[ACcFfHLlOopQTW]”)
                      (“$1$2/$3” . “([^\\])\\S([^;]*)[/#\^]([^;]*);”)
                      (“$1$2”    . “\\(\\S)|[\\](})|}”)
                      (“$1”      . “[\\]({)|{“)
              (setq str
                  (if mtx
                      (_Replace “\\” “ив” (_Replace “\$1$2$3” “(\\[ACcFfHLlOoPpQSTW])|({)|(})” str))
                      (_Replace “\”   “ив” str)
              (vlax-release-object regex)
              str
          ;    Main function
          (ssget ‘((0 . “text,mtext”)))
          (setq doc  (vla-get-activedocument (vlax-get-acad-object))
                objs (vlax-for o (vla-get-activeselectionset doc) (setq objs (cons o objs)))
                tol  (car (vl-sort (mapcar ‘vla-get-height objs) ‘<))
                objs (PTE:sortobj objs “rdr” tol)
          (or (setq excel(vlax-get-or-create-object “Excel.Application”))
              (alert “Fail to Excel load”) (exit)
          (vlax-invoke-method (vlax-get-property excel ‘Workbooks) ‘Add)
          (vlax-put Excel ‘visible :vlax-true)
          (setq cell (vlax-get-property (vlax-get-property excel ‘ActiveSheet) ‘Cells)
                x 1 y 1
          (foreach os objs
              (foreach o os
                  (setq str
                      (if (= (vla-get-objectname o) “AcDbText”)
                          (vla-get-textstring o)
                          (LM:UnFormat (vla-get-textstring o) nil)
                  (vlax-put-property cell ‘item y x (strcat “‘” str))
                  (setq y (1+ y))
              (setq y (1+ y) x 1)
          )(princ)
      )(vl-load-com)
