홈/ 질문/Q 96167
등록일: 2012-09-162012-09-16T15:20:21+09:00 2012-09-16T15:20:21+09:00카테고리: AutoCAD & CADian
갑자기 안되요…
기존에 쓰던 리습인데 원안에 숫자가 차례로 넣는 리습인데..
원만 나오고 숫자가 안보입니다..
머가 문제 일까요??
(DEFUN C:BT()
  (defun SETERR(s)
    (if (/= s “Function cancelled”)
        (princ (strcat “nError: ” s))
    ); of If
    (setq *error* oer seterr nil)
  ); of SETERR
  (setq oer *error* *error* seterr)
  (setvar “cmdecho” 0)
  ;(setq sn (getint “nStart Number : “))
  (setq sn 1)
  (initget “Box Circle None”)
  (setq cbn (getkword “nBox/Circle/<None>: “))
  (setq th (getvar “textsize”))
  (princ “nPick text/Text height<“)
  (princ th)
  (initget “Pick”)
  (setq txth (getdist “>: “))
  (cond
      ((= txth nil) (setq txth th))
      ((= txth “Pick”)
          (progn
              (setq txth (cdr (assoc 40 (entget (car (entsel “Pick text”))))))
              (princ “Text height is “)
              (princ txth)
          ) ;of progn
      ) ;of cond txth=”Pick”
  ) ;of cond
  (setq num sn)
  (princ “nNumber”)
  (princ num)
  (initget “Change”)
  (while (setq pnt (getpoint “, ChangeNum/<Pick point>: “))
      (if (= pnt “Change”)
          (setq num (getint “Enter New Number”))
          (progn
              (setq txt (itoa num))
              (command “text” “j” “m” pnt txth “” TXT)
              (setq bh (* 1.2 txth))
              (cond
                  ((= cbn “Circle”) (command “CIRCLE” pnt bh))
                  ((= cbn “Box”)
                      (progn
                          (setq lu (list (- (car pnt) bh) (+ (cadr pnt) bh)))
                          (setq ru (list (+ (car pnt) bh) (+ (cadr pnt) bh)))
                          (setq rl (list (+ (car pnt) bh) (- (cadr pnt) bh)))
                          (setq ll (list (- (car pnt) bh) (- (cadr pnt) bh)))
                          (command “pline” lu ru rl ll “c”)
                      ) ;of progn
                  ) ;of cond cbn=”Box”
              ) ;of cond
              (setq num (+ num 1))
          ) ;of progn
      ) ;of if pnt=”Change”
      (princ “nNumber”)
      (princ num)
      (initget “Change”)
  ) ; of while
);;; End of program
수정부탁드림니다..
  • 23 조회
