홈/ 질문/Q 113706
곧ㅎ캐드
곧ㅎ캐드Lv.1
등록일: 2022-04-012022-04-01T08:42:07+09:00 2022-04-01T08:42:07+09:00카테고리: AutoCAD & CADian
고급속성블록 값 정리
안녕하세요 고급속성블록 테이블 이 토적등등 지반고 터파기량 등등 있는데 이것을 표,(객체 등등) 으로 발라내는 방법이있을까요? burst 로 꺠서 적고있는데 너무 비효율적인거같아서 문의드립니다.
감사합니다
  • 166 조회
    2. 기남씨 Lv.6
      2022-04-01T10:44:30+09:00답변 등록 답변 등록 일시 2022-04-01 10:44 am
      구글 검색해서 찾은건데 테스트는 못 해봤어요.
      (Defun c:attable (/ at>att at>item at>set atable cnt cw ena nc nr pt rh)
         (vl-load-com)
         ;; GET_ATTS BY BILL KRAMER
         (defun get_ATTS (EN / EL ATTS)
      (setq EL (entget EN))
      (setq ENA (cdr (assoc 2 EL))) ; wiz
      (if (and (= (cdr (assoc 0 EL)) “INSERT”)
      (= (cdr (assoc 66 EL)) 1)
          ) ;_ end and
          (progn
      (setq EN (entnext EN)
            EL (entget EN)
      ) ;_ end setq
      (while (= (cdr (assoc 0 EL)) “ATTRIB”)
          (setq ATTS (cons (list
      (vla-get-ObjectID
           (vlax-ename->vla-object EN)
      ) ; wiz
      (cdr
           (assoc 2 EL)
      ) ;_ end_cdr
      (cdr (assoc 1 EL))
           ) ;_ end_list
           ATTS
             ) ;_ end_cons
        EN   (entnext EN)
        EL   (entget EN)
          ) ;_ end setq
      ) ;_ end while
      (list ena (reverse ATTS)) ; wiz
          ) ;_ end progn
      ) ;_ end if
         ) ;_ end_defun
         (if (setq at>set (ssget ‘((0 . “INSERT”))))
      (progn
          (setq at>att
           (mapcar ‘get_atts
           (vl-remove-if
      ‘listp
      (mapcar ‘cadr (ssnamex at>set))
           ) ;_ end_vl-remove-if
           ) ;_ end_mapcar
          ) ;_ end_setq
          (setq PT (getpoint “nTable insertion point: “)
        RH (* 2.0 (getvar “TEXTSIZE”))
        CW (* 20.0 (getvar “TEXTSIZE”))
        NR (+ 2 (length at>att))
        NC (1+ (length (cadar at>att)))
          ) ;_ end_setq
          (setq
      aTable (vla-addtable
         (vla-get-modelspace
             (vla-get-activedocument
         (vlax-get-acad-object)
             ) ;_ end_vla-get-activedocument
         ) ;_ end_vla-get-modelspace
         (vlax-3d-point PT)
         NR
         NC
         RH
         CW
             ) ;_ end_vla-addtable
          ) ;_ end_setq
          (vla-setcellvalue aTable 0 0 “B.O.M.”)
          (vla-setcellvalue aTable 1 0 “Block Name”)
          (vla-setcellvalue aTable 1 1 “Attributes”)
          (vla-MergeCells aTable 1 1 1 (length (cadar at>att)))
          (setq CNT 2) ;_ end_setq
          (foreach Item at>att
      (vla-setcellvalue aTable CNT 0 (car Item))
      (setq at>item 1)
      (while (<= at>item (length (cadar at>att)))
          (vl-catch-all-apply
      ‘(lambda ()
           (vla-settext
      aTable
      CNT
      at>item
      (strcat
           “%<\AcObjProp Object(%<\_ObjId “
           (itoa (car (nth (1- at>item) (cadr Item))))
           “>%).TextString>%”
      ) ;_ end_strcat
           ) ;_ end_vla-setcellvalue
      ) ;_ end_lambda
          ) ;_ end_vl-catch-all-apply
          (setq at>item (1+ at>item))
      ) ;_ end_while
      (setq CNT (1+ CNT))
      ;;ready next row
          ) ;_ end_foreach
      ) ;_ end_progn
         ) ;_ end_if
      ) ;_ end_Defun
      원본링크는 여기…
      https://www.cadtutor.net/forum/topic/26631-making-a-bom-list-from-blocks-with-attributes/
    3. 곧ㅎ캐드 Lv.1
      2022-04-13T14:29:41+09:00답변 등록 답변 등록 일시 2022-04-13 2:29 pm
      감사합니다
