홈/ 질문/Q 96861
등록일: 2012-12-132012-12-13T11:28:15+09:00 2012-12-13T11:28:15+09:00카테고리: AutoCAD & CADian
고수님들 리습 수정 부탁드립니다..
배열 리습인데요 잠긴 레이어까지 같이 잡혀서 배열이 안됩니다.
잠긴 레이어 제외하고 하는 방법을 몰라서 그러는데 고수님들 부탁드립니다.
(defun c:arrv ( / ss->list copyv dx gr nl nx obs obx p0 pd pw px vx ) (vl-load-com)
  ;; Lee Mac 2011
  (defun ss->list ( ss / i l )
    (if ss
      (repeat (setq i (sslength ss))
        (setq l (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) l))
  (defun copyv ( ob n v / i b l ) (setq i 1 b (vlax-3D-point ‘(0. 0. 0.)))
    (repeat n
      (foreach obj ob
        (vla-move (car (setq l (cons (vla-copy obj) l))) b (vlax-3D-point (mapcar ‘* v (list i i i))))
      (setq i (1+ i))
    l
  (if
    (and
      (setq obs (ss->list (ssget ‘((0 . “~VIEWPORT”)))))
      (setq p0  (getpoint “nBase Point: “))
      (setq px  (getpoint “nArray Vector: ” p0))
      (setq pw  (trans p0 1 0)
            pd  (trans p0 1 3)
            vx  (trans (mapcar ‘- px p0) 1 0) dx (distance ‘(0. 0. 0.) vx)
      (not (equal dx 0.0 1e-14))
      (princ “nArray Endpoint: “)
    (while (= 5 (car (setq gr (grread ‘t 13 0)))) (redraw)
      (setq obx (car (mapcar ‘vla-delete obx))
            nx  (fix (setq nl (/ (caddr (trans (setq gr (mapcar ‘- (cadr gr) p0)) 1 vx)) dx)))
            obx (copyv obs (abs nx) (mapcar (if (minusp nx) ‘- ‘+) vx))
      (grvecs (list -3 ‘(0. 0. 0.) (mapcar ‘* (trans vx 0 3) (list nl nl nl)))
        (list
          (list 1. 0. 0. (car   pd))
          (list 0. 1. 0. (cadr  pd))
          (list 0. 0. 1. (caddr pd))
          (list 0. 0. 0. 1.)
  (redraw) (princ)
  • 30 조회
    • cadplus_plot 사용방법 질문드립니다
