홈/ 질문/Q 102955
등록일: 2014-12-162014-12-16T13:49:50+09:00 2014-12-16T13:49:50+09:00카테고리: AutoCAD & CADian
단열재 그리기 리습 오류 입니다.
(defun c:direc()
(graphscr)
        (setvar “blipmode” 1)
        (setq sp1 (getpoint “nStart point : “))
        (setq om (getvar “orthomode”))
        (setvar “orthomode” 1)
        (setq sp2 (getpoint sp1 “nEnd point : “))
        (command “line” sp1 sp2 “” )
        (setq l_direc (angle sp1 sp2))
        (setq sp1x (car sp1 )
              sp1y (cadr sp1 )
              sp2x (car sp2 )
              sp2y (cadr sp2 ))
        (command “ucsicon” “off”)
        (command “ucs” “o” sp1)
        (command “ucs” “z” (rtd l_direc))
        (setq lp (getpoint “nSide to drawing: “))
        (command “erase” “l” “” )
        (setvar “orthomode” om)
        (setvar “blipmode” 0)
        (setq lpx (car lp )
              lpy (cadr lp ))
        (command “ucs” “”)
        (command “ucsicon” “on”)
        (if (> lpy 0)
                (setq direc (+ l_direc (* 0.5 pi)))
                (setq direc (- l_direc (* 0.5 pi)))
        (setq l_direc1 l_direc
              l_direc2 (+ l_direc  pi))
;********************** Insulation drawing*************************
(defun c:insu(/ stp1 sp3 stp2 sp4 stp3 sp1 stp4 sp2
                ea v_eq eq pp qq p0 p1 p2 p3 q0 q1 q2 q3
                width length)
   (graphscr)
   (setvar “cmdecho” 0)
   (COMMAND “UCS” “W”)
   (SETQ t1 (MGET “nWidth of Insulation :” 75.0 3))
   (c:direc)
   (setq osm (getvar “osmode”))
   (setvar “osmode” 0)
   (setq sp3 (polar sp1 direc t1))
   (setq sp4 (polar sp2 direc t1))
;******************** Aux points***************************
        (if (< lpy 0)
                (setq  stp1 sp3 stp2 sp4 stp3 sp1 stp4 sp2
                       direc (+ direc pi))
                (setq  stp1 sp1 stp2 sp2 stp3 sp3 stp4 sp4)
        (setq culr (getvar “clayer”))
        (command “layer” “s” “insulation” “” “”)
        (command “pline” stp1 stp3 stp4 stp2 “c”)
           (setq width t1
                 length (distance sp1 sp2))
           (setq v_eq (/ width 4))
           (setq ea (fix (/ length v_eq)))
           (setq eq (/ (/ length ea) 2))
           (setq pp (polar stp1 direc eq))
           (setq qq (polar stp1 direc (- width eq)))
;******************** Start Arc dwg ***************************
   (setq lp1 (polar stp1 direc (- width eq )))
   (setq q1 (polar qq l_direc eq))
   (command “arc” “c” lp1 q1 “a” “90”)(P-ADD)
;******************** Repeat ***************************
   (repeat  ea
           (setq p0 nil p1 nil p2 nil p3 nil q0 nil q1 nil q2 nil q3 nil)
           (setq p0 (polar pp l_direc 0))
           (setq p1 (polar p0 l_direc eq))
           (setq p2 (polar p1 l_direc eq))
           (setq p3 (polar p2 l_direc eq))
           (setq q0 (polar qq l_direc 0))
           (setq q1 (polar q0 l_direc eq))
           (setq q2 (polar q1 l_direc eq))
           (setq q3 (polar q2 l_direc eq))
           (command “line” p0 q1 “”)(P-ADD)
           (command “line” q1 p2 “”)(P-ADD)
           (command “arc” “c” p1 p0 p2)(P-ADD)
           (command “arc” “c” q2 q3 q1)(P-ADD)
           (setq pp (polar p1 l_direc eq))
           (setq qq (polar q1 l_direc eq))
    (command “break” “l” q3 stp4)
    (command “layer” “s” culr “”)
    (setq direc nil)
    (setq l_direc nil)
    (command “_.pedit” “_M” ss “” “_Y” “_J” “” “”)
    (setvar “osmode” osm)
(defun p-add ()
     (if (not ss) (setq ss (ssadd)))
     (ssadd (entlast) ss)
(defun rtd (a) (/ (* a 180.0) pi))
위에는 단열재 그리기 리습을 구해서 적용해보는데 오류가 납니다.
따로 파일이 필요한건지 궁금하네요.
그리고 아래 첨부파일은 여기서 찾은 리습인데요.
이거 간격수정 어떻게 하나요?
안에 값을 수정하라하는데 뭘 수정해야할 지 모르겠습니다.
간격이 벌어진 단열재 말고 완전이 붙어있는 단열재를 그리고 싶습니다.
  • 126 조회
    • 캐드 마우스 커서이동, 명령어 입력, 그래그 등 버벅거림 도와주세요,.,,
