홈/ 질문/Q 112211
장정아
장정아Lv.0
등록일: 2020-03-162020-03-16T11:23:57+09:00 2020-03-16T11:23:57+09:00카테고리: AutoCAD & CADian
단열재 리습 간격
위 그림처럼 1번이 현재 리습이고 2번 형태로 바꾸고 싶은데 무엇을 수정해야하나요?
(defun c:iu(/ myerror os bl cl pt1 pt2 pt3 pt4 pt5 pt6 pt7 thi angX angY angZ n di
              b1 b2 b3 b4 p1 p2 p3 p4 p5 p6 p7 p8 P9 p10 f1 f2)
   (command “undo” “group”)
   (setvar “cmdecho” 0)
   (setq os (getvar “osmode”))
   (setq bl (getvar “blipmode”))
   (setq cl (getvar “clayer”))
;—————– Internal error handler ——————-
 (defun myerror(S)
  (if (/= s “Function cancelled”)
      (princ (strcat “nError:” s))
  (setq *error* olderr)
  (setvar “osmode” os)
  (setvar “clayer” cl)
;  (setvar “blipmode” bl)
 (setq olderr *error* *error* myerror)
;   (setvar “blipmode” 0)
   (if (/= nil)
    (while ;엔터입력전까지 반복적구문 시작
     (setvar “osmode” 33)
     (setq pt1 (getpoint “n단열재 시작점(방향:좌->우)… : “))
     (setvar “osmode” 128)
     (setvar “orthomode” 1)
     (setq pt2 (getpoint pt1 “n단열재두께로 될 다음점 or 방향잡고 두께입력… : “))
     (setq th (distance pt1 pt2))
     (setvar “osmode”129)
     (setq pt3 (getpoint pt1 “n단열재 끝나는 점… : “))
     (setq pt4 pt1)
     (setvar “blipmode” 0)(setvar “osmode” 0)
    (if (= th nil) (setq th 50))
     (setq thi (getdist (strcat “n두께 <“(rtos th 2 0)”> 맞으면=> enter!!  ” “”)))
    (if (= thi nil) (setq thi th))
     (setq sc (/ thi 50))
     (setq angX (angle pt1 pt3) angY (angle pt1 pt2))
     (setq di (distance pt1 pt3))
     (setq n (/ di (* sc 25)) )
;   (laset “etc”)
     (setq b1 (polar pt1 angY (* sc 12.5))
           b2 (polar pt1 angY (* sc 20))
           b3 (polar pt1 angY (* sc 30))
           b4 (polar pt1 angY (* sc 37.5))
           b5 (polar pt1 angY (* sc 50)))
     (setq p1 (polar b1 angX (* sc 12.5))
           p2 (polar b2 angX (* sc 9.98))
           p3 (polar b3 angX (* sc 2.5))
           p4 (polar b4 angX (* sc 0))
     p5 (polar b5 angX (* sc 12.5))
           p6 (polar b4 angX (* sc 25))
           p7 (polar b3 angX (* sc 22.5))
           p8 (polar b2 angX (* sc 15.03))
           p9 (polar b1 angX (* sc 12.5))
           p10 (polar pt1 angX (* sc 25.00)))
     (command “layer” “m” “A-INS” “c” “red” “” “s” “A-INS” “”)
     (command “pline” pt1 “a” “s” p1  p2  p3  p4  p5  p6  p7  p8  p9  p10 “”)
    (while (>= n 1)
     (setq pt1 p10)
     (setq p10 (polar pt1 angX (* sc 25.00)))
     (command “copy” “l” “” pt1 p10)
     (setq n (- n 1))
    );while end
     (command “LAYER” “OFF” “*” “Y” “”);단열재 레이어와 연결방지
     (command “layer” “ON” “insul” “”);단열재 레이어만 켜기
     (setq f1 (polar pt4 angY sc))
     (setq f2 (polar pt3 angY sc))
     (command “pedit” “l” “j” “f” f1 f2 “” “” “”)
     (command “draworder” “l” “” “back” )
     (setq th thi);trim 구문시작
     (setvar “osmode” 0)
     (setvar “orthomode” 0)
     (setq angZ (/ pi 2.05))
     (setq pt6 (polar pt3 (+ angX angZ) th))
  (setq pt7 (polar pt3 (+ angX pi) (* th 0.01)));또 다른단열재와 trim시 문제로 생성
  (setq pt5 (polar pt7 (+ angX (/ pi 2)) th))
     (command “laymcur”  “l” “”);insul현재레이어설정
     (command “line” pt7 pt5 “”)
     (command “trim” “l” “” “f” pt7 pt6 “” “”);여유단열재제거
     (command “erase” “p” “” );라인제거
     (command “layer” “on” “*” “”) ;모든레이어켜기
     (command “layer” “thaw” “*” “”)
     (command “undo” “en”)
    );while end-전체반복구문
    );if
   (if (= nil)
 (princ “/n단열재그리기종료”)
 );if end-nil
    (prin1)
  • 160 조회
    • 오토캐드 호그리기 질문
    • 뷰포트가 모형->배치로 이동했을때 화면 내에 있던 것만 보여요
      2020-03-27T08:08:07+09:00답변 등록 답변 등록 일시 2020-03-27 8:08 am
      ;;  단열재 그리기 (96cho_i)
      (defun c:insul(/ myerror os bl cl pt1 pt2 pt3 pt4 thi angX angY n di
                    b1 b2 b3 b4 p1 p2 p3 p4 p5 p6 p7 p8 f1 f2)
       (defun myerror(S)
         (setvar “blipmode” 1) (setvar “osmode” 33)
         (setq pt1 (getpoint “n그리기 시작점 선택-> end<int> of “))
         (setq pt2 (getpoint pt1 “n단열재 두께 방향 선택-> per of “))
         (setvar “osmode” 129)
         (setq pt3 (getpoint pt1 “n그리기 끝점 선택-> end<per> of “))
         (setq pt4 pt1)
         (setq thi (getdist (strcat “n단열재 두께<“(rtos th 2 0)”>:”)))
      ;   (laset “etc”)
         (setq b1 (polar pt1 angY (* sc 4.32))
               b2 (polar pt1 angY (* sc 13.55))
               b3 (polar pt1 angY (* sc 36.45))
               b4 (polar pt1 angY (* sc 50.00)))
         (setq p1 (polar b1 angX (* sc 8.23))
               p2 (polar b2 angX (* sc 9.35))
               p3 (polar b3 angX (* sc 3.15))
               p4 (polar b4 angX (* sc 12.50))
               p5 (polar b3 angX (* sc 21.85))
               p6 (polar b2 angX (* sc 15.65))
               p7 (polar b1 angX (* sc 16.77))
               p8 (polar pt1 angX (* sc 25.00)))
         (command “pline” pt1 “a” “s” p1  p2 “l” p3 “a” “s” p4
                          p5 “l” p6 “a” “s” p7 p8 “”)
         (while (>= n 1)
           (setq pt1 p8)
           (setq p8 (polar pt1 angX (* sc 25.00)))
           (command “copy” “l” “” pt1 p8)
           (setq n (- n 1))
         );while end
         (if (= nm nil) (setq nm “Y”))
         (setq t1 (strcat “n단열재을 pline으로 묶기를 원하는가<” nm “>?:”))
         (setq nmm (getstring t1))
         (if (= nmm “”) (setq nmm nm))
         (setq nmm (strcase nmm))
         (if (= nmm “Y”) (progn
          ));if end
         (setq th thi nm nmm)
         (setvar “clayer” cl) (setvar “blipmode” bl)
         (prin1)
      저는 리습은 잘 모르는데 … 일단 저한테 있는것도 참고 한번 해보시겠어요?
