— 우아님의 글
다름이 아니오라 idw 작업시
부품 리스트에서 항목번호를 CA, CB, … 이런 식으로
나오게 할 수 있나요? 일일이 수정해야만 하나요?
IDW에 문외한인 제가 인벤터 뉴스그룹을 검색해 본 결과
다음과 같은 질의응답이 있던데, 혹시 도움이 될지도…??
“jihuadu” wrote in message
news:f19713b.-1@WebX.maYIadrTaRb…
> Dear All,
> I generated an assembly drawing. In the assembly I have 4 different parts
> that are slightly different. But I would like to call them the same part
> in the drawing and Quantity 4. However in the part list I created, they are
> different parts. I can hide 3 of them but the quantity would not be right.
> Could anybody help.
> Thanks in advance.
> Jihua
저도 알고 싶은데요….혹시 아시면 공유좀…
— 우아님의 글
다름이 아니오라 idw 작업시
> Dear All,
> Could anybody help.
> Thanks in advance.
> Jihua
Reply From: Zander, Quinn
Date: Oct/28/03 – 08:59 (GMT)
Re: How can I change quantity in the part list
Once you have your Parts list placed, go to Format->Standards->Parts List tab
and select “Unique Row Identifier”.
Within the iProperties of the 4 “different” parts, name an iProperty
(that will be displayed in the Parts list) identical between the parts.
Call this iProperty heading in the “Unique Row Identifier” dialog box.
Keep in mind all 3 rows MUST be filled in…. they can all be the same
if need be.
QBZ
감사드립니다만 이건 행병합에 대한 얘기인듯 합니다만…
