홈/ 질문/Q 109969
등록일: 2018-06-222018-06-22T10:16:34+09:00 2018-06-22T10:16:34+09:00카테고리: AutoCAD & CADian
리습검토좀 해주세요
(defun c:elbowd (/ dia rad spa deg spa1 pt1 dia2 rad1 deg1 slope pp1 pp2 pp3 pp4 pl1 pl2 thk)
  (setvar “cmdecho” 0)
  (setvar “orthomode” 1)
  (setvar “osmode” 0)
  (setvar “cecolor” “3”)
  (setq dia 1000
        thk 6
        rad (* dia 1.5)
        spa 60
        deg 90
        spa1 4)
  (setq pt1 (getpoint “n Base Point >”))
  (princ “n Duct center 직경을 입력하세요 < “)(princ dia)
  (setq dia (getreal ” > : “))
  (if (= nil dia) (setq dia 1000))
  (princ “n Duct center 두께를 입력하세요 < “)(princ thk)
  (setq thk (getreal ” > : “))
  (if (= nil thk) (setq thk 6))
  (setq rad (* dia 1.5))
  (princ “n Elbow 반지름을 입력하세요 < 1.5D = “)(princ rad)
  (setq rad (getreal ” > : “))
  (if (= nil rad) (setq rad (* dia 1.5)))
;; duct bending 직경산출 (=dia-thk)
  (setq dia (- dia thk))
  (princ “n 등분수를 입력하세요 < “)(princ spa)
  (setq spa (getreal ” > : “))
  (if (= nil spa) (setq spa 60))
  (princ “n Elbow 각도를 입력하세요 < “)(princ deg)
  (setq deg (getreal ” > : “))
  (if (= nil deg) (setq deg 90))
  (princ “n Elbow 편수를 입력하세요 < “)(princ spa1)
  (setq spa1 (getreal ” > : “))
  (if (= nil spa1) (setq spa1 4))
;  (setq dia2 (/ dia 2))
  (setq rad1 (* (tan (dtr (/ deg spa1))) (- rad (/ dia 2))))
  (setq dia1 (/ (* dia pi) spa))
  (setq deg1 (/ 360 spa))
  (setq pp1 (polar pt1 (dtr 90) (* (- rad (/ dia 2)) (tan (dtr (/ 90.0 (* spa1 2)))))))
  (command “pline” pt1 pp1 “”)
  (setq pl1 (ssget “l”))
  (repeat (/ spa 2)
    (progn
      (setq slope (abs (- (/ dia 2) (* (/ dia 2) (cos (dtr deg1))))))
      (setq pp2 (polar pp1 0 dia1))
      (setq pp3 (polar pp2 (dtr 90) (* (tan (dtr (/ 90.0 (* spa1 2)))) slope)))
      (setq deg1 (+ deg1 (/ 360 spa)))
      (command “pline” “” pp3 “”)
      (command “pedit” “l” “j” pl1 “” “”)
      (setq pp1 pp2)
   ));;end repeat
  (command “mirror” “l” “” pt1 (polar pt1 0 (/ (* dia pi) 2)) “”)
  (command “mirror” “l” “” pp3 (polar pt1 0 (/ (* dia pi) 2)) “”)
  (setvar “cecolor” “bylayer”)
  (setvar “osmode” 37)
);;end defun
  • 42 조회
      2018-06-22T11:50:06+09:00답변 등록 답변 등록 일시 2018-06-22 11:50 am
      제일 댓글 달기 싫은 글이 이런거죠.
      공부하다 안되서 물어보는 것도 아니고…
      어디서 줏어왔는데, 입맛에 맛게 고쳐주세요.
      아니면 그냥 안돼요.
      뭐가 어떻게 안된단 말도 없고…
      내가 하려면 공부해야하니 시간걸리고, 어렵고 귀찮고.
      줄은 엄청 긴데, 누가 해서 떠 먹여줬으면 좋겠고.
