홈/ 질문/Q 113833
Saintlusia
SaintlusiaLv.0
등록일: 2022-06-172022-06-17T10:05:11+09:00 2022-06-17T10:05:11+09:00카테고리: AutoCAD & CADian
리습 명령어 오류 질문있습니다
(defun C:lay ()
(command “layer” “n” “001” “s” “001” “c” “1” “001” “l” “centerx2” “001” “” )
(command “layer” “n” “002” “s” “002” “c” “2” “002” “l” “hiddenx2” “002” “” )
(command “layer” “n” “003” “s” “003” “c” “3” “003” “l” “continuous” “003” “” )
(command “layer” “n” “004” “s” “004” “c” “4” “004” “l” “continuous” “004” “” )
(command “layer” “n” “005” “s” “005” “c” “5” “005” “l” “continuous” “005” “” )
(command “layer” “n” “006” “s” “006” “c” “6” “006” “l” “phantomx2” “006” “” )
(command “layer” “n” “007” “s” “007” “c” “7” “007” “l” “continuous” “007” “” )
(command “layer” “n” “008” “s” “008” “c” “8” “008” “l” “continuous” “008” “” )
(command “layer” “n” “009” “s” “009” “c” “9” “009” “l” “continuous” “009” “” )
(command “layer” “n” “010” “s” “010” “c” “10” “010” “l” “continuous” “010” “” )
(command “layer” “n” “025” “s” “025” “c” “25” “025” “l” “hiddenx2” “025” “” )
(command “layer” “n” “025P” “s” “025P” “c” “25” “025P” “l” “phantomx2” “025P” “” )
(command “layer” “n” “040” “s” “040” “c” “40” “040” “l” “continuous” “040” “” )
(command “layer” “n” “0100” “s” “0100” “c” “240” “0100” “l” “centerx2” “0100” “” )
(command “layer” “n” “0200” “s” “0200” “c” “54” “0200” “l” “hiddenx2” “0200” “” )
(command “layer” “n” “0300” “s” “0300” “c” “20” “0300” “l” “continuous” “0300” “” )
(command “layer” “n” “0400” “s” “0400” “c” “140” “0400” “l” “continuous” “0400” “” )
(command “layer” “n” “0500” “s” “0500” “c” “180” “0500” “l” “continuous” “0500” “” )
(command “layer” “n” “0600” “s” “0600” “c” “200” “0600” “l” “phantomx2” “0600” “” )
(command “layer” “n” “WJ-DIM” “s” “WJ-DIM” “c” “010” “WJ-DIM” “l” “continuous” “WJ-DIM” “” )(prin1))
   (DEFUN C:1  () (COMMAND “LAYER” “S” “001” “” “COLOR” “BYLAYER”))
   (DEFUN C:2  () (COMMAND “LAYER” “S” “002” “” “COLOR” “BYLAYER”))
   (DEFUN C:3  () (COMMAND “LAYER” “S” “003” “” “COLOR” “BYLAYER”))
   (DEFUN C:4  () (COMMAND “LAYER” “S” “004” “” “COLOR” “BYLAYER”))
   (DEFUN C:5  () (COMMAND “LAYER” “S” “005” “” “COLOR” “BYLAYER”))
   (DEFUN C:6  () (COMMAND “LAYER” “S” “006” “” “COLOR” “BYLAYER”))
   (DEFUN C:7  () (COMMAND “LAYER” “S” “007” “” “COLOR” “BYLAYER”))
   (DEFUN C:8  () (COMMAND “LAYER” “S” “008” “” “COLOR” “BYLAYER”))
   (DEFUN C:9  () (COMMAND “LAYER” “S” “009” “” “COLOR” “BYLAYER”))
   (DEFUN C:10  () (COMMAND “LAYER” “S” “010” “” “COLOR” “BYLAYER”))
   (DEFUN C:100  () (COMMAND “LAYER” “S” “0100” “” “COLOR” “BYLAYER”))
   (DEFUN C:200  () (COMMAND “LAYER” “S” “0200” “” “COLOR” “BYLAYER”))
   (DEFUN C:300  () (COMMAND “LAYER” “S” “0300” “” “COLOR” “BYLAYER”))
   (DEFUN C:40  () (COMMAND “LAYER” “S” “040” “” “COLOR” “BYLAYER”))
   (DEFUN C:400  () (COMMAND “LAYER” “S” “0400” “” “COLOR” “BYLAYER”))
   (DEFUN C:500  () (COMMAND “LAYER” “S” “0500” “” “COLOR” “BYLAYER”))
   (DEFUN C:600  () (COMMAND “LAYER” “S” “0600” “” “COLOR” “BYLAYER”))
   (DEFUN C:0  () (COMMAND “LAYER” “S” “WJ-dim” “” “COLOR” “BYLAYER”))
자동으로 레이어를 추가하는 리습이지만
2021 버전에선 작동을하고 2022 버전은 작동하지않습니다
어떻게수정해야할까요??
명령장에서 작동하는거 확인해보니
command “layer” 까진 작동하지만
“n” 부터 알수없는명령어가 되어버립니다
  • 45 조회
