홈/ 질문/Q 112832
등록일: 2021-01-262021-01-26T11:03:20+09:00 2021-01-26T11:03:20+09:00카테고리: AutoCAD & CADian
리습 문의입니다. 윈도우7 32비트에서는 실행이 되긴하는데 윈도우8 64비트에서는 돌아가지가 않네요..
리습 문의입니다. 윈도우 7 32비트에서는 되는데 윈도우 8 64비트에서 ‘잘못된 인수 유형: VLA-OBJECT nil ‘ 오류가 뜹니다. 수정좀 부탁드려도 될까여?
(setvar “cmdecho” 0)
;(setq Ptext “<To도로토적표_090519>”)
;(HEADER Ptext)
(defun c:RTZ()
  ;(SNIPE Ptext)
  (ROAD_SIZE)
(defun c:RTU()
 ; (SNIPE Ptext)
  (ROAD_VALUE_UPDATE)
;—————–table size know
(defun ROAD_SIZE(/ ent1 p1 p2 p1_y p2_y delta_y)
  (princ “n>>>chain txt sample select!”)
  (setq ent1 (ssget))
  (setq p1 (getpoint “n>>>sample Table left up point :”))
  (setq p2 (getcorner p1 “n>>>sample Table right down point :”))
  (setq p1_x (car p1))
  (setq p1_y (cadr p1))
  (setq p2_x (car p2))
  (setq p2_y (cadr p2))
  (setq delta_x (abs (- p1_x p2_x)))
  (setq delta_y (abs (- p1_y p2_y)))
  (setq limit_kk (* delta_y 0.14))
  (from_txt_correct_xy ent1 p1 p2)
  (princ “n”)
  (princ “>>>Table size calculate !”)
  );end of defun
(defun ROAD_VALUE_UPDATE( / ent2 nn1 list_n repeat_n
      chain_num chain_coord_x chain_coord_y
      ent3 left_txt_db right_txt_db
      window_p1 window_p2
      find_txt_db
      right_txt_db left_txt_db bcnt)
  (make_layer)
  (setvar “osmode” 0)
  (vl-load-com)
  (setq bcnt 0)
  (setq ksj_index 0)
  (setq ksj_emp_chain_n 0)
  (setq limit_y limit_kk); 토적표 숫자값중 제외 한계값
  (setq find_txt_db ‘())
  (setq left_value_db ‘())
  (setq right_value_db ‘())
  ;—————–capture point calculate
  (princ “n>>>DAS의 물량박스1로 세팅되어있음”)
  (princ “n>>>Please open write Excel file!~ Are you ready?”)
  (princ “n>>>도로 table select!”)
  (setq ent2 (ssget))
  (the_find_and_that_coord ent2 “NO.”)
  ;—————–excel activate
  (the_excel_open_activate)
  ;—————–one and one window point calculate
  (that_total_searching “총계” 7)
  (setq total_y (+ 5 that_y))
  (setq nn1 0)
  (setq list_n (length find_txt_db))
  (setq repeat_n (/ list_n 4))
  (repeat  repeat_n
    (progn
      (setq chain_num (nth nn1 find_txt_db))
      (setq chain_coord_x (nth (+ nn1 1) find_txt_db))
      (setq chain_coord_y (nth (+ nn1 2) find_txt_db))
      (cal_window_point chain_coord_x chain_coord_y)
      ;—————–recapture and number searching and 분류 and db make
      (setq ent3 (ssget “C” window_p1 window_p2))
      (number_fillter_and_left_right_save ent3)
      (setq nn1 (+ nn1 4))
      (sort_and_save left_txt_db)
      (setq left_value_db ksj_data)
      (sort_and_save right_txt_db)
      (setq right_value_db ksj_data)
      ;—————–excel 해당체인 위치 searching
      (that_chain_searching chain_num 7); road
      (if (= that_y nil)
(progn
  (setq that_chin_y (+ total_y ksj_emp_chain_n))
  (cell_adress_return 1 that_chin_y)
  (excel_cell_write range_00 chain_num)
  (cell_colour_change range_00 6)
  );end of progn
(setq that_chin_y that_y)
);end of if
      ;—————–excel 해당체인에 write
      (road_left_value_input that_chin_y)
      (road_right_value_input that_chin_y)
      ); end of progn
    );enf of repeat
  (princ “n>>>All value update complete!n”)
  (setvar “osmode” 33)
  (vlax-release-object *excel*)
  (vlax-release-object *sheets*)
  (vlax-release-object *worksheet*)
  ;(massage)
  (now_layer)
  ); end of defun
;———————————————————————————————correct value calculate and save
(defun from_txt_correct_xy (ent_tx lu_p rd_p
    / endt_name ent_p ent_coord  ent_coord_x ent_coord_y
    lu_p_x lu_p_y rd_p_x rd_p_y)
  (setq ent_name (ssname ent_tx 0))
  (setq ent_p (entget ent_name))
  (setq ent_coord (cdr(assoc 10 ent_p)))
  (setq ent_coord_x (car ent_coord))
  (setq ent_coord_y (cadr ent_coord))
  (setq lu_p_x (car lu_p))
  (setq lu_p_y (cadr lu_p))
  (setq rd_p_x (car rd_p))
  (setq rd_p_y (cadr rd_p))
  (setq lu_correct_x (abs (- ent_coord_x lu_p_x)))
  (setq lu_correct_x (+ lu_correct_x (* delta_x 0.01)))
  (setq lu_correct_y (abs (- ent_coord_y lu_p_y)))
  (setq lu_correct_y (+ lu_correct_y (* delta_y 0.01)))
  (setq rd_correct_x (abs (- ent_coord_x rd_p_x)))
  (setq rd_correct_x (+ rd_correct_x (* delta_x 0.01)))
  (setq rd_correct_y (abs (- ent_coord_y rd_p_y)))
  (setq rd_correct_y (+ rd_correct_y (* delta_y 0.01)))
  (setq correct_value_db (list lu_correct_x lu_correct_y rd_correct_x rd_correct_y))
  ); end of defun
;————————————————————————————————-chain txt searching and relative data db make
(defun the_find_and_that_coord(ent find_txt /
       n1 n2 n3 ent_name ent_p ent_type
       txt txt_coord kkk)
  (setq n1 (sslength ent))
  (setq n2 0)
  (while (/= n1 n2)
    (progn
      (setq ent_name (ssname ent n2))
      (setq ent_type (cdr(assoc 0 ent_p)))
      (if (= ent_type “TEXT”)
(progn
  (setq txt (cdr (assoc 1 ent_p)))
  (setq txt_head (substr txt 1 3))
  (if (= txt_head find_txt)
    (progn
      (command “change” ent_name “” “p” “c” “2” “”)
      (setq txt_coord (cdr (assoc 10 ent_p)))
      (setq kkk (cons txt txt_coord))
      (setq find_txt_db (append find_txt_db kkk))
      (setq ksj_index (+ ksj_index 1))
    ); end of if
); end of if
      (setq n2 (+ n2 1))
    );end of while
  ); end of defun
;———————————————————————————–capture point calculate
  (defun cal_window_point(x y / window_p1_x window_p1_y window_p2_x window_p2_y)
    (setq window_p1_x (- x  lu_correct_x))
    (setq window_p1_y (+ y  lu_correct_y))
    (setq window_p1 (list window_p1_x window_p1_y))
    (setq window_p2_x (+ x  rd_correct_x))
    (setq window_p2_y (- y  rd_correct_y))
    (setq window_p2 (list window_p2_x window_p2_y))
    (command “rectangle” window_p1 window_p2)
    );end of defun
;————————————————————————–number searching and left number db and right number db make
(defun number_fillter_and_left_right_save(ent / xx1 xx2 ent_name ent_p ent_type txt value txt_coord_x
  txt_coord_y left_txt right_txt txt_coord_y0 dist_y  )
  (setq left_txt_db ‘())
  (setq right_txt_db ‘())
  (setq xx1 (sslength ent))
  (setq xx2 0)
  (while (/= xx1 xx2)
    (progn
      (setq appear_time (rem xx2 30)) ; 10이 커질수록 slow
      (if (= appear_time 0)
(processing1 “Processing”)
      (setq ent_name (ssname ent xx2))
(progn
  (setq value (distof txt 2))
  (setq txt_coord_y0 (cadr (cdr (assoc 10 ent_p))))
  (setq dist_y (abs (- chain_coord_y txt_coord_y0)))
  (if (and (/= value nil) (< limit_y dist_y))
    (progn
      (setq txt_coord_x (car (cdr (assoc 10 ent_p))))
      (setq txt_coord_y (cadr (cdr (assoc 10 ent_p))))
      (if (< txt_coord_x chain_coord_x)
(progn
  (setq left_txt (list ent_name value txt_coord_x txt_coord_y))
  (setq left_txt_db (append left_txt left_txt_db))
  (command “change” ent_name “” “p” “c” “84” “”)
(progn
  (setq right_txt (list ent_name value txt_coord_x txt_coord_y))
  (setq right_txt_db (append right_txt right_txt_db))
  (command “change” ent_name “” “p” “c” “152” “”)
  );end of progn
);end of if – 좌우 분리
      );end of progn
    );end of if – 유효 숫자만
  );end of progn
);end of if – txt 만
      (setq xx2 (+ xx2 1))
      );end of progn
    );end of while
  );end of defun
;————————————————————————–left txt db sort and save
(defun sort_and_save(the_list / the_value_db aa list_nn repeat_nn left_coord_y the_list_coord_y_db
     the_list_coord_y_db_sort
     bb sort_list_nn yyy sss other_n the_value_n the_value)
  (setq the_value_db ‘())
  (setq the_list_coord_y_db ‘())
  (setq aa 3)
  (setq list_nn (length the_list))
  (setq repeat_nn (/ list_nn 4))
  (repeat repeat_nn
    (progn
      (setq coord_y (nth aa the_list))
      (setq coord_y (list coord_y))
      (setq the_list_coord_y_db (append the_list_coord_y_db coord_y))
      (setq aa (+ aa 4))
      ); end of progn
    ); end of repeat
  (setq the_list_coord_y_db_sort (vl-sort the_list_coord_y_db ‘>))
  (setq bb 0)
  (setq sort_list_nn (length the_list_coord_y_db_sort))
  (repeat sort_list_nn
    (progn
      (setq yyy (nth bb the_list_coord_y_db_sort))
      (setq position_yyy (vl-position yyy the_list))
      (setq the_value_n (- position_yyy 2))
      (setq the_value (nth the_value_n the_list))
      (setq the_value (list the_value))
      (setq the_value_db (append the_value_db the_value))
      (setq bb (+ bb 1))
      ); end of progn
    );end of repeat
  (setq ksj_data the_value_db)
  ); end of defun
;——————————————————————————the_excel_activate
;(defun the_excel_open_activate(sheetname /  )
 (defun the_excel_open_activate( /  )
  (if (null msxc-xl24HourClock)
      (vlax-import-type-library
      :tlb-filename “C:/Program Files/Microsoft Office/OFFICE12/XL5EN32.OLB”
      :methods-prefix “msxm-“
      :properties-prefix “msxp-“
      :constants-prefix “msxc-” )
  (setq *excel* (vlax-get-or-create-object “Excel.Application.12”)); 2003은 11 2007은 12
  (setq *sheets* (vlax-get-property *excel* ‘ActiveWorkbook))
  (setq *worksheet* (vlax-get-property *sheets* ‘ActiveSheet))
  ;(msxm-activate *worksheet*)
;——————————————————-cell_adress_trans calcu
(defun cell_adress_return(x y / y_tx)
  (cond
    ((= x 1) (setq Alpabet “A”))
    ((= x 2) (setq Alpabet “B”))
    ((= x 3) (setq Alpabet “C”))
    ((= x 4) (setq Alpabet “D”))
    ((= x 5) (setq Alpabet “E”))
    ((= x 6) (setq Alpabet “F”))
    ((= x 7) (setq Alpabet “G”))
    ((= x 8) (setq Alpabet “H”))
    ((= x 9) (setq Alpabet “I”))
    ((= x 10) (setq Alpabet “J”))
    ((= x 11) (setq Alpabet “K”))
    ((= x 12) (setq Alpabet “L”))
    ((= x 15) (setq Alpabet “O”))
    ((= x 17) (setq Alpabet “Q”))
    ((= x 19) (setq Alpabet “S”))
    ((= x 22) (setq Alpabet “V”))
    ((= x 25) (setq Alpabet “Y”))
    ((= x 28) (setq Alpabet “AB”))
    ((= x 29) (setq Alpabet “AC”))
    ((= x 31) (setq Alpabet “AE”))
    ((= x 32) (setq Alpabet “AF”))
    ((= x 34) (setq Alpabet “AH”))
    ((= x 35) (setq Alpabet “AI”))
    ((= x 37) (setq Alpabet “AK”))
    ((= x 40) (setq Alpabet “AN”))
    ((= x 43) (setq Alpabet “AQ”))
    ((= x 45) (setq Alpabet “AS”))
    ((= x 47) (setq Alpabet “AU”))
    ((= x 51) (setq Alpabet “AY”))
    ((= x 53) (setq Alpabet “BA”))
    ((= x 55) (setq Alpabet “BC”))
    ((= x 57) (setq Alpabet “BE”))
    ((= x 59) (setq Alpabet “BG”))
  (setq y_tx (itoa y))
  (setq cell_adress (strcat Alpabet y_tx))
  (setq range_00 (vlax-get-property *worksheet* ‘Range cell_adress))
;————————————————excel_cell_read
(defun excel_cell_read(cell_obj / cell_obj_value0)
  (setq cell_obj_value0 (vlax-get-property cell_obj ‘Value))
  (setq cell_obj_value1 (vlax-variant-value cell_obj_value0))
  ); end of defun
;————————————————excel_cell_write
(defun excel_cell_write(cell_obj that_value / )
  (vlax-put-property cell_obj ‘value2 that_value)
  ); end of defun
;————————————————that chain searching and cell address y save
(defun that_chain_searching(that_chain_name start_y / search_y search_txt excel_txt)
  (setq search_txt that_chain_name)
  (setq search_y start_y)
  (while (and (/= search_txt excel_txt) (/= total_y search_y))
    (progn
      (cell_adress_return 1 search_y )
      (excel_cell_read range_00)
      (setq excel_txt cell_obj_value1)
      (setq search_y (+ search_y 1))
    ); end of while
  (if (= search_y total_y)
    (progn
      (setq anounce_txt (strcat search_txt “을 찾을 수 없습니다”))
      (alert anounce_txt)
      (setq that_y nil)
      (setq ksj_emp_chain_n (+ ksj_emp_chain_n 1))
      (setq that_y (- search_y 1))
    ); end of if
  ); end of defun
(defun that_total_searching(that_chain_name start_y / search_y search_txt excel_txt)
  (while (/= search_txt excel_txt)
    (progn
    ); end of while
  ); end of if
;————————————————road left value input
(defun road_left_value_input(yyy / value )
  (cell_adress_return 1 yyy)
  (setq value (nth 0 left_value_db))
  (cell_adress_return 34 yyy)
  (excel_cell_write range_00 value)
  (cell_colour_change range_00 50)
  (setq value (nth 1 left_value_db))
  (cell_adress_return 37 yyy)
  (setq value (nth 2 left_value_db))
  (cell_adress_return 31 yyy)
  (setq value (nth 3 left_value_db))
  (cell_adress_return 51 yyy)
  (setq value (nth 4 left_value_db))
  (cell_adress_return 53 yyy)
  (setq value (nth 5 left_value_db))
  (cell_adress_return 55 yyy)
  (setq value (nth 6 left_value_db))
  (cell_adress_return 57 yyy)
  (setq value (nth 7 left_value_db))
  (cell_adress_return 59 yyy)
  (setq value (nth 8 left_value_db))
  (cell_adress_return 40 yyy)
  (setq value (nth 9 left_value_db))
  (cell_adress_return 43 yyy)
  ); end of defun
;————————————————road right value input
(defun road_right_value_input(yyy / value )
  (setq value (nth 0 right_value_db))
  (cell_adress_return 3 yyy)
  (cell_colour_change range_00 37)
  (setq value (nth 1 right_value_db))
  (cell_adress_return 6 yyy)
  (setq value (nth 2 right_value_db))
  (cell_adress_return 9 yyy)
  (setq value (nth 3 right_value_db))
  (cell_adress_return 12 yyy)
  (setq value (nth 4 right_value_db))
  (cell_adress_return 28 yyy)
  (setq value (nth 5 right_value_db))
  (cell_adress_return 17 yyy)
  (setq value (nth 6 right_value_db))
  (cell_adress_return 19 yyy)
  (setq value (nth 7 right_value_db))
  (cell_adress_return 22 yyy)
  (setq value (nth 8 right_value_db))
  (cell_adress_return 25 yyy)
  (setq value (nth 9 right_value_db))
  (cell_adress_return 15 yyy)
  ); end of defun
;————————————————cell colour change
(defun cell_colour_change(cell_obj colourindex / cell_obj_interior cell_obj_interior_c cell_obj_interior_c_v)
  (setq cell_obj_interior (vlax-get-property cell_obj ‘interior))
  (setq cell_obj_interior_c (vlax-get-property cell_obj_interior ‘ColorIndex))
  (setq cell_obj_interior_c_v (vlax-variant-value cell_obj_interior_c))
  (setq cell_obj_interior_c_v (vlax-make-variant colourindex))
  (vlax-put-property cell_obj_interior ‘ColorIndex cell_obj_interior_c_v)
  );end of defun
(defun processing1 (prmpt /)
(Princ
(Nth bcnt ‘(“rProcessing ▶▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▷▷▷▷▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▷▷▷▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▷▷▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▷▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▷▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▷▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▶▷▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▶▶▷▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▶▶▶▷▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▷▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▷▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▷▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▷▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▷”
    “rProcessing ▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶▶”
    “rProcessing ▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷▷”
(setq bcnt (Rem (1+ bcnt) 21))
;—————————————————————————————————————sun function(3):layer make
(defun make_layer()
  (setq layer_name_bit (rtos (getvar “cdate”) 2 0))
  (setq layer_name (strcat “zzz_ksj(” layer_name_bit “)”))
  (command “-layer” “m” layer_name “c” “1” “” “”)
;—————————————————————————————————————sun function(4):layer change
(defun now_layer()
  (command “-layer” “s” now_layer_name “”)
;—————————————————————————–SERIAL_CHECK
(defun SERIAL_CHECK()
  (setq curr_date (getvar “cdate”))
  (setq ymd (rtos curr_date 2 0))
  (setq year (atoi (substr ymd 1 4)))
  (setq month (atoi (substr ymd 5 2)))
  (setq date (atoi (substr ymd 7 2)))
  (setq output_serial (+ year (expt month 2) (* 2 year date) 7777 ))
  (setq tmpop (open “c:/WINKSJ.SYS” “r”))
  (if (= tmpop nil)
    (setq serial_opt 0)
    (progn
      (setq tmpserial (atoi (read-line tmpop)))
      (setq tmpop (close tmpop))
      (if (= output_serial tmpserial)
(setq serial_opt 1)
(setq serial_opt 0)
  • 26 조회
    2. 수야12 Lv.22
      2021-01-26T11:55:31+09:00답변 등록 답변 등록 일시 2021-01-26 11:55 am
      리습은 인터프리터 언어이기 때문에 버전을 타지 않습니다
      오류메세지를 봐서는 객체가 선택이 안됐다는 메세지인데요
      엑셀버전을 확인해보심이 어떨런지요 버전 탈것은 엑셀밖에 없는데요
