홈/ 질문/Q 109483
등록일: 2018-02-262018-02-26T17:01:35+09:00 2018-02-26T17:01:35+09:00카테고리: AutoCAD & CADian
리습 변경 가능하신분.. (VL함수 -> AutoLISP함수 )
2018 LT 버전을 사용하고있습니다.
아이컴툴스에서 지원하는 보조프로그램 을 사용하여 리습 사용중입니다.
밑에 리습은 VL 함수를 사용하여 지원을 못한다고하더군요 ..
혹시 다른식으로 변환을 하여 사용할수있는지 답변부탁드리겠습니다.
;   배열
(defun c:aar ( / ss->list copyv dx gr nl nx obs obx p0 pd pw px vx ) (vl-load-com)
  ;; Lee Mac 2011
  (defun ss->list ( ss / i l )
    (if ss
      (repeat (setq i (sslength ss))
        (setq l (cons (vlax-ename->vla-object (ssname ss (setq i (1- i)))) l))
  (defun copyv ( ob n v / i b l ) (setq i 1 b (vlax-3D-point ‘(0. 0. 0.)))
    (repeat n
      (foreach obj ob
        (vla-move (car (setq l (cons (vla-copy obj) l))) b (vlax-3D-point (mapcar ‘* v (list i i i))))
      (setq i (1+ i))
    l
  (if
    (and
      (setq obs (ss->list (ssget ‘((0 . “~VIEWPORT”)))))
      (setq p0  (getpoint “nBase Point: “))
      (setq px  (getpoint “nArray Vector: ” p0))
      (setq pw  (trans p0 1 0)
            pd  (trans p0 1 3)
            vx  (trans (mapcar ‘- px p0) 1 0) dx (distance ‘(0. 0. 0.) vx)
      (not (equal dx 0.0 1e-14))
      (princ “nArray Endpoint: “)
    (while (= 5 (car (setq gr (grread ‘t 13 0)))) (redraw)
      (setq obx (car (mapcar ‘vla-delete obx))
            nx  (fix (setq nl (/ (caddr (trans (setq gr (mapcar ‘- (cadr gr) p0)) 1 vx)) dx)))
            obx (copyv obs (abs nx) (mapcar (if (minusp nx) ‘- ‘+) vx))
      (grvecs (list -3 ‘(0. 0. 0.) (mapcar ‘* (trans vx 0 3) (list nl nl nl)))
        (list
          (list 1. 0. 0. (car   pd))
          (list 0. 1. 0. (cadr  pd))
          (list 0. 0. 1. (caddr pd))
          (list 0. 0. 0. 1.)
  (redraw) (princ)
  • 105 조회
    2. 수야12 Lv.22
      2018-02-27T18:27:07+09:00답변 등록 답변 등록 일시 2018-02-27 6:27 pm
      ,그리 추천하고픈 방법은 아니지만 command 명령을 사용하여 약간의 버벅임이 있습니다
      ;   배열
      (defun c:ff ( / Sub:Newss copyv dx gr nl nx L obx p0 pd pw px vx L ) (vl-load-com)
        ;; Lee Mac 2011
      (defun Sub:NewSS ( elast / newss enxt)
        (setq enxt elast
            newss (ssadd))
        (while (/= (setq enxt (entnext enxt)) nil)
          (ssadd enxt newss)
        ) newss
        (defun copyv ( ob n v  / i b l  ss ss1 ) (setq i 1 b ‘(0. 0. 0.) ss1 (ssadd))
          (repeat n
              (setq en(entlast))
              (vl-cmdf “copy” ob “” b (mapcar ‘* v (list i i i)))
              (setq ss(Sub:NewSS en)n 0)
              (repeat(sslength ss)
                (ssadd (ssname ss n)ss1)
                (setq n(1+ n))
            (setq i (1+ i))
          ss1
       (setvar ‘cmdecho 0)
        (if
          (and
            (setq obs  (ssget ‘((0 . “~VIEWPORT”))))
                  pd  (trans p0 1 3)
              (if L
                (repeat (setq i (sslength L))
                 (SETQ i (1- i))
                 (setq e (ssname L i))
                 (entdel e)
            (setq
                  L (copyv obs (abs nx) (mapcar (if (minusp nx) ‘- ‘+) vx))
              (list
                (list 0. 0. 0. 1.)
        (redraw)
      (setvar ‘osmode 1)  (princ)
      2018-03-07T11:41:29+09:00답변 등록 답변 등록 일시 2018-03-07 11:41 am
      도움주셔서 감사합니다.
      허나 실행해보니 명령이 먹히질 않네요..
      쪽지 확인부탁드리겠습니다..!
    4. 수야12 Lv.22
      2018-03-09T10:25:36+09:00답변 등록 답변 등록 일시 2018-03-09 10:25 am
      다시 올립니다 리습 무덤인  캐디안에서도 되는거 보니 안될리는 없을꺼 같습니다
      버벅임을 어쩔수 없네요 ㅎㅎ;;
