홈/ 질문/Q 112590
방울도사
방울도사Lv.0
등록일: 2020-10-132020-10-13T11:43:30+09:00 2020-10-13T11:43:30+09:00카테고리: AutoCAD & CADian
리습 자리수 수정좀부탁드립니다.
기본자리수 2로 나오는 면적표를 6자리로 수정좀 부탁드립니다.
;  면적구하기(98주말농부)
;  ->pline이나 내부점을 선택하여 화면에 면적을 자동으로 표기(사사오입)
;  ->설정값변경 옵션추가/자리수 선택가능(2007.5.11)
;;—— quick area —————————————————
(defun c:qa(/ os ot ts ht a yn tem ent1 en1 grpt pt1 ar1 ar2 ar3)
;->*error* start
 (defun *error* (msg)(princ “error: “)(princ msg)
 (setvar “osmode” os)(setvar “orthomode” ot)
 (princ))
;-<*error* end
   (prompt “…면적구하기”)
   (setq os (getvar “osmode”) ot (getvar “orthomode”)
         ts (getvar “textsize”))
   (setvar “orthomode” 0) (setvar “osmode” 0)
   (if (= dw nil) (setq dw 2))
;설정값 변경
   (setq a (strcat “n현재 설정값(문자높이=” (rtos ts 2 1)
            “,자리수=” (rtos dw 2 0) “)을 변경할까요? [Y/N] <N> : “))
   (initget “Yes No”)
   (setq yn (getkword a))
   (if (= yn “Yes”)
     (progn
       (setq a (strcat “n문자높이<” (rtos ts 2 1) “>:”))
       (setq ht (getdist a))
       (if (= ht nil) (setq ht ts))
       (setq a (strcat “n소수점 자리수을 지정<” (rtos dw 2 0) “>:”))
       (setq tem (abs (getint a)))
       (if (= tem nil) (setq dot dw) (setq dot tem) )
       (setq dw dot)
     (setq ht ts dot dw)
;선택방법
   (setq ent1 (entsel  “nPline선택 <내부점 선택>->”))
   (if ent1
     (progn
       (setq en1 (car ent1)) (redraw en1 3)
       (setq grpt (grread T))
       (setq pt1 (cadr grpt))
       (command “area” “e” ent1)  )
     (progn
       (prompt “nSelect internal point->”)
       (command “boundary” pause “”)
       (setq en1 (entlast))(redraw en1 3)
       (command “area” “e” “l”)
       (setq pt1 (getvar “lastpoint”))  )
   (setq ar1 (/ (getvar “area”) 1000000));제곱미터로 변경
   (setq ar2 (rtos ar1 2 dot));자리수=dot
   (if (>= dot 1)
       (setq ar3 (@tx_dot ar2 dot))
       (setq ar3 ar2)
   (command “text” “j” “r” pt1 ht “0” ar3)
   (prompt “nEnter text point->”)
   (command “move” “l” “” pt1 pause)
   (redraw en1 4)
   (prompt “n면적: “)(prin1 ar1)(prompt “㎡”)
(prin1))
;문자로된 숫자의 자리수를 맞추고 문자로 되돌리기
(defun @tx_dot(tx dot / k k1 tx tx1 tx2 tx3)
   (setq k1 (vl-string-position (ascii “.”) tx))
   (if (= k1 nil) (setq tx1 (strcat tx “.0”)) (setq tx1 tx))
   (setq k (strlen tx1))
   (setq k1 (vl-string-position (ascii “.”) tx1))
   (setq tx2 (substr tx1 1 (+ k1 1)));정수부분
   (setq tx3 (substr tx1 (+ k1 2)));소수부분
   (setq k (strlen tx3))
   (while (< k dot)
      (setq tx3 (strcat tx3 “0”))
   (strcat tx2 tx3)
  • 37 조회
    2. 방울도사 Lv.0
      2020-10-14T09:17:43+09:00답변 등록 답변 등록 일시 2020-10-14 9:17 am
      감사합니다~
