홈/ 질문/Q 29325
등록일: 2002-03-082002-03-08T14:40:10+09:00 2002-03-08T14:40:10+09:00카테고리: AutoCAD & CADian
리습, LOAD하는 방법좀 갈켜 주셔여
실은 제가 CAD는 2년 정도 하지만 부끄럽게도 프로그램을 잘 모릅니다.
리습은 있는데 LOAD하는 방법을 몰라서 못쓰고 있습니다.
도와 주십시요.
  • 5 5 답변
  • 52 조회
    5 답변
      2002-03-08T17:58:09+09:00답변 등록 답변 등록 일시 2002-03-08 5:58 pm
      3A, *3DARRAY
      3F, *3DFACE
      3P, *3DPOLY
      A, *ARC
      AA, *AREA
      AL, *ALIGN
      AP, *APPLOAD
      AR, *ARRAY
      AAD, *ASEADMIN
      AEX, *ASEEXPORT
      ALI, *ASELINKS
      ASQ, *ASESQLED
      ARO, *ASEROWS
      ASE, *ASESELECT
      AT, *DDATTDEF
      -AT, *ATTDEF
      ATE, *DDATTE
      -ATE, *ATTEDIT
      B, *BMAKE
      -B, *BLOCK
      BH, *BHATCH
      BO, *BOUNDARY
      -BO, *-BOUNDARY
      BR, *BREAK
      C, *CIRCLE
      CH, *DDCHPROP
      -CH, *CHANGE
      CHA, *CHAMFER
      COL, *DDCOLOR
      CO, *COPY
      D, *DDIM
      DAL, *DIMALIGNED
      DAN, *DIMANGULAR
      DBA, *DIMBASELINE
      DCE, *DIMCENTER
      DCO, *DIMCONTINUE
      DDI, *DIMDIAMETER
      DED, *DIMEDIT
      DI, *DIST
      DIV, *DIVIDE
      DLI, *DIMLINEAR
      DO, *DONUT
      DOR, *DIMORDINATE
      DOV, *DIMOVERRIDE
      DR, *DRAWORDER
      DRA, *DIMRADIUS
      DST, *DIMSTYLE
      DT, *DTEXT
      DV, *DVIEW
      E, *ERASE
      ED, *DDEDIT
      EL, *ELLIPSE
      EX, *EXTEND
      EXIT, *QUIT
      EXP, *EXPORT
      EXT, *EXTRUDE
      F, *FILLET
      FI, *FILTER
      G, *GROUP
      -G, *GROUP
      GR, *DDGRIPS
      H, *BHATCH
      -H, *HATCH
      HE, *HATCHEDIT
      HI, *HIDE
      I, *DDINSERT
      -I, *INSERT
      IAD, *IMAGEADJUST
      IAT, *IMAGEATTACH
      ICL, *IMAGECLIP
      IM, *IMAGE
      -IM, *-IMAGE
      IMP, *IMPORT
      IN, *INTERSECT
      INF, *INTERFERE
      IO, *INSERTOBJ
      L, *LINE
      LA, *LAYER
      -LA, *-LAYER
      LE, *LEADER
      LEN, *LENGTHEN
      LI, *LIST
      LS, *LIST
      LT, *LINETYPE
      -LT, *-LINETYPE
      LTS, *LTSCALE
      M, *MOVE
      MA, *MATCHPROP
      ME, *MEASURE
      MI, *MIRROR
      ML, *MLINE
      MO, *DDMODIFY
      MS, *MSPACE
      MT, *MTEXT
      MV, *MVIEW
      O, *OFFSET
      OS, *DDOSNAP
      -OS, *-OSNAP
      P, *PAN
      -P, *-PAN
      PA, *PASTESPEC
      PE, *PEDIT
      PL, *PLINE
      PO, *POINT
      POL, *POLYGON
      PR, *PREFERENCES
      PRE, *PREVIEW
      PRINT, *PLOT
      PS, *PSPACE
      PU, *PURGE
      R, *REDRAW
      RA, *REDRAWALL
      RE, *REGEN
      REA, *REGENALL
      REC, *RECTANGLE
      REG, *REGION
      REN, *DDRENAME
      -REN, *RENAME
      REV, *REVOLVE
      RM, *DDRMODES
      RO, *ROTATE
      RPR, *RPREF
      RR, *RENDER
      S, *STRETCH
      SC, *SCALE
      SCR, *SCRIPT
      SE, *DDSELECT
      SEC, *SECTION
      SET, *SETVAR
      SHA, *SHADE
      SL, *SLICE
      SN, *SNAP
      SO, *SOLID
      SP, *SPELL
      SPL, *SPLINE
      SPE, *SPLINEDIT
      ST, *STYLE
      SU, *SUBTRACT
      T, *MTEXT
      -T, *-MTEXT
      TA, *TABLET
      TH, *THICKNESS
      TI, *TILEMODE
      TO, *TOOLBAR
      TOL, *TOLERANCE
      TOR, *TORUS
      TR, *TRIM
      UC, *DDUCS
      UCP, *DDUCSP
      UN, *DDUNITS
      -UN, *UNITS
      UNI, *UNION
      V, *DDVIEW
      -V, *VIEW
      VP, *DDVPOINT
      -VP, *VPOINT
      W, *WBLOCK
      WE, *WEDGE
      X, *EXPLODE
      XA, *XATTACH
      XB, *XBIND
      -XB, *-XBIND
      XC, *XCLIP
      XL, *XLINE
      XR, *XREF
      -XR, *-XREF
      Z, *ZOOM
      ; The following are alternative aliases and aliases as supplied in AutoCAD Release 13.
      AV, *DSVIEWER
      CP, *COPY
      DIMALI, *DIMALIGNED
      DIMANG, *DIMANGULAR
      DIMBASE, *DIMBASELINE
      DIMCONT, *DIMCONTINUE
      DIMDIA, *DIMDIAMETER
      DIMED, *DIMEDIT
      DIMTED, *DIMTEDIT
      DIMLIN, *DIMLINEAR
      DIMORD, *DIMORDINATE
      DIMRAD, *DIMRADIUS
      DIMSTY, *DIMSTYLE
      DIMOVER, *DIMOVERRIDE
      LEAD, *LEADER
      TM, *TILEMODE
    3. 감각캐드
      2002-03-08T16:16:15+09:00답변 등록 답변 등록 일시 2002-03-08 4:16 pm
      de는여 아마두 text edit 할때사용하슨 명령어인 ddedit 단축명령어인듯..^^
      사용자마다 단축키를 다른경향이 있어 확실하지 않지만서두
      대부분 de는 ddeit의 단축명령어 입니다.
      혹시 님이 사용하는 명령어의 단축명령어가 궁금하심은
      캐드폴더안에 support 폴더안에 acad.pgp 이놈 열여보심은
      AA, *AREA —— 이런넘이 있는데여
      앞에놈이 단축명령어구여 뒤엣넘이 장축(?)명령어입니다 ^^
      건승하세여
    4. 티티티
      2002-03-08T15:40:18+09:00답변 등록 답변 등록 일시 2002-03-08 3:40 pm
      1
    5. sunforest
      2002-03-08T15:23:57+09:00답변 등록 답변 등록 일시 2002-03-08 3:23 pm
      넘- 넘- 넘 고맙습니다.
      진짜로 정말…
      근데 “de” 라는 단축키(리습) 아시나요?
      넘 염치없습니다.
    6. 티티티
      2002-03-08T14:48:31+09:00답변 등록 답변 등록 일시 2002-03-08 2:48 pm
      풀다운 메뉴에서 tools 에서.. Load application 누르시고..
      리습경로 잡아주시고.. Load 꾹.. 누르세욤~`
      금 존 하루 되시구욤..
      이만..휘리릭~!~!
