홈/ 질문/Q 106853
등록일: 2016-06-292016-06-29T17:06:57+09:00 2016-06-29T17:06:57+09:00카테고리: AutoCAD & CADian
문구가 뜨는데 무엇이 문제인지 모르겠습니다
오투캐드 2011쓰고 있는데요 고수님들 EXTRIM 하다가 저런 문구가 뜨는데 무엇이 문제인지 모르겠습니다 수정좀 해주시면 안되겠습니까
error: no function definition: ACET-ERROR-INIT
(defun c:extrim ( / na e1 p1 redraw_it lst n )
(acet-error-init (list
(list “cmdecho” 0
“highlight” 0
“regenmode” 1
“osmode” 0
“ucsicon” 0
“offsetdist” 0
“attreq” 0
“plinewid” 0
“plinetype” 1
“gridmode” 0
“celtype” “CONTINUOUS”
“ucsfollow” 0
“limcheck” 0
T ;flag. True means use undo for error clean up.
‘(if redraw_it (redraw na 4))
);list
);acet-error-init
(princ “nPick a POLYLINE, LINE, CIRCLE, ARC, ELLIPSE, IMAGE or TEXT for cutting edge…”)
(setq na (acet-ui-single-select ‘((-4 . “<OR”)
(0 . “CIRCLE”)
(0 . “ARC”)
(0 . “LINE”)
(0 . “ELLIPSE”)
(0 . “ATTDEF”)
(0 . “TEXT”)
(0 . “MTEXT”)
(0 . “IMAGE”)
(0 . “SPLINE”)
(0 . “INSERT”)
(0 . “SOLID”)
(0 . “3DFACE”)
(0 . “TRACE”)
(0 . “LWPOLYLINE”)
(-4 . “<AND”)
(0 . “POLYLINE”)
(-4 . “<NOT”)
(-4 . “&”)
(70 . 112)
(-4 . “NOT>”)
(-4 . “AND>”)
(-4 . “OR>”)
T
);acet-ui-single-select
);setq
(if na
(progn
(setq e1 (entget na));;setq
(if (or (equal “TEXT” (cdr (assoc 0 e1)))
(equal “MTEXT” (cdr (assoc 0 e1)))
(equal “ATTDEF” (cdr (assoc 0 e1)))
(equal “IMAGE” (cdr (assoc 0 e1)))
(equal “INSERT” (cdr (assoc 0 e1)))
(equal “SOLID” (cdr (assoc 0 e1)))
(equal “3DFACE” (cdr (assoc 0 e1)))
(equal “TRACE” (cdr (assoc 0 e1)))
);or
(progn
(setq lst (acet-geom-object-point-list na nil))
(setq n 0)
(command “_.pline”)
(repeat (length lst)
(command (nth n lst))
(setq n (+ n 1));setq
);repeat
(if (not (equal (car lst) (last lst) 0.0000001))
(command “_cl”)
(command “”)
);if
(setq na (entlast)
e1 na
);setq
);progn then draw a temp pline to be the cutting edge.
(setq e1 nil)
);if
(redraw na 3)
(setq redraw_it T)
(setq p1 (getpoint “nSpecify the side to trim on:”));setq
(redraw na 4)
(setq redraw_it nil)
(if p1 (etrim na p1));if
(if e1
(progn
(if (setq p1 (acet-layer-locked (getvar “clayer”)))
(command “_.layer” “_un” (getvar “clayer”) “”)
);if
(entdel e1)
(if p1
(command “_.layer” “_lock” (getvar “clayer”) “”)
);if
);progn then
);if
);progn
);if
(acet-error-restore)
);defun c:extrim
;Entity-TRIM function
;takes: na – entity name
; a – a point, the side to trim on
;NOTE: This function does not allow for the possible miss of
; non-continuous linetypes.
(defun etrim ( na a / la b d e1 lst lst2 n j k m ss na2 na3 na4
x y z flag flag2 flag3 zlst vpna vplocked
(setq e1 (entget na));setq
(if (or (setq flag (equal (acet-dxf 0 e1) “POLYLINE”))
(setq flag (equal (acet-dxf 0 e1) “LWPOLYLINE”))
(equal (acet-dxf 0 e1) “LINE”)
(equal (acet-dxf 0 e1) “CIRCLE”)
(equal (acet-dxf 0 e1) “ARC”)
(equal (acet-dxf 0 e1) “ELLIPSE”)
(equal (acet-dxf 0 e1) “TEXT”)
(equal (acet-dxf 0 e1) “ATTDEF”)
(equal (acet-dxf 0 e1) “MTEXT”)
(equal (acet-dxf 0 e1) “SPLINE”)
);or
(progn
(if (and flag
(equal 8 (logand 8 (acet-dxf 70 e1)))
);and
(setq flag nil)
);if
(setq a (trans a 1 0)
vpna (acet-currentviewport-ename)
);setq
(acet-ucs-cmd (list “_View”))
(setq lst (acet-geom-object-point-list na nil) ;;;find extents of selected cutting edge object
lst (acet-geom-list-extents lst)
x (- (car (cadr lst)) (car (car lst)))
y (- (cadr (cadr lst)) (cadr (car lst)))
x (* 0.075 x)
y (* 0.075 y)
z (list x y)
x (list (+ (car (cadr lst)) (car z))
(+ (cadr (cadr lst)) (cadr z))
);list
y (list (- (car (car lst)) (car z))
(- (cadr (car lst)) (cadr z))
);list
zlst (zoom_2_object (list x y))
);setq
(if vpna
(setq vplocked (acet-viewport-lock-set vpna nil)) ;unlock cur viewport if needed.
);if
(command “_.zoom” “_w” (car zlst) (cadr zlst))
(entupd na) ;;;update the ent. so it’s curves display smoothly
(/ (acet-geom-pixel-unit) 2.0)
);setq
(if (or (not flag)
(not (acet-geom-self-intersect lst nil))
);or
(progn ;then the object is valid and not a self intersecting polyline.
(if (and flag
(equal (car lst) (last lst) 0.0001)
);and
(setq flag3 T);then the polyline could potentialy need a second offset
);if
(if (setq la (acet-layer-locked (getvar “clayer”)))
(command “_.layer” “_unl” (getvar “clayer”) “”)
);if
(command “_.pline”)
(setq b nil)
(setq n 0);setq
(setq d (nth n lst))
(if (not (equal d b 0.0001))
(progn
(command d)
(setq lst2 (append lst2 (list d)));setq
(setq b d);setq
);progn
);if
(setq n (+ n 1))
);repeat
(command “”)
(setq na2 (entlast)
ss (ssadd)
ss (ssadd na2 ss)
lst nil
);setq
(acet-ss-visible ss 1)
(setq lst2 (get_fence_points na2 a lst2 flag3 flag));setq
(if la
);if
(acet-ucs-cmd (list “_p”))
;Move the ents to force a display update of the ents to avoid viewres problems.
(setvar “highlight” 0)
(if (setq ss (ssget “_f” (last lst2)))
(command “_.move” ss “” “0,0,0” “0,0,0”)
);if
(if flag
(progn
(if (setq la (acet-layer-locked (acet-dxf 8 e1)))
(command “_.layer” “_unl” (acet-dxf 8 e1) “”)
);if
(acet-ucs-set-z (acet-dxf 210 e1))
(command “_.copy” na “” “0,0,0” “0,0,0”)
;(entdel na)
(acet-ss-visible (ssadd na (ssadd)) 1);make it invisible for a while.
;rk 12:01 PM 3/10/98
(setq na3 na
na (entlast)
);setq
(command “_.pedit” na “_w” “0.0” “_x”)
(if la (command “_.layer” “_lock” (acet-dxf 8 e1) “”));if
);progn
);if
(command “_.trim” na “”)
(setq m (- (length lst2) 1));setq
(setq k 0)
(repeat (length lst2)
(setq lst (nth k lst2))
(setq a (trans (car lst) 0 1))
(setq n 1)
(repeat (- (length lst) 1) ;repeat each fence list
(setq b (trans (nth n lst) 0 1))
(if (equal a b 0.0001)
(setq flag2 T)
(setq flag2 nil)
);if
(setq na4 nil);setq
(setq j 0);setq
(while (not flag2) ;repeat each segment of the fence until no new ents are created.
(setq na4 (entlast));setq
(command “_F” a b “”)
(if (and (equal na4 (entlast))
(or (not (equal k m))
(> j 0)
);or
);and
(setq flag2 T)
);if
(setq j (+ j 1));setq
);while
(setq a b);setq
);repeat
(setq k (+ k 1))
);repeat
(command “”)
(if flag
(progn
);if
(entdel na) ;get rid of the copy
;(entdel na3);bring back the original
(acet-ss-visible (ssadd na3 (ssadd)) 0) ;bring back the original
);progn
);if
);progn
(progn
(princ “nSelf intersecting edges are not acceptable.”)
);progn else invalid self intersecting polyline
);if
(command “_.zoom” “_p”)
(if vplocked
(acet-viewport-lock-set vpna T) ;then re-lock the viewport
);if
);progn then it’s a most likely a valid entity.
);if
);defun etrim
(defun another_offset ( pl1 pl2 a1 a2 b na2 lst2 a lst3 lst4 / na ss lst da1 da2)
(setq da1 (abs (- a2 a1)));setq
(setq da2 (- (* b (max pl2 pl1))
(/ (* b (abs (- pl2 pl1)))
2.0
);setq
(if (> (abs (- da2 da1))
(* 0.01 (max a1 a2))
(progn
(acet-pline-make (list lst2))
(setq na (entlast)
na2 (entlast)
ss (ssadd)
ss (ssadd na ss)
);setq
(command “_.offset” b na2 a “”)
(if (and (not (equal na (entlast)))
(setq lst3 (acet-geom-vertex-list (entlast)))
(setq lst3 (intersect_check lst2 lst3 lst4))
);and
(progn
(acet-ss-visible (ssadd (entlast) (ssadd)) 1)
(command “_.area” “_ob” (entlast))
(setq pl2 (getvar “perimeter”)
a2 (getvar “area”)
);setq
(setq lst (list (acet-geom-vertex-list (list (entlast) 0))));setq
(entdel (entlast));then offset was a success so delete the ent after getting it’s info
);progn then
(if (not (equal na (entlast))) (entdel (entlast)));if else
);if
(entdel na2)
);progn then let’s do that second offset
);if
lst
);defun another_offset
(defun get_fence_points ( na2 a lst2 flag plflag / a1 a2 pl1 pl2 b c d n
lst lst2 lst3 lst4 na
(if flag
(progn
(setq lst2 (cdr lst2));setq
(repeat (fix (/ (length lst2) 2))
(setq lst2 (append (cdr lst2) (list (car lst2)));append
);setq
);repeat
(setq lst2 (append lst2 (list (car lst2))));setq
(command “_.area” “_ob” na2)
(setq pl1 (getvar “perimeter”)
a1 (getvar “area”)
);setq
);progn
);if
(setq a (trans a 0 1)
b (* (getvar “viewsize”) 0.05);initial offset distance
n 3.0 ;number of offsets
d (/ b (- n 1)) ;delta offset
c (acet-geom-pixel-unit)
lst4 (acet-geom-view-points)
);setq
(while (> b c)
(setq na (entlast))
(or (not plflag)
);or
);and
(progn
(setq lst3 (acet-geom-m-trans lst3 1 0))
(if flag
(progn
a2 (getvar “area”)
);setq
);progn
);if
(setq lst (append lst (list lst3)));setq
(entdel (entlast)) ;delete the ent after getting it’s vertex info
(if flag
(another_offset pl1 pl2 a1 a2 b na2 lst2 a lst3 lst4)
);append
);setq
);if
);progn then offset was a success
);if
(setq b (- b d));setq
);while
(setq na (entlast))
(command “_.offset” c na2 a “”)
(or (not plflag)
);or
);and
(progn
(if flag
(progn
a2 (getvar “area”)
);setq
);progn
);if
(if flag
(another_offset pl1 pl2 a1 a2 c na2 lst2 a lst3 lst4)
);append
);setq
);if
);progn then
);if
(entdel na2)
lst
);defun get_fence_points
;returns a list of points on screen if the first two lists do not
;contain segments that intersect each other.
(defun intersect_check ( lst lst2 lst3 / x x2 y y2 lst4 flag len len2
a aa b bb c d n j)
(setq len (length lst)
len2 (length lst2)
x (car (car lst3))
x2 (car (cadr lst3))
y (cadr (car lst3))
y2 (cadr (cadr lst3))
);setq
(setq n 0);setq
(while (and (not flag)
(< (+ n 1) len2)
);and
(setq aa (nth n lst2)
bb (nth (+ n 1) lst2)
a (bns_truncate_2_view aa bb x y x2 y2)
b (bns_truncate_2_view bb aa x y x2 y2)
lst4 (append lst4 (list a))
);setq
(if (or (not (equal a aa))
(not (equal b bb))
);or
(setq lst4 (append lst4 (list b)))
);if
(setq j 0);setq
(< (+ j 1) len)
);and
(setq c (nth j lst)
d (nth (+ j 1) lst)
flag (inters a b c d)
);setq
);while
);while
(if (not (equal b (last lst4)))
(setq lst4 (append lst4 (list b)));setq
);if
(if (not flag)
(setq flag lst4)
(setq flag nil)
);if
flag
);defun intersect_check
(defun zoom_2_object ( lst / p1 p2 p3 p4 p5 p6 mp dx dy dx2 dy2
r1 r2 na e1 x w h dv1 dv2 x
(setq lst (acet-geom-m-trans lst 1 2)
p1 (acet-geom-m-trans (acet-geom-view-points) 1 2) ;p1 and p2 are the viewpnts
p2 (cadr p1)
p1 (car p1)
p1 (list (car p1) (cadr p1))
p2 (list (car p2) (cadr p2))
);setq
(if lst
(progn
(setq p5 (acet-geom-list-extents lst) ;p5 and p6 are the geometry points
p6 (cadr p5)
p5 (car p5)
p5 (list (car p5) (cadr p5))
p6 (list (car p6) (cadr p6))
mp (acet-geom-midpoint p5 p6) ;prepare to resize the geometry rectang to
dx (- (car p2) (car p1)) ;have the same dy/dx ratio as p1 p2.
dy (- (cadr p2) (cadr p1))
dx2 (- (car p6) (car p5))
dy2 (- (cadr p6) (cadr p5))
);setq
(if (equal dx 0.0) (setq dx 0.000001)) ;just in case div by zero
(if (equal dx2 0.0) (setq dx2 0.000001))
(setq r1 (/ dy dx)
r2 (/ dy2 dx2)
);setq
(if (< r2 r1)
(setq dy2 (* r1 dx2));then scale dy2 up
(progn
(if (equal r1 0.0) (setq r1 0.000001)) ;just in case div by zero
(setq dx2 (* dy2 (/ 1.0 r1)));else scale dx2 up
);progn
);if
(setq p5 (list (- (car mp) (/ dx2 1.98)) ;1.98 is used instead of 2.0 to expand
(- (cadr mp) (/ dy2 1.98)) ;the rectangle slightly
);list
p6 (list (+ (car mp) (/ dx2 1.98))
(+ (cadr mp) (/ dy2 1.98))
);list
);setq
);progn then lst
);if
(if (and lst
(equal 0 (getvar “tilemode”))
(not (equal 1 (getvar “cvport”)))
(setq na (acet-currentviewport-ename))
);and
(progn
x (cdr (assoc 10 e1))
w (cdr (assoc 40 e1))
h (cdr (assoc 41 e1))
p3 (list (- (car x) (/ w 2.0))
(- (cadr x) (/ h 2.0))
);list
p4 (list (+ (car x) (/ w 2.0))
(+ (cadr x) (/ h 2.0))
);list
p3 (trans p3 3 2) ;p3 and p4 are the viewport points
p4 (trans p4 3 2)
dv1 (acet-geom-delta-vector p1 p3)
dv2 (acet-geom-delta-vector p2 p4)
x (distance p1 p2)
);setq
(if (equal 0 x) (setq x 0.000001));just in case
(setq x (/ (distance p5 p6)
x
dv1 (acet-geom-vector-scale dv1 x)
dv2 (acet-geom-vector-scale dv2 x)
p5 (acet-geom-vector-add p5 dv1)
p6 (acet-geom-vector-add p6 dv2)
);setq
);progn then
);if
(setq p1 (list (car p1) (cadr p1) 0.0)
p2 (list (car p2) (cadr p2) 0.0)
p5 (list (car p5) (cadr p5) 0.0)
p6 (list (car p6) (cadr p6) 0.0)
);setq
(if lst
(setq lst (list (trans p5 2 1)
(trans p6 2 1)
);list
);setq
(setq lst nil)
);if
lst
);defun zoom_2_object
  • 62 조회
    • 도구막대 이동시 미리보기가 안됩니다.
