홈/ 질문/Q 111160
조니1
조니1Lv.1
등록일: 2019-04-042019-04-04T22:54:11+09:00 2019-04-04T22:54:11+09:00카테고리: AutoCAD & CADian
양방향 옵셋인데 처음잡은선을 바꾸고 양방향되는선도 바꾸고하려는데 잘안되네요 ㅠ
(defun c:YY()
    (setq  olderr *ERROR*)
(setq os_m (getvar “osmode”))
(setvar “osmode” 37)
(setvar “cmdecho” 0)
        (if (tblsearch “layer” “!JK01”)
(command “_layer” “S” “!JK01”  “color” “1” “” “”)
    (command “_layer” “make” “!JK01” “lt” “continuous” “” “color” “1” “” “”)
        );endif
       (if (tblsearch “layer” “!JK13_GIRDER”)
          (command “_layer” “S” “!JK13_GIRDER”  “color” “3” “” “”)
      (command “_layer” “make” “!JK13_GIRDER” “lt” “HIDDEN” “” “color” “3” “” “”)
);endif
    (command “-layer” “s” “!JK13_GIRDER” “”)
(if (= OFF100 nil) (setq OFF100 0))
(SETQ OFF_100 OFF100)
(SETQ OOABC “”)
(PRINC “N 양쪽 간격의 총 크기 [반지름 (R)] “)
(PRINC “< “) (PRINC OFF_100) (PRINC” > :”)
(setq OOABC (strcase (getstring)))
(setq OFF100 (ATOf OOABC))
(IF (OR (= OOABC “R” ) (= OOABC “r”))
    (PROGN
        (SETQ OO222 (/ OFF_100 2))
        (setq OFF100 (getreal (strcat “n양쪽 간격의 반 지름 <” (rtos OO222) “>:”)))
        (SETQ OFF_100 (* OO222 2))
        (SETQ OFF100 (* OFF100 2))
(IF (OR (= OFF100 NIL) (= OFF100 0))
(SETQ OFF100 OFF_100)
(setq off1(* off100 0.5))
(SETQ a1(SSGET))
(SETQ NUM(SSLENGTH a1))
(SETQ INDEX 0)
(REPEAT NUM(SETQ b1(entget(ssname a1 index)))
    (setq kkke(cdr(assoc 0 b1)))
    (IF(= “LINE” kkke)
         (progn
              (setvar “osmode” 0)
              (setq c1(assoc 10 b1))
              (setq c2(assoc 11 b1))
              (setq d1(cdr c1))
              (setq d2(cdr c2))
              (setq ang(angle d1 d2))
(setq p1(polar d1(+ ang (* 0.5 pi)) off1))
(setq p2(polar d1(- ang (* 0.5 pi)) off1))
(setq p3(polar d2(+ ang (* 0.5 pi)) off1))
(setq p4(polar d2(- ang (* 0.5 pi)) off1))
              (command “line” p1 p3 “”)
              (command “line” p2 p4 “”)
              (setq index(+ index 1))
              (command “osmode” 191)
              (SETQ KIS OFF100)
    (if(= “ARC” kkke)
         (progn
              (setvar “osmode” 0)
              (setq cc1(assoc 10 b1))
              (setq rr1(assoc 40 b1))
              (setq c1(assoc 50 b1))
              (setq c2(assoc 51 b1))
              (setq dd1(cdr cc1))
              (setq r1(cdr rr1))
              (setq d1(cdr c1))
              (setq ang1(rtd d1))
              (setq d2(cdr c2))
              (setq ang2(rtd d2))
              (setq ptt1(+ r1 off1))
              (setq ptt2(- r1 off1))
              (setq kkkk1(strcat “@”(rtos ptt1) “<“(rtos ang1)))
              (setq kkkk2(strcat “@”(rtos ptt1) “<“(rtos ang2)))
              (setq kkkk3(strcat “@”(rtos ptt2) “<“(rtos ang1)))
              (setq kkkk4(strcat “@”(rtos ptt2) “<“(rtos ang2)))
              (command “arc” “c” dd1 kkkk1 kkkk2)
              (command “arc” “c” dd1 kkkk3 kkkk4)
              (command “osnap” “int”)
              (SETQ KIS OFF100)
              (COMMAND “osmode” os_m)
(setq OOABC “”)
  (command “chprop” ent “” “c” “bylayer” “lt” “bylayer” “la” “!JK01” “”)
양방향 옵셋 다른분이 만든거를 짜집어서 바꿀려고 하는건데
처음잡은 선은 빨간선으로 바꾸고 양쪽으로 옵센되는선은 녹색으로 바꾸고자 만들었는데 잘안되네요 ㅠ
기본 양방향옵셋도 될때도있고 안될때도있고 옵센된게 도면저멀리 날라가있거나 하는경우도있는데
그건 도무지뭔지몰라서 … 수정을못하겠습니다. 수정된거 있으시거나 이렇게 접근해보신적있으신분!
  • 32 조회
    • 도구막대 이동시 미리보기가 안됩니다.
    2. 수야12 Lv.22
      2019-04-05T07:41:59+09:00답변 등록 답변 등록 일시 2019-04-05 7:41 am
      혹시 구문이 낯설어도 사용하시다보면 자연스럽게 알게 됩니다 (저도 그렇게 배웠어요 )화이팅~!!
    3. 조니1 Lv.1
      2019-04-08T10:43:50+09:00답변 등록 답변 등록 일시 2019-04-08 10:43 am
      고캐드에서 추천해준 책사서 보고있는데
      리습관련 좋은책 추천좀해주세요 ㅎ
    4. 조니1 Lv.1
      2019-04-08T10:47:29+09:00답변 등록 답변 등록 일시 2019-04-08 10:47 am
      제가 짜집은거에 비해서 너무간단하게 되있어서 코딩이란 세계가 세상 놀랍네요.
    5. 수야12 Lv.22
      2019-04-08T12:09:55+09:00답변 등록 답변 등록 일시 2019-04-08 12:09 pm
      제가 리습 관련 책만 5권정도 있는데 초보때 여러가지 책은 의미 없습니다 그냥 아무책이나 한권으로
      기본문법 익히고 나머지는 넷상에서 발품 팔아가면서 하나 하나 배울수 밖에 없습니다
      일단 초보때는 내가 뭘 모르는지 몰라요 그러니 급하게 마음 먹지 마시고 일단 기본만 익힌다 생각하세요
      저도 먼저 앞서간 선배분들이 캐드 도움말이 가장 좋은 책이다 이럴때  뭔 말도 안되는 소리야?
      했는데 시간이 지나고 내공이 쌓이니 아 선배들 말이 맞구나 싶습니다~!!
      리습 배울때 필요한 준비물
       1. 가장 기본적인 리습책(대충 리습이 어떤식으로 흘러가는지 알 수 있을정도의 기본지식을 위해)
       2. 리습함수 목록 (뭘 할 수 있는가를 파악)
       3. 리습함수 도움말 (요즘은 캐드 온라인 도움말이 잘 돼있죠)
       4. 끈기와 열정 입니다
      화이팅~!!
