홈/ 질문/Q 90954
등록일: 2011-03-112011-03-11T14:14:46+09:00 2011-03-11T14:14:46+09:00카테고리: AutoCAD & CADian
원에 중심선 삽입 리습인데요. 이거만쓰면 오스넴 세팅이 풀려버리네요. 어떻게 바꿔야 하나요?
;원에 중심선 삽입
(defun  c:CL()  (setvar   “cmdecho” 0)(setvar “osmode” 0)(setvar “orthomode” 1)
                (setq     ent       (entget  (car     (entsel   “nSelect circle :”))))
                (setq     cen       (cdr     (assoc     10        ent)))
                (setq     rad       (cdr     (assoc     40        ent)))
                (setq     val       (*       rad       1.20))
                (setq     pnt1      (list    (-         (car      cen)      val)      (cadr     cen)))
                (setq     pnt2      (list    (+         (car      cen)      val)      (cadr     cen)))
                (setq     pnt3      (list    (car       cen)      (+        (cadr     cen)      val)))
                (setq     pnt4      (list    (car       cen)      (-        (cadr     cen)      val)))
                (command  “layer”  “t”  “CL”  “”)
                (command  “layer”  “s”  “CL”  “”)
                (command  “line”    pnt1     pnt2      “”)
                (command  “line”    pnt3     pnt4      “”)
                (command  “layer”  “s”  “0”  “”)
                (princ))
고수님들 부탁드려요~
  • 16 조회
